Difficulty bending to a nice curve
Clive Hartland | 08/08/2012 21:49:06 |
![]() 2929 forum posts 41 photos | Any one know how to get a nice bend/curve on 4mm copper tube? I have tried spring tube benders and it kinks and I now contemplate lead filling. Do I make a tube bender? Clive |
Nathan Sharpe | 08/08/2012 22:02:25 |
175 forum posts 3 photos | Hi Clive, Have you tried a brake pipe bender? Cheap off ebay. Nathan. |
mgj | 08/08/2012 23:08:15 |
1017 forum posts 14 photos | I have a tube bender - Hemingway. Very good, but over complex for the task- but quite excellent in the slightly larger sizes of tube. If i'm not telling my granny, the operational guts of the thing is a groove, just over 1/2 th dia of thee tube to be bent. That stops it going oval and collapsing. So a lot of my smaller tubes I bend by using a ball nose cutter on a rod of the required bend radius, of about 75% dia depth, and bend the annealed tube around that. 3/16 tube I like the sliding shoe of the bender, but less than that a thumb and a groove does as well! |
Michael Gilligan | 08/08/2012 23:38:47 |
![]() 23121 forum posts 1360 photos | Don't know if it's still available, but Record did a "Mini Pipe Bender" in cast Alloy [painted Blue, of course], for tubes around this size. Alternatively ... fill with Wood's Metal, not Lead; it melts at at about 80°C MichaelG. Edited By Michael Gilligan on 08/08/2012 23:42:23
Looks like the Record is still available ... at a price! Edited By Michael Gilligan on 08/08/2012 23:47:05 |
Clive Hartland | 09/08/2012 07:37:43 |
![]() 2929 forum posts 41 photos | It looks like I will make a mini Pipe bender as part of the exercise. I will need one for a later job anyway. Clive |
Clive Hartland | 09/08/2012 14:35:18 |
![]() 2929 forum posts 41 photos | The specified bend is 4mm Radius so it is pretty tight bending with 4mm Dia. copper tube. Its a bending jig for sure, I will start on it this evening when it is cooler as the sun is right in the front of the workshop. Clive |
paul rayner | 09/08/2012 16:46:25 |
187 forum posts 46 photos | I have read somewhere if you pack tube with dried sand and seal the ends up you will get kink free bends, although I would imagine in small bore pipes it may prove difficult to remove all the sand. |
mgj | 09/08/2012 21:43:29 |
1017 forum posts 14 photos | Clive - 4mm rad in 4mm pipe is seriously tight. That will be an entertainment. I think you'll need the extra leverage of a bender to do that nicely. There is a sort of ideal (typical) minimum dia/bend rad ratio. I have forgotten what it is, and someone may be able to help with that - but its not 1:1!!!! Any way you can get away with it a bit wider than 1:1? |
DMB | 09/08/2012 22:11:30 |
1585 forum posts 1 photos | Clive, try Chris Heapy`s site. I think he does a table of sizes, pipes/radii etc.. If not, root around various sites run by individuals, because I`ve seen it somewhere! John. |
Versaboss | 09/08/2012 22:37:50 |
512 forum posts 77 photos |
Posted by paul rayner on 09/08/2012 16:46:25:
I have read somewhere if you pack tube with dried sand and seal the ends up you will get kink free bends, although I would imagine in small bore pipes it may prove difficult to remove all the sand. Very true, Paul. A colleague tried to make a helix coil from 10 mm copper tube. The diameter of the coil was around 50-60 mm (from memory). He tried filling with sand and was unable to remove it afterwards. Then he had a brilliant idea: he filled the tube with table salt... Just put it in a bucket of water afterwards, and away it is. At the softening temperature of copper the salt does not melt. That way he produced a perfect coil. Greetings, Hansrudolf |
Michael Gilligan | 09/08/2012 22:45:17 |
![]() 23121 forum posts 1360 photos | Clive, You might find some useful guidance here ... He's talking slightly bigger sizes than 4mm, but the principles are explained. MichaelG.
As I mentioned earlier ... Wood's Metal, or similar, is the best option for filling. I think the Plumber's version is called CerroBend ... see here
Edited By Michael Gilligan on 09/08/2012 22:46:30 Edited By Michael Gilligan on 09/08/2012 22:59:41 |
Michael Gilligan | 09/08/2012 23:10:45 |
![]() 23121 forum posts 1360 photos | Clive, There is a very neat tube bender, described in photo's and a drawing, here MichaelG. |
mark mc | 13/08/2012 13:38:16 |
92 forum posts 16 photos | I've heard of people filling the pipe with water and freezing it then bend |
Clive Hartland | 13/08/2012 18:06:34 |
![]() 2929 forum posts 41 photos | Thanks for that lead Michael, I have downloded the drwg and will study it to see if I can machine it with what I have. Mark, I have taken that on board as my freezer is right alongside my workbench. Clive |
FMES | 03/11/2012 22:57:59 |
608 forum posts 2 photos | Hi Clive, I use a product called 'Cerrobend', it looks like lead but melts in boiling water - just melt and fill the pipe, bend and a quick touch with a small torch melts it all out again for reuse. Hope this is of use Lofty |
fizzy | 04/11/2012 20:24:26 |
![]() 1860 forum posts 121 photos | for ultra cheap you can fill it with water then put it in the freezer - work quickly once removed though! |
Clive Hartland | 04/11/2012 22:48:58 |
![]() 2929 forum posts 41 photos | I have made a bender to an American design but its as good as useless on the 4mm tube even when annealed. I am now looking at one with a grooved bar that goes around with pipe as you bend it. I will still have to make it and I just need a little more time before I start. One of the main problems is the pipe is pulled through as you roll the wheel around. See my photos as there is a pic. of it there. This seems to make the rad. larger than what i want. Clive Edited By Clive Hartland on 04/11/2012 22:50:26 |
John Ockleshaw 1 | 05/11/2012 02:23:51 |
![]() 56 forum posts 7 photos | Hello Clive, Commander W.T.Barker described a tube bender in Model Engineer number2383, 9th January, 1947. It is for small copper tube up to 1/4" diameter maximum with a centre line radius of 1 1/2 to 2 diameters minimum. A anchored mandrel supports the inside of the tube at the point of bending. I made one years ago and it does a first class job. If you do not have access to the issue I can email you a copy of the article. Regards, Graham |
Clive Hartland | 05/11/2012 07:42:33 |
![]() 2929 forum posts 41 photos | Graham, can you contact me through PM's and I can give you my email addy there. Clive |
Michael Gilligan | 05/11/2012 08:22:25 |
Posted by Clive Hartland on 09/08/2012 14:35:18:
Clive, It will be very interesting if you do manage to achieve this. With the notable exception of Michael Williams' Cut & Shut ... Every design, or method, mentioned so far seems to indicate that 1.5 diameters is a realistic minimum for the bend radius. Please could you post some pictures of your experimental results? Also ...if/when you do succeed; I think it would make an excellent subject for an article in MEW. MichaelG. |
