Wolfie | 19/06/2012 12:40:59 |
![]() 502 forum posts | OK I've come across a small problem which I'm sure there is a simple answer to I want to make a brass bush in 2 halves. OK so I turn it to the right diameter and drill the hole thinking that I will then saw it in two and thats it sorted. Except of course that when you saw it in two you reduce the diameter by 2 saw cuts so it doesn't fit any more. Ooops. The same is going to go for axle supports . How is this usually done? |
David Clark 1 | 19/06/2012 13:09:23 |
![]() 3357 forum posts 112 photos 10 articles | Hi Wolfie. I would use two bits of flat bar and the four jaw chuck. Say two bits 1/2 x 1/4 with the split line central in the four jaw chuck. regards David
John McNamara | 19/06/2012 13:15:20 |
![]() 1377 forum posts 133 photos | Hi One way would be to soft solder two brass rectangles together, then centre them in the 4 jaw. They would need to be longer to allow for the section gripped in the jaws. Then turn the outside and bore the centre. The solder joint can be broken easily by carefully warming the piece up. Maybe the solder step can be avoided if you use light cuts. After parting the bearing off a few strokes on a file will give the slot a little Clarence. (Or clamp them together with a piece of paper between before machining that should give a couple of thou clearence.) Cheers John Edited By John McNamara on 19/06/2012 13:19:14 |
John McNamara | 19/06/2012 13:52:22 |
![]() 1377 forum posts 133 photos | Hi This link shows a split boring bar being turned. Half way to a bearing bush and close to a rail split bush. Cheers John |
NJH | 19/06/2012 13:54:27 |
![]() 2314 forum posts 139 photos | Hi Wolfie This is quite a common occurance. When you buy kits of castings for stationary engines the eccentric straps and big end bearings are often supplied as one piece gunmetal castings. As has been said the technique is to saw them in half, clean up the joints and then soft solder the two bits bits back together. It's likely that you will be holding the component in the 4-jaw so great strength is not an issue. I did, at one time, have some solder paste which is just brushed on, the two halves pressed together and then heated until there was evidence of the molten solder at the joint. I recall too that I have applied multicore electrical solder to each half, wiped off the surplus with a cloth , then when cold aligned and clamped the two halves together, re heated and bingo - they were secure! - (Well secure enough to machine anyway. ) Then, ensuring that you have first drilled the holes for the securing bolts, reheat to seperate. Regards Norman
Edited By NJH on 19/06/2012 13:56:06 |
Stub Mandrel | 19/06/2012 19:39:42 |
![]() 4318 forum posts 291 photos 1 articles | I have never used the solder method. I rough machine the outside shape, drill and hold the two halves together with bolts and clamp firmly before boring. I have a VERY thin slitting saw (about 10 thou) and for 'bearing brasses' which are held in a support that gap is quite acceptable - but you couldn't do this for an eccentric strap without taking a final skim to true up on re-assembly.. Welcome back, by the way! You'll be cheered to hear I have been experimenting with cardboard models while you were away, and I've just started the Revell Se5a (my favourite plane for models). Neil |
Andrew Johnston | 19/06/2012 19:53:01 |
![]() 7061 forum posts 719 photos | The soft solder method has never worked for me; it always ends with the joint breaking during machining. Soft solder isn't exactly known for its strength. I usually make a jig that allows the bearing to be machined without soldering them together. Like this: Regards, Andrew |
julian atkins | 19/06/2012 23:56:58 |
![]() 1285 forum posts 353 photos | i had the same problem with the split brasses/bronze bushes for the big ends on my 5"g terrier. i machined the bearing oversize inside and out then split with a junior hacksaw. i then soft soldered together ala LBSC with eccentric straps. i then bored them to the journal diameter setting reasonably to true in the 4-jaw. i then loctited them to some bar of the journal diameter, shoved same in the 3-jaw, and turned the outer diameter. in my case i also turned a groove to locate around the bearing straps with a parting tool. i then heated up when the loctite disentigrated and the soft solder melted! all fitted now ok! cheers, julian |
Ady1 | 20/06/2012 02:11:12 |
![]() 6137 forum posts 893 photos | I usually make a jig that allows the bearing to be machined without soldering them together like this Great idea, I had all sorts of mathematical solutions running through my head for taking the loss of circumference into account. doh! Being overeducated can make you look for complicated solutions to simple problems So now even a 4 part bearing or a two piece leadscrew clasp nut is a total doddle (double doh!)
Edited By Ady1 on 20/06/2012 02:15:55 |
Terryd | 20/06/2012 05:28:37 |
![]() 1946 forum posts 179 photos | Hi Wolfie, What is the shape and size of the bush? Regards Tery |
Ian S C | 20/06/2012 06:30:12 |
![]() 7468 forum posts 230 photos | Theway I make big end bearings for my Stirling Engines: For a 3/8" / 10 mm bearing. drill the big end of the con rod 1/2". Take a bit of bronze, and bore to size for reaming, and reduce OD to fit the big end tightly, press it in. This is where I (just for the heck of it),use the power hacksaw fitted to one of my Stirling Engines, I cut across the diameter of the bush, and the big end. Fit the screws to retain the bearing cap, mount in the lathe, and either bore or ream the bush. The out side of the bush is slightly oval, so it won't rotate, and it stays in place. Just my way, it could just as easily be done with a round hole in the big end, and replacement would be easier. Ian S C
Ramon Wilson | 20/06/2012 08:11:07 |
![]() 1655 forum posts 617 photos | Have to disagree on solder not being man enough - unless the joint is stessed outward eg mounting on an expanding mandrel and overtightening. I've made quite a few split bearings over time and always used this method. If you're interested I described the process on HMEM here - (I hope that doesn't cause the text under the advert syndrome but I can't see how to use a link word) Hope that helps a little more
Regards - Ramon |
Wolfie | 20/06/2012 12:44:31 |
![]() 502 forum posts | Interesting link there Ramon, nice work. @Terry, its a theoretical question at the moment. @Andrew, can you show some more photos of that? Edited By Wolfie on 20/06/2012 12:46:27 |
Andrew Johnston | 20/06/2012 22:42:08 |
![]() 7061 forum posts 719 photos | Hi Wolfie, I'm afraid I don't have any more pictures of the actual machining operation. However I have taken a picture of the jig, as here: For scaling the rectangular slot is 1.5" across. The sequence of machining to make the jig was as follows. The front face, smaller diameter and middle face were machined in one go in the lathe. At the same time a 1.5" hole was drilled and bored. The part was then turned round and plain facing operation done to get the correct thickness, 0.75". Note that the set up of the part is not critical for the facing operation; it doesn't matter if the machined diameters don't run true. The outer diameter was not machined as it plays no part when using the jig. The part was then transferred to the mill and the rectangular slot milled out using the 1.5" bore as a guide. When the remnants of the bored hole disappear on the sides and at the bottom I know that the slot is 1.5" wide, and that the bottom of the slot must be exactly 0.75" below the centre of the machined spigot. In use the jig is set up in the four jaw chuck so that the spigot runs true. I then know that the two sides and bottom of the slot are equi-distant from the centre line of the lathe. Thus, when the blank bearing halves are placed in the jig I know that a hole bored in the bearings will be exactly central in both X and Y. The bearings are held in place by the fourth jaw operating in the slot with a piece of scrap brass in the way to avoid damaging the bearings. Best Regards, Andrew |
