What type of tool is best
Baldric | 16/05/2012 13:25:24 |
195 forum posts 32 photos | I am going to need to turn some balls in the near future as will need to make or buy a tool to use on my lathe. As I see it there are 2 types:
Which is easier to use? Looking on youtude option 2 seems easier as once the the ball diameter is set it can be left and just use the cross slide to feed in to the work. Is one type more flexible than the other? If so why? FYI I have a Boxford so will be looking to use it on that. Baldric |
Michael Cox 1 | 16/05/2012 14:32:10 |
555 forum posts 27 photos | Hi Baldric, I made myself a type two ball turner which I have used quite often and seems to give satisfactory results. It is based on the Steve Bedair design but I have modified the position of the cutting insert so that complete balls can be turned. More details are here: Mike |
Tractor man | 16/05/2012 16:38:13 |
426 forum posts 1 photos | Are you making balls or ball ended handles? The type 1 is excellent for ball handles and I made one of the Hemmingway kits and found it to be very good. Regards T |
Baldric | 16/05/2012 16:48:49 |
195 forum posts 32 photos | Thanks for the responses so far. I will be actually making a ball on the end of a rod for a steering joint, but can alos see it being usefull when making globe valves and other itmes that need to loo pretty. Mike, I can see why you ammended the tip holder, it looks very good. |
JasonB | 16/05/2012 17:11:34 |
![]() 25215 forum posts 3105 photos 1 articles | I also made a Bedair type tool here is a pic of it in action actually being used for a concave cut rather than convex, not sure if the up and over do both ways? My cross slide is long enough to leave the top slide in place. You do need to have a fair amount of work sticking out of teh chuck with this type the up and over can be used a bit closer. The Bedair design is easily found on teh net and adapted to suit your own lathe. J
Clive Hartland | 16/05/2012 17:38:30 |
![]() 2929 forum posts 41 photos | If you have room under the job for a rotary table you can mount a tool on the rotary table and use that to cut spheres. I have in fact done this on a milling machine and it works well. Clive |
JasonB | 16/05/2012 18:12:21 |
![]() 25215 forum posts 3105 photos 1 articles | There are some pictures of the method Clive describes on this site |
Gray62 | 16/05/2012 18:15:20 |
1058 forum posts 16 photos | I made the Hemingway ball turning tool some time ago and it has served me well, I made all of the double ended ball handles for my Quorn with it plus many others.
In hind sight, I would adapt a budget 50mm boring head to do the same job, saves a lot of work and gives the same end result CB |
Chris B | 16/05/2012 18:23:17 |
34 forum posts 5 photos | I was given a set of Hemingway drawings and made my own but found as drawn, the pivot block that clamps in the toolpost was too short for the QCTP on my Boxford,so the handle would have fouled. I made the pivot block longer to clear this, the guy who gave me the drawings had a similar problem but overcame it by just making a longer boss for the handle.
Clive Hartland | 16/05/2012 22:39:18 |
![]() 2929 forum posts 41 photos | Thats the Badger Jason, and the way I did the job, it turned a few heads as they saw it being done. A bit of three dimensional thinking! Clive |
Tel | 17/05/2012 00:14:13 |
![]() 157 forum posts 28 photos | Over the years I have tried several different designs, but the Steve Bedair design is by far the best IMHO. Here's my version for the Myford Edited By Tel on 17/05/2012 00:15:02 |
David Littlewood | 17/05/2012 00:21:36 |
533 forum posts | Baldric, One difference is that the up and over type will cut concave surfaces; not sure the other one will unless you modify it a lot. This may not of course matter to you.... David |
JasonB | 17/05/2012 07:39:32 |
![]() 25215 forum posts 3105 photos 1 articles | David, see the photo of my Bedair type cutting concave that I posted above, no mod required for small concave but I built it with a double ended holder so it will do large 2" rad concave if needed.
J |
Tel | 17/05/2012 09:42:25 |
![]() 157 forum posts 28 photos | I built two different tool heads for mine to deal with the problem. Too easy! |
Springbok | 17/05/2012 13:13:19 |
![]() 879 forum posts 34 photos | Hi have a look at this bought one a few years works a treat on ebay Item number: 290711057123 Bob |
Springbok | 17/05/2012 13:13:35 |
Springbok | 17/05/2012 13:13:43 |
![]() 879 forum posts 34 photos | Hi have a look at this bought one a few years works a treat on ebay Item number: 290711057123 Bob Ooops managed to post it 3 times Edited By Springbok on 17/05/2012 13:19:30 |
Nobby | 17/05/2012 13:40:08 |
![]() 587 forum posts 113 photos |
Hi
Edited By David Clark 1 on 17/05/2012 14:18:23 |
David Clark 1 | 17/05/2012 14:21:49 |
![]() 3357 forum posts 112 photos 10 articles | Hi David Thay are fine on my computer. I have made the above photo smaller. Has that made a difference to your screen? regards David
Les Jones 1 | 17/05/2012 14:27:35 |
2292 forum posts 159 photos |
Hi Tel, Les. |
