KWIL | 07/10/2010 14:59:48 |
3681 forum posts 70 photos | Does anyone know of a supplier for M2 Hex Headed set screws at least 12mm long? Steel or stainless. |
john swift 1 | 07/10/2010 15:37:10 |
![]() 318 forum posts 183 photos | Hi Kwil ,
I've only found pan head screws so far from rs components , rapid online and modelfixings.co.uk
what are the screws for , and how many do you need ?
John |
KWIL | 07/10/2010 15:58:24 |
3681 forum posts 70 photos | They are to hold two components together under pressure and are to replace 8BA (not directly). They must be Hex headed. 40+ required. Yes I found plenty of pan heads and only one source of hex, but they were gold plated price each!! |
John Baguley | 07/10/2010 16:16:59 |
![]() 517 forum posts 57 photos | Polly Models list M2 x 15mm steel at £3.80 for 25 John |
Keith Long | 07/10/2010 16:38:59 |
883 forum posts 11 photos | Hi Kwil You could try here:- http://www.avonstainlessfasteners.co.uk as well. They list M2 -M36 in both A2 or A4 grade. Phone number is 0117 972 8560. Never had any dealings with them but saw them mentioned in respect of an enquiry for M2 hex head bolt/machine screws on a RCgroups.com forum. Keith |
KWIL | 07/10/2010 17:05:24 |
3681 forum posts 70 photos | Thanks John and Keith, will follow up. |
John Olsen | 07/10/2010 22:08:53 |
1294 forum posts 108 photos 1 articles | There are suppliers on the Continent for such things, at least there were when I went to the Sinsheim show in 2000. I picked up some catalogues there, but they would probably be out of date by now. regards John |
JasonB | 08/10/2010 07:30:36 |
![]() 25215 forum posts 3105 photos 1 articles | This is one of the continental suppliers.
Why are you not making them yourself Ken
![]() ![]() Jason
KWIL | 08/10/2010 09:34:23 |
3681 forum posts 70 photos | To screwcut on that size would need a roller box and I do not have one so small. Please (anyone) do not suggest using a tailstock mounted die!![]() |
Lawrie Alush-Jaggs | 08/10/2010 09:54:06 |
![]() 118 forum posts 32 photos | I made up a load of 10 BA screws in silver steel two weeks ago. Turned the bodies on an old Emco Unimat SL and used the tailstock to get the die flat. After that no problem. |
KWIL | 08/10/2010 10:05:30 |
3681 forum posts 70 photos | Suggestion NOT well received![]() |
V8Eng | 08/10/2010 19:11:53 |
1826 forum posts 1 photos | Have you asked the following suppliers?
Lawrie Alush-Jaggs | 09/10/2010 00:27:34 |
![]() 118 forum posts 32 photos | Ahhhh haaa haaa haaa haa!!!
Every body has a sense of humour. Go Kwil...... |
KWIL | 09/10/2010 10:30:20 |
3681 forum posts 70 photos | ekp is a no, AHC my local supplier does not carry this small. |
Vapeur89 | 09/10/2010 11:30:24 |
18 forum posts | Hi, I buy the micro screws here http://www.micro-modele.fr/tarif_din84.htm Patrick |
KWIL | 09/10/2010 14:03:25 |
3681 forum posts 70 photos | en Francais!! Mais non. |
Terryd | 09/10/2010 15:37:37 |
![]() 1946 forum posts 179 photos | Kwill, pourquoi pas? They list 2mm metric in steel with both standard hex and small hex heads. Most excellent I'd say and reasonable price and postage charges. Terry Edited By Terryd on 09/10/2010 15:38:19 |
KWIL | 09/10/2010 16:36:25 |
3681 forum posts 70 photos | Je naime pas les francais |
Versaboss | 09/10/2010 23:33:49 |
512 forum posts 77 photos | How about German? My friend Tony does not speak English afaik, but his sons do certainly! As I know he has customers as far away as Japan, I think he would deliver to England also Compared to the french supplier, his prices seem to be ok. The stainless screws are turned also. The list is here: Nooo, I give up trying to use this chain button, sorry! http://www.dampfmodellbau.ch/ You have to select 'Preislisten' (left column), then preisliste_schrauben_muttern.pdf
Greetings, Hansrudolf |
Terryd | 10/10/2010 00:07:17 |
![]() 1946 forum posts 179 photos | What a loss just for a bit of Francophobia, never mind. Terry Edited By Terryd on 10/10/2010 00:08:33 |
