Here is a list of all the postings john swift 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Three phase Variac Internal wiring |
15/12/2019 18:28:25 |
Looking at the photos in post 3 it looks like you have something like the 3 phase variac from RS components RS stock number 890-2856
your variac terminals look like this the letters A to E match the RS Components diagram the neutral, if used , going to the star point C1+C2+C3 if you connected your lamp between 1 & 3 (C & E) and it did not work check the winding continuity between 1 & 5 (A & C) and the carbon brush is OK and making contact with the winding
Edited By john swift 1 on 15/12/2019 18:37:34 |
15/12/2019 13:49:44 |
Going by your photo it looks like it the 208 V input had been wired a fixed 89% tap and common input / output to give you a stepped up output of 234V 1.125% out across the total winding
For single phase use I would rewire the transformer to connect your single phase supply to the ends of the winding with the output taken between the common and the wiper (variable tap) you will have 0 to 100% of your mains supply available
add diagram Edited By john swift 1 on 15/12/2019 14:11:58 |
Thread: Help a beautiful lady |
19/05/2019 21:01:18 |
According to their web site Hotter shoes have shops in Liverpool , Llandudno and Chester you could e-mail or call them on 01695 213 213 to check if they have narrow fitting shoes John
Thread: Electronic switch forward/reverse/stop help |
17/05/2019 20:16:31 |
looking at your last photo the original switch incorperates a no volt release ( I expect the black part is a 220/240V coil ) I would of thought the 3 blue cam switch elements may of been wired like this
John |
Thread: E.stop wiring |
09/05/2019 23:58:59 |
The reason I connected the switched live via the E-stop switch to A1 is An accidental short between A1 and neutral or earth will blow the mains fuse
If you had live to terminal 13 and neutral to terminal 23 an accidental short between A1 and neutral or earth would energise the coil when the E-stop switch is open assuming the mains supply is not protected by a residual current circuit breaker
john |
09/05/2019 11:37:32 |
KJD17 E-stop wiring diagram |
Thread: Fuse for "Align" slow motion mill table motor |
01/05/2019 00:19:28 |
yes but , it all will depend on the drive having an interlock that forces you to start at a low speed if you can start a full speed then a 1A fuse will be too low a current - you may need a 4 or 5A fuse using a slow blow fuse will help - for example if the original fuse was a 1A slow blow fuse would be marked T1.0A John
Edited By john swift 1 on 01/05/2019 00:19:52 |
Thread: No volt realese switches. |
13/04/2019 09:44:52 |
looking at photos of the switches the KJD17B has the solenoid connectly to the switched output terminals 14 & 24
the CK21 has only one end of the solenoid connected to the switched output 2 the other end of the solenoid goes to a small 5th terminal you have to connect to switched output 1 this enables you to add one or more normally closed remote E-stop switches use terminals 3 & 4 as the mains input
if you don't need to add any E-stop switches you can use either switch
Edited By john swift 1 on 13/04/2019 09:45:52 |
Thread: Straightening coiled small steam pipe. |
09/12/2018 22:18:28 |
Have a look at how coil feed Escomatic lathes straighten the stock see page 3 https://www.escomatic.ch/media/gallery/machines/d2-d5-flexspeed-e.pdf John |
Thread: DOL starter switch |
17/09/2018 20:00:57 |
Hi Clogs
is this what your looking for https://www.electricalonline4u.com/2018/01/forward-reverse-motor-control-diagram-three-phase.html
John |
Thread: WM18 Earth Fault - Looks like Controller blew |
13/08/2018 21:24:11 |
as the fault was swarf shorting the semiconductors metal tab to the heatsink it looks like the speed control is a copy of KB electronics KBLC-240D (or some thing similar ) KB electronics use devices that have isolated TAB's on the 3 diodes & 2 thyristors ( forming a controlled bridge rectifier ) & does not require the insulator the copies use cheaper devices that don't have isolated TAB's and there for requires the insulator john
Edited By john swift 1 on 13/08/2018 21:32:13 |
Thread: Dangerous Ultrasonic Cleaner Electrical Failure |
27/07/2018 12:02:42 |
I suspect your the second person to look inside ! Some one else has had it apart and not reassembled it correctly
John Edited By john swift 1 on 27/07/2018 12:03:18 |
Thread: DC motors |
19/07/2018 11:36:02 |
It may be possible but it depends on the motors being identical and the mechanical load on the motors being the same
my instinct is to use a 24V supply and a separate speed control for each motor
what are you wanting to do with the motors ? If its some kind of electric vehicle is it possible to have the motors driving the same drive shaft ?
Edited By john swift 1 on 19/07/2018 11:36:58 |
Thread: MEW 270, Ajax Mill |
15/07/2018 18:13:51 |
its missing from the contents page but is on page 60 John |
Thread: Clarke CL 500 switch |
22/06/2018 17:10:53 |
the nearest I have found is this :- http://cdn1.grizzly.com/manuals/g4015z_m.pdf figure 17 on page 21 shows a low resolution diagram do two of the wires have short wires crimped on to make the diagonal connections to the switch ??? if you test the continuity between the 4 wires from the motor I would expect you will find two wires (V1 V2 ) have continuity and they need to be wired across the middle 2 switch terminals
the other two wires (U1 U2) motor wires will go to the start winding that's in series with a capacitor and will connect directly to the mains supply from the NV release switch John
Edited By john swift 1 on 22/06/2018 17:37:53 |
Thread: Speed Controller |
20/06/2018 17:47:22 |
looking at the video link from blowlamp https://m.youtube.com/watch?v=X6CCxv3i4No at 19:59 you can see what looks like the light from a red LED I assume the speed control is controlled by the amount of reflected light from the movable flag / reflector the mod with the graded reflector giving a better range of control as MichaelG says looking up the device part data sheet will make things easier may be its like this Sharp GP2S700HCP https://cdn.sharpsde.com/fileadmin/products/Optoelectronics/Isolation%20Devices/Specs_Photointerrupter/GP2S700HCP_03Oct05_DS_D3-A02201FEN.pdf John Edited By john swift 1 on 20/06/2018 17:47:59 |
Thread: Wiring an NVR switch |
16/06/2018 19:35:55 |
I have found a view of the mechanical latch on another D.O.L. starter when the over load has been reset it holds a normally open switch closed the dial (or on some units a lever ) adjusts the value of current the latch is released when one or more of the bi-metallic stripes are heated by the motor current exceeds the maximum current you have set as the trip current the adjustment of the green knob moves a hinged insulated bar that the bi-metallic strips push on to release the latch
Edited By john swift 1 on 16/06/2018 19:55:12 |
16/06/2018 19:05:41 |
that's the adjuster to set the trip current for the motor you are using
15/06/2018 23:27:03 |
single & 3 phase wiring
john |
Thread: KATSU MINI LATHE |
02/06/2018 13:39:07 |
PS your machine could be like this Warco wm180 - http://andysmachines.weebly.com/variable-speed-controls.html John
