Here is a list of all the postings Vapeur89 has made in our forums. Click on a thread name to jump to the thread.
Thread: James Watt Steam Engines |
18/11/2010 12:00:55 |
Hi, there are free e_books to download form all american libraries (archive.org) . There is a book on boulton and watt here http://www.archive.org/details/livesboultonand00unkngoog you can read it on line or download. For downloading left click on All Files: HTTP then choose the .pdf and right click. Here there is a great listing of books free to download http://www.homemodelenginemachinist.com/index.php?topic=11244.0 May be you can find useful information. Patrick |
Thread: Traction engine tyres |
09/11/2010 17:58:59 |
hi Paul. I think it's a clever idea well worth to try out. I'll forward it to my friend. Patrick |
Thread: Small Metric Screws |
09/10/2010 11:30:24 |
Hi, I buy the micro screws here http://www.micro-modele.fr/tarif_din84.htm Patrick |
28/09/2010 19:27:21 |
Thank's Jason. I'll forward that to my friend . I will also register to TTF. Patrick |
28/09/2010 18:44:36 |
Hi, a friend of mine is building a 2'' Allchin. (using a conversion factor of 32mm for 1'') . You can see his work in progress on his site < http://mbc-usinages.e-monsite.com/ >. at the moment he is looking for methods to produce rubber tyres for the traction engine. Has anyone gained skills in that field or would know any useful link on the subject? Patrick |
Thread: Veteran car models |
11/09/2010 17:48:34 |
HI, may be these links could help This italian museum owns a 1903 De Dion http://www.museoauto.it/home/index.php?option=com_content&view=article&id=47&Itemid=54 French club with an english version of the site http://de.dion.bouton.pagesperso-orange.fr/Accueil_eng.htm English club http://www.dedionboutonclub.co.uk/technical.html This man sells casting may he got a lot of data on de dion http://www.classic-motors.at/descript.htm Patrick |
Thread: Scale model Economy hit & miss engine builders wanted |
28/05/2010 20:25:37 |
Hi you could take a look at http://www.homemodelenginemachinist.com/index.php and place a question after the traditional welcome post It's a very friendly forum with a lot to learn. American machinist are keen on Hit 'n miss engines. I remember a thread on the trouble firing a vertical hit ' miss engine, but I could n't locate it anymore. regards. |
Thread: Imported Lathes - Which one |
01/03/2010 16:06:02 |
In the range of lathe and mill I talked about the variospeed uses a brushless DC motor driven by a microcontroller that computes voltage and chopping the current to stabilize the torque. Sometimes the electric devices blows and it’s not cheap.
The problem is that at low speed you generally need a high torque but with this device the real efficient torque is reduced . More frightening is that at low speed the DC motor is not correctly ventilated on long period. So the good old belt with AC motor is an excellent solution. The torque on the chuck increases as the spindle speed is decreased but your motor is revolving a the same full speed and with a good ventilation.
Generally the mill comes with two gears speed and the problem is solved for speed no lower than 150 rpm.
After a while -if you really need it - you could mount on your belted lathe a 3_phase motor driven by a a professional frequency and torque control device. Need some work and a minimal electrical knowledge. You could keep your belt system in place to have a very large range of speed and torque. Take care not to overspeed the spindle!
If that helps. |
01/03/2010 15:12:44 |
Two years ago I bought a chinese lathe and a mill (Optimachines-Quantum/ D250-400 /BF20 vario) almost like the Chester range (DB-10V /Champion 20V)
I met small problems but the main one was on the lathe (compound slide grooves not parallel!). It took me half a year to understand what was happening. So the main thing is to trust the distributor to replace the faulty parts. There is a large discrepancy of accuracy within the same model and the same brand as the chinese brand is not the maker but uses contractor who uses sub-contractor who ... I’ll say the same for the accessories. Some are incredibly bad. I remember a 4’’ three jaws chuck from Shoba really out of centre . On the contrary I’m very satisfied with my 6’’ Vertex rotary table. Compared with professional machines of the "same" capacity there is an obvious lack of rigidity, mainly torsional, both on lathe and on mill. You have to cope with that.
In fact these machines are not for the absolute beginner as they need a lot of tweaking and care. Even if they are sold under “professional mill” or “expert lathe” labels they are only light duty machines. But in my opinion they performs well enough for the average model engineer. Finally I’m satisfied, I can achieve my goals for a “modest” investment. Surely I won’t buy a second hand chinese lathe nor mill. Patrick |
Thread: 5 inch gauge in France |
27/02/2010 16:08:11 |
Here a good club with an an excellent 5'' and 71/4'' layout. A wokshop with a lot of tools and machining facilities http://www.cmcf-oignies.com/vapeurvive.htm Patrick |
Thread: Proxxon Drill Sharpener |
15/01/2010 18:27:21 |
Hi, I got one and it performs well. It took half an hour to master it following the booklet. Start training with a medium drill 8mm as example, I found it easier. Clearly it is not as accurate as a professionnal drill grinder with collets which is worth £1000. As to me there are only two critical points to manage when sharpening drills: - the angle of each lip with the vertical drill axis has to be dead equal. It's not so important that it is 58.6° or 60.2° - the central chisel has to be straight symetrical and square to the vertical drill axis. The optimum angle is 55° with a plan parallel to the edge of the lips The proxxon seems to fit the bill on this two points. Drills are quite well sharpened. I must admit that under 5mm it' a bit tricky. regards, Patrick |
Thread: Magazine reprints |
15/01/2010 17:59:12 |
Of course for a small 4466.43 Euros you can purchase from issue n°1 to 151 at http://www.abebooks.fr/servlet/SearchResults?sortby=1&tn=%22model+engineer%22&x=0&y=0. More seriously, thanks for the work done Patrick |
Thread: facing a cast iron casting |
15/11/2009 17:37:01 |
I have bench lathe almost like the DB10G from Chester with 1hp motor. To face a large round casting I use carbide indexable tooI with an 1/2'' shank. There are special grade of carbide inserts for roughing if the metal is a difficult one. As to me I never meet problem with hobbyist inserts. After that I check : * that the tool is not overhanging too much from the tool post.The less the better * that the tool is exactly on the lathe axis or slightly under (2 or 3 thou max) Then * I put a slight angle to the tool post (not the compound slide) to be sure that only the tip of the tool is working and the tool's side is not rubing the casting. That way the cutiing pressure is maximum * I lock all the movements : cross slide and longitudinal movement and the compound slide during each cut. * I take light cuts about 0,4mm (1/64'') This way I turned 120mm (4 3/4'') casting for a chuk backplate without problem. The speed was around 300 rpm during roughing and 700 rpm for finishing. With cast iron it's a dirty tedious work. If that can help. Patrick |
Thread: new project |
15/11/2009 16:43:03 |
Thanks a lot for information. Patrick |
15/11/2009 14:11:20 |
Hi, Which method do you use to cut the frame? Could you give me the link to his plan, it looks an interesting project? Have a good day, Patrick |
Thread: Cutting male threads |
14/11/2009 17:35:16 |
Take a look at http://www.gewinde-normen.de/en/index.html Almost all existing thread past and present |
Thread: Metric vs Imperial - Practical or Traditional? |
11/11/2009 13:02:10 |
I’m on the metric side of the hobby and I use either metric or imperial drawings or kits. I have no problems with that. It does’nt take very long to convert from imperial to metric. The reverse is not true if you have to work with imperial fractional. You can download a free professional unit converter at http://www.katmarsoftware.com/uconeer.htm As to what represents a distance... it’s not easier to figure 1 53/64’’ than 46,434 mm. Many times I order stock bars from bristish suppliers as it is a cheaper than in France. To deal with imperial drawings I use exclusively metric holes and metric thread and I convert distances in mm with three decimals. In fact before making chips we have to study and dig into the drawing to understand or to adapt the stock bar we have on hand or to deal with a limited set of tools. So converting is a good starter. The strengh of SI unit system clearly appears when you have to work with complex physics formulas, but as long as only length is concerned why worry about that? |
Thread: HELP HELP HELP - Warco 1224 Gear Head Lathe |
01/10/2009 20:25:13 |
Hi, Sometimes the problem comes from the compound slide after hard work or a dig in. The axis of the compound slide have to be dead parallel to the headstock axis. An error of 0,12° is enough to produce a taper cutting like your’s on a 50mm travel. Don’t trust the 0° setting of the angular dial of your compound slide. To check it’s easy. It’s almost the same as checking general alignement. Loosen sligthly the nuts that lock the rotation of the compound slide. That’s to ease it for further light adjustment. You need to remove the tool post and place a lever indicator with a magnetic base on the compound slide. Then chuck a ground round bar of says ½’’ diameter. Wind the hand wheel to move the compound slide and place the indicator on to the bar as close as possible to the chuck. Lock the longitudinal movement and the transverse movement (cross slide). Set the indicator dial at zero. Now move away at a maximum distance from the chuck with the crossslide handwheel. Note the reading on the indicator. Rewind to go as close as possible to the chuck. Move the chuck by hand to find the maximum deviation of the indicator. Note it. Move away and note the reading Then calculate A= (Near chuck1+Near chuck2)/2- (Awaychuck1-Awaychuck2)/2. With a soft hammer and ligth blows -on the tail of the compound slide reduce or augment the reading on the indicator the reading by A/2. Then check again doing same procedure. After two or three adjustements the total variation will be reduced to a minimum and won’t vary. Tighten the nuts. Check again |
