In search of Peter Rawlinson
Jeff Dayman26/06/2010 19:49:29
2356 forum posts
47 photos
Whatever happened to Mr. Peter Rawlinson? for a long time in the 1990's he was a prolific contributor to MEW and described some very sophisicated bits of tooling including a wire EDM machine.
Did he give up writing, or change hobbies, or go on to write for other publications?
I enjoyed his writings greatly. I could  only aspire to his skills, but always came away with applicable ideas to things I could do. Such a contrast to the "how to drill a hole with a twist drill" type articles seen frequently in MEW today (to say nothing of the endless plugs for Myford - but that's another issue).
JD
Edited By Jeff Dayman on 26/06/2010 19:50:07
Jeff Dayman02/07/2010 20:54:20
2356 forum posts
47 photos
NO ONE reading the forum knows anything about Mr Rawlinson or what happened to him?
JD
David Clark 102/07/2010 21:29:53
3357 forum posts
112 photos
10 articles
Hi There
He asked for his articles back and stopped submitting them.
regards David
Steve Garnett02/07/2010 21:51:49
837 forum posts
27 photos
Jeff, I'll send you a private message with the only info I have - an email address and a phone number... (took 10 minutes to find them, and wasn't that easy...)
And in view of what David said about withdrawn articles, there might be a bit of a clue here from something that Colin Usher wrote:
"Peter Rawlinson is a prolific author/engineer who has built a reputation for producing excellent tool and machine designs. He has now produced a series of books where he has pulled together most of these designs. Volume 1 contains over 20 different projects as diverse as Machining Large Tubes thro’ Laser Alignment to a Mechanical Dividing Head. Volumes 2 and 3 are much the same, each detailing over 20 engineering projects. All designs are complete with excellent CAD drawings and colour photographs. Volume 4 is a compilation of the series of articles that originally appeared in Model Engineers’ Workshop giving complete instructions and drawings for the construction of a CNC Milling machine. This volume also contains details of his CNC Continuous wire eroder together with a brief look at “ G “ code programming.
Whilst these books are primarily intended for the model engineer they will surely find a place on the book shelves of many professional engineers."
Edited By Steve Garnett on 02/07/2010 22:04:02
Jeff Dayman02/07/2010 22:10:58
2356 forum posts
47 photos
Thanks Steve - PM sent to you.
David - do you know what year and month roughly that Peter withdrew the articles and stopped submitting?
Thanks JD
John Stevenson02/07/2010 22:46:30
5068 forum posts
Now that it's mentioned I can remember his doing the print on demand books.
However a quick web search doesn't show anything so unless he's like the best whores and is ex-directory he's making it hard for anyone to buy his product.
John S.
Jeff Dayman03/07/2010 01:44:22
2356 forum posts
47 photos
Posted by John Stevenson on 02/07/2010 22:46:30:
Uh, pardon?
JD
Niloch03/07/2010 09:53:55
371 forum posts
Sounds as if Mr Rawlinson's books would be an education to many of us.  I have no idea whether the author of the following books  is THE Peter Rawlinson but I found the following on Amazon:
Tools to make life Easier
August 2006
ISBN-10:0955373603
ISBN-13:978-0955373602
Temporarily out of stock
Tools to make Life Easy: Band Saw Blade Welder v.5
February 2007
ISBN-10: 0955373646
ISBN-13:978-0955373640
Toos
42 pages
Tools to Make Life Easy: v.5
September 2006
ISBN-10:0955373611
ISBN-13:978-0955373619
Toos
200 pages
The reason for two ISBN numbers hasn't registered on my radar.
Edited By Niloch on 03/07/2010 09:59:50
Michael Ellis 103/07/2010 21:36:17
13 forum posts
The first book listed by Niloch, Tools To Make Life Easier, is by the same Peter Rawlinson. It was mentioned in MEW #118 with contact details. As I recall from the writing in MEW various series, he was developing or had already developed mobility problems. It is quite possible he has dropped out of active engineering model as a result.
ellis
John Stevenson03/07/2010 22:29:05
5068 forum posts
Posted by Jeff Dayman on 03/07/2010 01:44:22:
Uh, pardon?
JD
 Jeff,
Bit of an in-joke.
Apparently all the high class call girls are ex directory, you  have to make contact by recommendation, or so I'm told.
I use this as a stock phrase as my engineering repair business isn't in the phone book either, nor does it have any signs at all, all work comes as recommendation.
John S.
Spencer Brook06/08/2010 08:40:14
2 forum posts
The last article authored by Peter Rawlinson in MEW was in Issue 123 (March 2007) and was on turning large radius items on a lathe.
In the introduction to his article on a "Tailstock Power System" in MEW 110 (November 2005) he gives some considerable detail of why he developed this system - he suffers from Carpel Tunnel Syndrome (a manual dexterity problem) in both hand.
SEGB
DMB06/08/2010 15:34:47
1585 forum posts
SEGB,
Carpal tunnel Syndrome can be operated upon, so given that there is no reason for PR not to have an operation, he could get this fixed - I know another  model engineer who has.
John.
Gray6213/08/2010 22:54:07
1058 forum posts
16 photos
John, beware, CTS occurs in varying degrees and in some cases has varying complications, such as diabetes and arthritis which can preclude efective treatment.
Early diagnosis is also key to effective treatment of CTS. If not detected early enough, permanent damage to the median nerve will preclude effective treatment of the condition.
To make such a bland and overarching statement as you have will only serve to inflame the feelings of suffers of this debilitating condition!! And I speak from experience on this.
Jeff Dayman13/08/2010 23:09:45
2356 forum posts
47 photos
My sympathies go out to all of those with carpal tunnel disease of any sort. I know it is a rough one no matter what the severity.
However I do not want to see the thread derailed off topic. If it does, I will ask moderator to lock the thread.
The subject is Mr. Rawlinson and whether he is writing or working elsewhere. So far I haven't been able to find any current info on how he is or what he is up to, despite leads from several people above. Thanks to them for their efforts.
JD
Tanya Nicholls30/01/2019 01:48:41
5 forum posts
Hi to all.. I believe you are asking about my father who very very sadly passed away on Friday.. hoping for a response from any one on here... about him..
Willem Kotze30/01/2019 09:17:24
17 forum posts
Tanya, My sincere condolences to your family on your loss. I did enjoy his articles very much.
Russell Eberhardt30/01/2019 10:05:48
2785 forum posts
87 photos
Tanya
May I add my condolences. I too used to enjoy his articles and found them inspiring.
Russell
Chris Trice30/01/2019 11:19:04
1376 forum posts
10 photos
I can only add what others have said. There is a certain comfort I think from knowing that he lives on when any of us use what we learnt from him and that his books continue to give joy to their owners when we read his words. To make people smile after one has left is the best way to leave. Sympathy and thoughts for you and your family at this sad time.
ega30/01/2019 11:35:29
2805 forum posts
219 photos
Tanya Nicholls
I was very sorry to learn of Peter Rawlinson's death.
I was friendly with a Jim Smith of Folkestone who knew your father and, frankly, revered him.
Like the others, I very much appreciated his contributions to MEW and his willingness to share his expertise over the phone.
Jeff Dayman30/01/2019 13:47:14
2356 forum posts
47 photos
Hello Tanya, I'm very sorry to hear your sad news. My sincere condolences to you and your family. I started this forum thread back in 2010 when I was considering doing a wire EDM machine. I had not seen anything published by Peter in a long time and I hoped to have an email conversation with Peter about some of the EDM machine details, and perhaps find and purchase a couple of his books. As others have said, Peter's articles were enjoyable reading for many of us and his insights into the technology being discussed were most helpful to those following along and building similar equipment. He was a very skilled man and will be missed by the model engineering world. Best regards Jeff Dayman Waterloo Ontario Canada
Edited By Jeff Dayman on 30/01/2019 13:47:37
