Drill Chuck, Dismantle
Peter Gain29/12/2009 11:27:35
103 forum posts
Does anyone know how to dismantle a Chinese 13mm drill chuck? The chuck is a Jacobs copy. It has some detritus left internally which is now causing it to lock. I seem to recall details of dismantling described in ME(?) or ? but cannot now locate this info.
All suggestions will be welcome.
Peter Gain.
Jim Whetren29/12/2009 12:20:04
50 forum posts
Hello Peter,
First of all; I do not have knowledge of a Chinese copy chuck, but I would like to issue a small warning - Have a good look at it before committing yourself!
I have successfully stripped and cleaned both Jacobs & Rohm chucks, but this is where I cought a cold.
To strip a Jacobs chuck, first line up the tips of the jaws with the end face of the chuck, then find a piece of tube which fits over the rear of the body and abuts the back of the closing ring, it should be long enough to allow the ring to be to be pushed off the FRONT of the chuck. I used a stack of bearing outer races.
With the sleeving of choice in place and a piece of material at the front to protect the face,put the assembly in a vice and press the sleeve off the front of the chuck. Wait for a loud bang as the sleeve is pushed off the split closing nut.
Seperate the nut and remove, but examine the jaws before removal as they are usually marked for position, The teeth end in different places and there are marks in the slots into which each fits.
If this is not so or it all goes wrong, fit the jaws aligned with the end as before and try to fit the nut. If one jaw is sticking out, swap them around until the tips are level and move in and out evenly as you turn the nut with your fingers.
When all is well, use the spacer/s and a piece of material to protect the back and press the sleeve back on. When apart you can see that with the jaws so aligned, the inner ends will clear the sleeve.
Now for the rub, The Rohm chuck has a split nut but it also incorporates the sleeves gear teeth. This means that the sleeve has to be pressed off the gear teeth towards the BACK of the chuck. The Nut/teeth unit is pulled apart and the other instructions apply.
With close examination it should be possible to decide which way to press. Don't do what I did and keep pressing until something gives. I killed the closing sleeve and had to make a new one!
I hope this is of some use to you.
Jim
c29/12/2009 12:44:27
44 forum posts
ME Volume 188 page 352 (17 May 2002), v 155 p 634 (6 December 1985)
Jeff Dayman29/12/2009 13:49:45
2356 forum posts
47 photos
Before dismantling it, I would try soaking it for a few days in white spirit, then gently working the action, then soak, etc. to see if you can get the debris out that way. I have several old chucks that this treatment freed up. After freeing up another soak in light oil gets everything lubed.
Hope it helps.
Jeff
Circlip29/12/2009 14:01:43
1723 forum posts
Try this site guys, straight from the orses maarf :-
  Regards  Ian.
  PS. It applys to Rohm chucks too.
Peter Gain30/12/2009 10:38:55
103 forum posts
Hi,
Thanks to all who replied.
Following your advice I have been able to dismantle the chuck very easily. This is a good example of how an apparently impossible job becomes very easy when one has received the correct instructions!
The internal debris that was causing the chuck to lock was small pieces of the threaded control ring that had broken off from the top part of the thread. This should not have occurred as I never use excessive force such as extension levers or tubes. I only ever use the correct key. The ring appears to have been hardened, presumably over done. The long term answer is to stump up the extra cash & buy EU/USA products. "You get what you pay for" comes to mind. But in fairness, Far Eastern is better than nothing.
Peter Gain.
Mark Smith 316/01/2010 19:21:30
175 forum posts
36 photos
I have a Hawkins drill press you probably won't have heard of as it was made in Christchurch NZ many years ago. My problem is that the chuck needs servicing as it is stiff to operate and doesn't hold the drills securely. It also won't hold drills below 1/8'. I think it is a screw on chuck as there is no slot in the quill and a shaft runs through the pulleys with a long keyway. How do I get it out without breaking something. Once out I should be able to strip it after reading the previous posts.
Mark
chris stephens16/01/2010 23:25:24
1049 forum posts
Hi Mark,
Some drills have the chuck fitted straight onto the drive shaft without a Morse taper in between. Although your chuck may be screwed on, it is more likely to be fitted to a male taper on the end of the driving shaft. The usual way to remove the chuck would be to use a pair of Jacobs type U shaped wedges. You might be able to see if it is a taper by close examination of the top of the chuck area.
I must warn you that I do not know your particular drill, but I do have one that has the chuck fitted as described.
chriStephens
Mark Smith 317/01/2010 03:02:55
175 forum posts
36 photos
Thanks, Chris, I took the bull by the horns and went to the jacobs web site it said to chuck a large allen key in the chuck and whack it. Well it worked. The chuck unscrewed after several whacks. It dismantles easily with a slipring at the back of the chuck. I have stripped and oiled it; it works better now.
Mark
Ian S C17/01/2010 05:33:58
7468 forum posts
230 photos
Hi Mark,If all else fails hit it hard with a big hammer.What size thread,is it 3/8" UNF like a Black & Dekker drill.Ian S C
Mark Smith 317/01/2010 06:27:48
175 forum posts
36 photos
No,Ian much bigger about 18mm dia. anyway problem solved.
chris stephens17/01/2010 14:04:13
1049 forum posts
Hi Mark,
Thanks for the thanks, but I got it wrong. Glad you got it fixed, good old Jacobs to the rescue!
ChriStephens
Geoffrey Morgan 112/02/2010 19:01:54
4 forum posts
Please excuse my lack of proper English, but can someone give me the American equivalent of white spirits.  I am assuming that it is the same as our mineral spirits or Stoddard solvent, which are petroleum based solvents used in regular enamel paints, shoe polish, etc.  Stoddard solvent is a blend of light petroleum distillates developed early in the 20th century by a pharmacist.  At least I know the relationship between paraffin and kerosene.  Many thanks. Geoff M.
Jeff Dayman12/02/2010 19:44:07
2356 forum posts
47 photos
UK white spirits = North America Varsol
russell14/02/2010 23:22:54
142 forum posts
and as far as i can work out, = australian Mineral Turpentine, aka 'turps'...
Ian S C15/02/2010 08:38:41
7468 forum posts
230 photos
russell, white spirits is about half way up the chain between kero and petrol, it'll be the same on your side of the ditch as here in NZ. Ian S C
Frank Dolman15/02/2010 10:42:08
106 forum posts
     Important for use as thinner for paint is the fact that White Spirit
  all evaporates.  Kerosene ( paraffin oil ) leaves a thin oily deposit
   of low lubricity.  This interferes with the drying of paint and is also
   is a nuisance if left in bearings.
     At one time White Spirit was also called Turps Substitute but I
     believe that this is now a dfferent but very similar product.  In
    B&Q, you can often find them on adjacent shelves.
Geoffrey Morgan 115/02/2010 22:42:05
4 forum posts
Thanks to all for the reply concerning the term for white spirits.  Varsol is a particular brand of mineral spirits in the U.S. (I believe Varsol belongs to the progeny of ol' John D. Rockefeller and the Standard Oil Company)  I thought as much, but as is most usual in these cases, I had some doubts.  Varsol is also a variation of Stoddard Solvent.  There may be slight differences as to component mixtures and specific gravities, but they are interchangeably similar.  Primarily used to thin standard enamels (not synthetics) and as a general degrease agent.
As to the actual subject of disassembling drill chucks, I must confess that I have been successful a couple of times as well as rupturing the outer sleeve in at least one case.  Confessions of someone with a hydraulic press and not enough patience!  It has progressed to the point where the replacement parts are almost too expensive and difficult to obtain to make rebuilding worthwhile.  Of course, if one is lucky, there is e-bay and web sites like this one.  Regards, Geoff M.
Peter Tucker16/02/2010 18:34:08
185 forum posts
Hi Geoffrey,
I have heard a mecanic call white sprits "britolite" (not sure of the spelling).   Hope this may help.
Peter.
