Member postings for Jim Whetren
Here is a list of all the postings Jim Whetren has made in our forums. Click on a thread name to jump to the thread.
Thread: Message for Jim Whetren
23/03/2012 01:15:52
James
You have a PM
Jim
Thread: Subscription Expiry
18/03/2012 11:30:20
I only subscribe to MEW but have a date for both ME & MEW.
Is there going to be a change?
Since I subscribed by quarterly direct debit, I have never had a renewal notice.
Jim
Thread: Tool Post ME Article
14/03/2012 10:51:59
Hello James,
The MEW issue you are looking for is:
Issue 132 December 2007.
Jim
Thread: Hobbymat BFE Milling Head
14/10/2011 11:35:18
Hello Mike,
I have sent you a PM
Jim
Thread: ME issue 4270
19/09/2011 16:55:20
Hello Martin,
It would appear that the answer is yes.
I have just renewed my car insurance on line, and the documents were e-mailed as a pdf file.
This was password protected.
Jim
Thread: Copper Rivets
30/03/2011 11:10:30
Vince
If you're really stuck, I have about 85 off x 3/8" long that you are welcome to.
Jim
Thread: bandsaws and vices
31/12/2010 01:53:41
Hello James,
I have the Axminster version of this bandsaw. The camlock vice is, in my opinion, an excellent feature.
I have had my saw for about five years now and wouldn't be without it. I am still using the original blade, but there are better ones available.
A simple means of holding short work pieces with a piece of angle iron appeared in MEW October 2006, I don't have the issue number to hand at the moment. Illustrated is a piece of 3/4" square material stood on end having an 1/8" slice cut off with this method.
Hope this is of some help.
Jim
Thread: issue 171
26/11/2010 13:12:41
It's dry and sunny in the Ancient Isle of Avalon.
No MEW.
This is no surprise as it is a long time since it arrived on the Monday prior to publicaion. It is usually the day before, but it has arrived on the Monday after.
Jim (Glastonbury)
Thread: N.V.R. switch
25/10/2010 11:27:00
Hello Niloch,
I have fitted one of these switches to my ancient Startrite dril which has a single phase motor connected to a 13A plug with three core cable.
The important thing to remember is that the line (live) feed from the plug goes through the emergency stop relay, so the power is cut off at source when you hit the red button.
I have opened up my switch an taken a picture which I will try to add here.
Jim
Thread: How to drill a square hole?
10/08/2010 13:58:57
Hello Alex,
I have been following the thread with interest and was surprised that the Rotary Broach didn't get a mention.
A version of this tool was described by Jock Miller in MEW issue No. 157. It is quite straightforward to make, and the tool bit is easily ground on the most basic of grinding set ups.
Also the chicken & egg problem with making a square hole in the guide bush to produce a tool to make square holes is eliminated.
In the case of the buffer beam, you would just drill a pilot hole the AF size of the square, countersink it to just accommodate the cross corners size of the bit, then position the square in the correct orientation and 'drill' away.
Good luck with it,
Jim
Thread: The HobbyMat BFE 65 again
15/07/2010 11:16:05
Hello Sam,
I don't want to go off on a tangent to what has already been said, but I would like to make an observation.
I have both a Hobbymat mill and a Prazimat lathe from the same East German manufacturer which have some similarities, for instance the large aluminium hand wheels are identical.
The mill motor looks to be a smaller version of the lathe motor. To get to the point, I had a fail to start buzz with my lathe which turned out to be the centrifugal start switch. I found that one of the contacts had disappeared, leaving one contact point and a hole in the end of a contact spring, causing the intermittent contact.
I managed to find some salvaged contacts and removed the contact point and riveted in place. The lathe has been working ever since.
Sorry for the ramble, but it was just a thought.
regards
Jim
Thread: Micrometer ratchet stop
28/06/2010 21:06:25
Hello CoalBurner,
Many years ago I aquired a couple of mikes in pretty much the same state.
I made a replacement pawl for one, and when it was all working, made a duplicate mechanism for the one without.
The re-calibration was a piece of cake, just rotate the scale till it reads zero.
I will check if mine are M & W or Starret, as they are imperial they don't get any use.
Jim
Thread: The HobbyMat BFE65
24/06/2010 19:56:30
Hello Sam,
As you have a milling chuck installed, it is most certainly secured with a draw bar. You will have noticed that the quill splines move down through the driving splines, hence the drawbar can only have a small head, in your case the Allen screw.
As it is unlikely to house a very long Allen screw, my guess is that the draw bar is threaded into the collet chuck at one end and the Allen screw is fastened at the other.
I would remove the Allen screw which may bring the draw bar with it, or if the screw seperates, put it back loose and hit it with a soft drift to release the taper, then remove again and pull the the chuck out bringing the draw bar with it. If you run out of room, at least you can then grip the bar to unscrew it.
If I were going to put it all back, I would permenantly fix the Allen screw and make it a hex headed draw bar.
The gearbox doesn't use oil, the gears etc are packed in grease.
I hope this is of some help, and if I can further assist, please ask.
Jim
24/06/2010 10:03:20
Hello Sam,
It's the second method, remove the large hexagon plug on top of the head and use a piece of 6mm rod.
jim
Thread: Hobbymat MD65 needs assistance to start
31/05/2010 11:46:57
Hello Joe,
Thank you for your kind comments.
As it happens, I did write an article on this mod at the end of March 2008. I presume it is as they say, in 'The Pipeline'.
Watch this space?
Jim
30/05/2010 19:37:48
Hello Mick,
When I bought my Hobbymat mill, it came as the two seperate items - Milling head & Milling table.
The Head included the cast bracket to attach it to the Hobbynat lathe, which I did not need.
Also included were two semicircular plates and associated screws to enable the accurate setting up both left to right and fore and aft. Being a 'pack rat', I still have the plates.
The operating manual included comprehensive instructions for setting the bracket accurately. If it is of use I can look out the instructions, and if they are as I remember them, I can scan them and send them on.
Jim
Thread: Digital editions of Model Engineer and Model Engineers' Workshop.
03/05/2010 11:03:30
Terryd,David & Circlip,
Terry - I should read everything before doing anything! Thank you.
David - I apologise for being a pillock, thank you for your input.
Ian - You are right, today is my birthday, I'm too old for this.....
Thank you all again, I promise to Buck Up.
Best regards,
Jim
03/05/2010 00:52:50
The saga continues -
What's gone wrong with the MEW digital archive? I was going to look at an early issue, but found that the archive only went back to issue 122.
I may be jumping the gun if this is due to the re-scanning of the earlier issues, but if this is not so, then why have I paid £29 for a year's access to the archive?
Jim
Thread: Myford ml7 clutch
02/05/2010 11:55:39
Hello Mike,
I have sent a PM.
Jim
Thread: Pop-up for digital.
23/04/2010 01:31:48
When I suddenly lost access to the digital archive, the only way I could restore it was to disable the control of cookies, pop-ups and mobile control in my internet security suite.
Enabling the pop-up blocker has stopped the pop-up in its tracks.
However, in order to enter text into this reply, everything had to be disabled again. This is strange as it used to work.
