Robin Graham | 18/08/2023 22:06:30 |
1089 forum posts 345 photos | I'm looking to replace the 24V AC 50W halogen capsule lamp on my lathe: It's a horrible lamp. Hard to position, not very bright and the mount attached to the saddle can get in the way for some operations. Lots of possibilities I know, but there might be an advantage in using the existing 24V AC supply. Something I'm thinking about is using a 27W Sealey LED array . This works from a 12-36V DC supply, so I'd need a rectifier. A couple of questions: Q1. I have diodes suitable to make a full wave bridge rectifier myself but don't know how to calculate the appropriate value for smoothing capacitance. Any advice? Q2. Is it nuts to contemplate making something myself? Perhaps there is some off-the-shelf unit which would do what I want? I've looked but so far failed to find, perhaps because I don't know the right search terms. Comments along 'if I were going there I wouldn't start from here' lines also welcome of course! Robin.
Edited By Robin Graham on 18/08/2023 22:07:00 |
Nealeb | 18/08/2023 22:29:46 |
231 forum posts | I needed to replace the 48V light on my lathe - not so easy to find bulbs for it these days, and in any case as I was going to run the machine off a 240-415V inverter anyway the light would only have come on with the motor. I bought a couple of small 12V LED spotlights intended for car bumper mounting. I was able to modify the mountings to fit one of them in the existing shade and reuse the wiring and the support arms. I then removed the 415V-48V transformer from the LoVoLight switchbox and replaced it with a surplus 12V power supply that I think had run an old broadband modem/router. Adequate power for the LED. Gives a decent amount of light. I plan to mount the other one (I think they were about £15 for the pair) to do a similar job on my mill. Cheap but effective. I also mounted the light on the splash guard - could you do something similar with yours? Looks like you already have a small clip-on light on the splash guard? Edited By Nealeb on 18/08/2023 22:31:20 |
Frances IoM | 18/08/2023 22:49:07 |
1395 forum posts 30 photos | personally I'd look in the nearest Lidl as they often have reasonable quality LED lamps with flexible shafts - these can be removed from their heavy bases (usually a lump of concrete in a metal case) and the shaft fitted to a convenient mount fixed eg to the back plate - these lamps come with a 12v supply fed from the ac mains |
Steviegtr | 18/08/2023 22:52:08 |
![]() 2668 forum posts 352 photos | Ebay is awash with machine led lights. I bought 2 for my machines some time ago & they are pretty good & very bright. Have a look at this item No on ebay. There are lots to choose from. Your only drawback is these are 230Volt. Steve. |
duncan webster | 18/08/2023 23:13:47 |
5307 forum posts 83 photos | To answer your initial query, I don't think you need a smoothing capacitor, just run it off the rectifier |
Paul Lousick | 18/08/2023 23:21:50 |
2276 forum posts 801 photos | Run the lathe light from 240V and use a 12V LED transformer for house down lights. Available from your local hardware |
Alan Johnson 7 | 19/08/2023 08:43:18 |
127 forum posts 19 photos | In answer to your original post. If it is "a horrible lamp" dump it and buy something new, but, if you are like me..... recycle, re-use! First question is: does the lamp have a transformer, or is there a switched mode power supply? If it does have a transformer, I will check my 1970's DC power supply textooks and report back.
larry phelan 1 | 19/08/2023 08:57:34 |
1346 forum posts 15 photos | Some time ago Lidl had Led lights for sale for less than 10Euros, I bought two of them for my lathe and mill. They came in two types, one with a base for table use, the other with a clamp for clipping to a shelf. The latter type is simple to fit to your lathe and the light is both bright and easy to focus. Like you, I had/have two of those horrible lights, now consigned to the dark corner of my cave. The Lidl lamps operate from a plug-in transformer, not a problem as I found, so, might be worth while looking out for them. Just a thought ! |
Mike Poole | 19/08/2023 09:14:57 |
![]() 3676 forum posts 82 photos | Posted by duncan webster on 18/08/2023 23:13:47:
To answer your initial query, I don't think you need a smoothing capacitor, just run it off the rectifier You may experience strobe effects with unsmoothed DC, fluorescent lighting is also a strobe risk but most of us use it in the workshop without having a problem. Being aware of the possibility is probably enough to avoid grabbing hold of a rotating job that appears stationary. Mike |
noel shelley | 19/08/2023 10:06:53 |
2308 forum posts 33 photos | I used an LED floodlight on a 24v transformer and rectifier - it flickered so I used the first cap that was to hand 1000uf at 50v that stopped it ! Noel. |
John Doe 2 | 19/08/2023 10:16:44 |
![]() 441 forum posts 29 photos | Without smoothing, your LED light will switch off every half cycle, so it will flicker, perhaps not noticably, but might cause dangerous strobing effects. My copy of Horowitz and Hill is packed away, so I had to ask the Internet: Quote: "[A good approximation for a 6.5A supply is given by:] C (filter capacitor) = i (load current in Amps) x t (period of the rectified AC) x 1,000,000 (conversion from farads to uF) / E (ripple voltage)
Unquote In your case, you will need to know the current drawn, (very little), and the voltage at which your LED light extinguishes, so as to work out an acceptable ripple voltage, in order to calculate a capacitor size. Or forget 24V and fit one of these into your housing, (And fix the base of the lamp to the wall behind if it is getting in the way mounted on the lathe). These lights are brilliant, very bright, sealed, so no swarf or dust can get into the light itself, and are powered directly from the mains, no PSU block needed. (These might flicker though, mine are used as down-lighters in the bathroom and I have no way of checking): Edited By John Doe 2 on 19/08/2023 10:22:30 |
Robert Atkinson 2 | 19/08/2023 10:37:17 |
![]() 1891 forum posts 37 photos | To answer the question : For your Sealy 27W lamp the current draw will be over 1A so you need a 1.5A or greater bridge rectifier. I'd suggest a 2 or 3A item. If using individual diodes to make a bridge then you can use 4 x 1A diodes like 1N400x series. This is because each diode is only carrying current 1/2 the time. Hope this helps. Robert.
Edited By Robert Atkinson 2 on 19/08/2023 10:38:34 |
John Doe 2 | 19/08/2023 10:50:38 |
![]() 441 forum posts 29 photos | I have just used a variable speed battery hand drill held under one of the down-lighters I referred to above: There is some strobing detectable at certain speeds, but it is quite mild. I don't think it would be enough to "freeze" a piece that was mounted in a lathe chuck, making it appear stationary, but just to warn you. |
SillyOldDuffer | 19/08/2023 11:04:33 |
10668 forum posts 2415 photos | Posted by John Doe 2 on 19/08/2023 10:16:44:
Without smoothing, your LED light will switch off every half cycle, so it will flicker, perhaps not noticably, but might cause dangerous strobing effects. ...Just a guess because the description of Robin's Sealey lamp doesn't say so, but it claims to operate from a 10V to 30V DC supply. The input voltage range implies the lamp contains a some sort of electronics, perhaps a constant current power supply, in which case it may not need any smoothing at all. My main concern with powering it from 24VAC and a rectifier is that the peak DC output is nearly 34V, which might result in the lamp having a short life. (The blurb says 10V to 30V, not 10V to 36V) Unfortunately the spec doesn't say how much current the lamp draws. However, 27Watts is probably the light equivalent, not the actual power consumption. As LEDs are abut 10x more efficient than Halogen, I guess the lamp consumes 2 or 3 watts, say 100mA, not enough load to stop a beefy 24VAC supply rated to run a halogen lamp charging a big capacitor up to 34V. The lamp costs £18.60. I'd either:
How long a slightly over-volted LED lamp will last is anyone's guess: I suspect it will be OK. As the lamp is moderately expensive, I'd fit a dropper resistor. This stuff is much easier if you have a mutlimeter and oscilloscope because a few simple measurements remove most of the guess work. Dave |
John Doe 2 | 19/08/2023 12:47:09 |
![]() 441 forum posts 29 photos | Yes, sorry, I did specify "without smoothing" in my reply. If the lamp in question has some sort of smoothing or regulator built-in, it might be OK as a stand alone - I was assuming a basic LED lamp without. As you say, hard to be sure unless one has a 'scope or a circuit diagram.
PS, the down-lighters I mentioned above are £10.95 + VAT each, and don't need any other components. Edited By John Doe 2 on 19/08/2023 12:47:45 |
Maurice Taylor | 19/08/2023 13:08:33 |
275 forum posts 39 photos | Hi Robin ,if you’ve got an old type car battery charger (consists of transformer and rectifier giving about 17 volts),you could try your new lamp on this . If it works ok, add your rectifier to your 24volt supply. Maurice Edited By Maurice Taylor on 19/08/2023 13:21:52 |
Robert Atkinson 2 | 19/08/2023 15:06:54 |
![]() 1891 forum posts 37 photos | The light rating is 27W input power so 1-3Acdepending on voltage. Clearly intended for vehicle use confirmed by the R10 approval. It must have a built in regulator to work over this voltage range. While the peak voltage of 24V AC is out of the noinal range of the lamp, as mentioned by SOD, the loaded average votage is probably OK. To be safe just use half wave recification (1x 3A or higher rated diode) and a larger smoothing capacitor, say 1000uF or 2200uF 35V. Robert. |
Robert Atkinson 2 | 19/08/2023 15:15:56 |
![]() 1891 forum posts 37 photos | Posted by Steviegtr on 18/08/2023 22:52:08:
Ebay is awash with machine led lights. I bought 2 for my machines some time ago & they are pretty good & very bright. Have a look at this item No on ebay. There are lots to choose from. Your only drawback is these are 230Volt. Steve. The lamp pictured is not compliant with UK regulations. Additionlly a metal bodied lamp with a two core mains lead is problematic. The 220V rating ia also incorrect for UK. I'd need to examine it but I bet it has multiple safety issues. Note that despite being UK stock the contact info is in China so good luck with support or getting your money back. Robert |
Robin Graham | 19/08/2023 22:56:14 |
1089 forum posts 345 photos | Thanks for replies, all read attentively and (more or less) digested. Posted by Robert Atkinson 2 on 19/08/2023 10:37:17:
Thanks Robert, that's exactly what I was hoping for - a 'rule of thumb'. I have the diodes and some 1000uF 50V capacitors in my 'bits box' so I can lash something up and see how it performs. John Doe 2 - I came across the formula you quoted (or something very similar), plugged in some numbers (guesswork) and came out with 450,000 uF. Obviously ridiculous, but not being sure which piece of 'garbage in' led to this 'garbage out' I gave up and posted. SoD - yes, 10-30V not 36V. Not sure what happened there! Thank you for your suggestion of using a resistor to drop the peak voltage. I think I have a box of 5W resistors somewhere. I have an oscilloscope so now I have a reasonable value for the smoothing capacitor I can build a simple circuit and see what happens. Alan Johnson 7 - it's a transformer. Until I started investigating this I hadn't realised that there is 240/24V transformer which is always energised when the lathe is switched on at the mains plug. It seems to run all the switchgear (interlocks etc) as well as the light. It takes only a few Watts when quiescent so has probably only eaten about £50 over the 5+ years the lathe has been left on at the wall 24/7. Maybe it's simpler to junk the 24V lamp and go for something mains powered but I wanted to explore possibilities and learn something along the way. Robin.
Robert Atkinson 2 | 21/08/2023 07:49:52 |
![]() 1891 forum posts 37 photos | Low voltage lamps were used on machine tools and as inspection lamps fpr two reasons: Care is needed when buying low cost mains powered machine lights (or making our own). Even just looking at the photographs of many on ebay show they do not comply with UK safety regulations and probably are not safe in practice. Nor having a proper UK mains plug and only two core cable are big red flags. Robert. |
