Greensands | 17/03/2023 19:27:09 |
449 forum posts 72 photos | Hi all - Can anyone provide a link to a suitable units conversion calculator., specifically, converting thous/inch to microns/metre. The sites I have discovered appear to be limited to straight forward unit to unit conversions as opposed to a unit/unit to unit/unit conversion. |
John Haine | 17/03/2023 19:37:01 |
5563 forum posts 322 photos | What's the difference? Just use the calculator on your phone or computer. Exactly 25.4mm in an inch, everything flows from that. |
DC31k | 17/03/2023 19:58:50 |
1186 forum posts 11 photos | Posted by John Haine on 17/03/2023 19:37:01:
Exactly 25.4mm in an inch, everything flows from that. How does that come into play? Thous per inch is dimensionless. There are 1000 thous in one inch. Thus one thou per inch is a _ratio_ of 1 in 1000. Microns per metre is also dimensionless. There are one million (10^6) microns in one metre. So 1000 microns per metre would be the same ratio of 1 in 1000. |
Tony Pratt 1 | 17/03/2023 20:32:50 |
2319 forum posts 13 photos | As John Haine says, use a calculator, let’s not make this complicated folks, unless I’m missing something? Tony |
JasonB | 17/03/2023 20:41:19 |
![]() 25215 forum posts 3105 photos 1 articles | Does it really need a calculator, as DC31K says you should be able to multiply by 1000 in your head but first hit on google gives a calculator where you can fill in the first box and get result in the second
Peter Greene | 17/03/2023 21:09:58 |
865 forum posts 12 photos | One of my favourite conversion sites (there are so many) |
DC31k | 17/03/2023 21:13:21 |
1186 forum posts 11 photos | I do not think I said anything about multiplying in anyone's head. My comment was more to point out the irrelevance of 25.4 to the problem in hand. It is not answering his original question, but it just struck me that there is a one-to-one correspondence between thou per inch and microns per MILLIMETRE. The same one to one correspondence is between thou per inch and millimetres per metre. |
JA | 17/03/2023 21:35:30 |
![]() 1605 forum posts 83 photos | My conversion calculator is now a slide ruler, very quick and, generally, quite accurate enough. Somethimes the old ways are still good. JA Edited By JA on 17/03/2023 21:36:28 |
JohnF | 17/03/2023 23:41:17 |
![]() 1243 forum posts 202 photos | Really cannot see the problem and why the controversy from John Haine's post 1/25.4 = .039370078740157 thus for general workshop use use 0.03937 and multiply your mm to get inches or divide your inches to get mm -- simples ! If you want or need microns then use the whole conversion factor. John |
duncan webster | 17/03/2023 23:52:21 |
5307 forum posts 83 photos | OP question was how to convert from thous per inch, which is dimensionless, to micron per metre, which is similarly dimensionless. As 1 micron is a millionth of a metre, 1000 microns per metre is the same numerically as 1 thou per inch, no calculation required apart from multiplying by 1000. I must admit to wondering what on the scale of metres needs measuring to microns |
Bazyle | 17/03/2023 23:59:58 |
![]() 6956 forum posts 229 photos | Perhaps the op has expressed his problem in too simple a manner for us to understand his dilemma. Maybe he has a to make a component with a taper expressed as say 20 thou per foot and his mill is all metric so he just can't get his head around how to set it up. |
JasonB | 18/03/2023 07:16:25 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by DC31k on 17/03/2023 21:13:21:
I do not think I said anything about multiplying in anyone's head. No it was the fact that the conversion was a factor of 1000 which you said, so should not require a calculator to convert eg 367thou/inch = 367,000microns/meter
If the question had been how to convert thou to microns then yes a calculator and 25.4 come into play but that is not what teh OP seems to be asking. "The sites I have discovered appear to be limited to straight forward unit to unit conversions as opposed to a unit/unit to unit/unit conversion."
Here it is entered into that online calculator I posted yesterday as you can see just multiply the imperial by 1000 which should be possible in your head
Or if you want to do it long hand you can see that the answer is 1000 times larger than the original imperial value So as a practical example if the OP has a Taper as Bazyle suggests of say 367thou / inch (0.367/1) then in metric that would be 367,000microns / meter or 367mm / meter. or 0.367m / m which sounds rather like the imperial length/length we started with. Plot it on CAD if you need proof that the angle is the same.
Edited By JasonB on 18/03/2023 08:03:37 Edited By JasonB on 18/03/2023 10:01:38 |
Howard Lewis | 18/03/2023 08:06:36 |
7227 forum posts 21 photos | Why make life complicated when it isn't? If you want a ready to hand conversion chart, set up a matrix. One for thous to mm and another for mm to thous, with say Tens along the top and units down the side. The cells in the matrix will have all been calculkated using the factor 25.4 You can either do each calculation with a calulator (Many have the facility to set the factor as a constant to make it simpler ) or make up a spreadsheet in EXCEL Having got the numbers in the cells, print off and ideally laminate so that it stays wipe clean. If the dimensions you wish to convert are larger, find a suitable number and mulktiply nthe result by 10. That should make conversions at a glamce. Howard. typos corrected- I hope! Edited By Howard Lewis on 18/03/2023 08:08:41 |
Paul L | 18/03/2023 08:42:59 |
![]() 87 forum posts 26 photos | I find this covers almost everything i need https://www.rapidtables.com/
Chuck Taper | 18/03/2023 08:57:18 |
![]() 95 forum posts 37 photos | Posted by Greensands on 17/03/2023 19:27:09:
If (and only if) you use an iPhone/iPad you might try PCalc, available at the App Store. Technically orientated with many useful features and functions. Your mileage may vary. Frank C. Edited By Chuck Taper on 18/03/2023 08:58:25 |
Hopper | 18/03/2023 09:01:53 |
![]() 7881 forum posts 397 photos | Posted by Greensands on 17/03/2023 19:27:09:
Hi all - Can anyone provide a link to a suitable units conversion calculator., specifically, converting thous/inch to microns/metre. The sites I have discovered appear to be limited to straight forward unit to unit conversions as opposed to a unit/unit to unit/unit conversion. Well, Jason has already provided the info on how to find it, but here is the specific link REQUESTED LINK Type in your thous per inch at the left and the answer will appear on the right in microns per metre. Easy peasy.
Edited By Hopper on 18/03/2023 09:05:22 |
Martin Kyte | 18/03/2023 10:06:38 |
![]() 3445 forum posts 62 photos | The OP is strangely quiet? regards Martin |
Greensands | 18/03/2023 10:15:31 |
449 forum posts 72 photos | To answer Duncan Edwards question. I have a Heidenhain DRO display unit Model VRZ 760B which makes provision for various parameteric corrections e.g. Linear Error Compensation on X, Y and Z where values to be entered are expressed in terms of microns/metre. Thanks to all who provided assistance |
John Reese | 21/03/2023 21:51:37 |
![]() 1071 forum posts | There are a number of phone apps that do unit conversion. I use Jo Shop Pro. |
