Rowan Sylvester-Bradley | 31/01/2023 13:23:47 |
88 forum posts | I need some rectangular PVC white tube, say 20 x 40mm, or 25 x 50mm for a construction project I'm working on. I can't find anyone in UK who can supply this, But surely this must be available? I can find end caps for it, which surely means that the tube must exist? Can anyone suggest where I might get this? Thank you - Rowan |
David Millar 3 | 31/01/2023 13:31:36 |
28 forum posts | Hi Rowan,
would electrical trunking suit?
David |
John Rudd | 31/01/2023 13:34:29 |
1479 forum posts 1 photos | Posted by Rowan Sylvester-Bradley on 31/01/2023 13:23:47:
I need some rectangular PVC white tube, say 20 x 40mm, or 25 x 50mm for a construction project I'm working on. I can't find anyone in UK who can supply this, But surely this must be available? I can find end caps for it, which surely means that the tube must exist? Can anyone suggest where I might get this? Thank you - Rowan So if you can obtain the end caps, maybe ask the supplier if they can supply matching tube or recommend a source? |
Bizibilder | 31/01/2023 13:43:34 |
![]() 173 forum posts 8 photos | Are you sure the end caps are for plastic tubing? it sounds like they may be for steel tube as used in desks and tables etc. |
David George 1 | 31/01/2023 13:46:20 |
![]() 2110 forum posts 565 photos | Try these for 25 x 50 https://www.mkmplastics.com/shop/plastic-square-tubing No connection but it seems expensive. £340.50 for 25 3mtr lengths. David |
Journeyman | 31/01/2023 14:48:51 |
![]() 1257 forum posts 264 photos | Could try TP Extrusions John Edited By Journeyman on 31/01/2023 14:50:31 |
bernard towers | 31/01/2023 15:31:37 |
1221 forum posts 161 photos | The end caps that are available may be targeted to steel sections eg table legs /chair legs |
Bazyle | 31/01/2023 15:50:04 |
![]() 6956 forum posts 229 photos | Or the end caps may be repair items for imported plastic furniture. Could you get square drainpipe and cut and glue it? |
Rowan Sylvester-Bradley | 31/01/2023 16:21:03 |
88 forum posts | Posted by bernard towers on 31/01/2023 15:31:37:
The end caps that are available may be targeted to steel sections eg table legs /chair legs Yes, I recognise that the end caps that I have seen may be intended for metal tube. Rowan |
Rowan Sylvester-Bradley | 31/01/2023 16:24:29 |
88 forum posts | Posted by Journeyman on 31/01/2023 14:48:51:
Could try TP Extrusions John Edited By Journeyman on 31/01/2023 14:50:31 TP Extrusions seem only to make tube to order, which means they have massive minimum order quantities. Sinclair and Rush only make small tube, max size 23 x 11.5mm This is not large enough for what I need. Any other ideas? Thank you - Rowan |
Rowan Sylvester-Bradley | 31/01/2023 16:26:15 |
88 forum posts | Posted by Bazyle on 31/01/2023 15:50:04:
Could you get square drainpipe and cut and glue it? I suppose I could try this, but it would make the job much more complex than it needs to be if I could find the right size tube. Thanks - Rowan |
Rowan Sylvester-Bradley | 31/01/2023 16:28:07 |
88 forum posts | Posted by David George 1 on 31/01/2023 13:46:20:
Try these for 25 x 50 https://www.mkmplastics.com/shop/plastic-square-tubing No connection but it seems expensive. £340.50 for 25 3mtr lengths. David They only seem to supply these massive quantities, which is not cost effective for me (I only need about 2m of tube). Thanks - Rowan |
Rowan Sylvester-Bradley | 31/01/2023 16:30:42 |
88 forum posts | Posted by David Millar 3 on 31/01/2023 13:31:36: would electrical trunking suit? No, I don't think it would. I think the opening side would make the finished contruction much weaker. I suppose I could just glue the lid shut. But in most cases that I have seen the trunking is not truly rectangular, so it wouold be much more difficult to cut and glue accurately. I think I've got to find just plain rectangular tubing. Thanks - Rowan |
Jeff Dayman | 31/01/2023 16:33:13 |
2356 forum posts 47 photos | Some sizes are available here in North America, see link below. Multiply inch sizes by 25.4 for mm conversion https://www.mcmaster.com/pvc-rectangular-tubing/ |
Michael Gilligan | 31/01/2023 17:19:22 |
![]() 23121 forum posts 1360 photos | The second link by Journeyman looks ideal to me: **LINK** https://www.sinclair-rush.co.uk/categories/tubes-bars-rods/plastic-box-section-square-tubes/ MichaelG. |
Rowan Sylvester-Bradley | 31/01/2023 17:36:45 |
88 forum posts | Posted by Michael Gilligan on 31/01/2023 17:19:22:
The second link by Journeyman looks ideal to me: **LINK** Form their web site the largest rectangular size they have is 23 x 11.5mm, which is too small for me. They supply larger square sizes, which I may have to go to if I can't find rectangular, but their mimimum order qty is £24 which is more than I was hoping to spend. Thanks - Rowan |
Steve Skelton 1 | 31/01/2023 17:46:52 |
152 forum posts 6 photos | Rowan, try searching for "PVC batten" you may find what you are looking for. Steve |
Michael Gilligan | 31/01/2023 18:25:44 |
![]() 23121 forum posts 1360 photos | Posted by Rowan Sylvester-Bradley on 31/01/2023 17:36:45:
. Having no idea what it is that you are wanting to build; it is obviously unreasonable of me to comment, but: I would be tempted to consider using pairs of 25x25 in place of 25x50 MichaelG. |
peak4 | 31/01/2023 19:02:32 |
![]() 2207 forum posts 210 photos | Does it have to be plastic? |
Rowan Sylvester-Bradley | 31/01/2023 19:20:21 |
88 forum posts | Posted by Steve Skelton 1 on 31/01/2023 17:46:52:
Rowan, try searching for "PVC batten" you may find what you are looking for. That was a good suggestion, but despite fairly thorough searching, I still haven't been abkle to find what I am looking for. So still looking, and would still welcome any suggestions. Thank you - Rowan |
