Member postings for David Millar 3
Here is a list of all the postings David Millar 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: Long span shelving - support material
30/05/2023 11:51:22
My very rough, back of an envelope, no responsibility implied or offered, gives a circa 6mm deflection on 3 no. 50*50*3mm SHS, 3m long, carrying 67kg per metre.
Thread: Where to get rectangular PVC tube
31/01/2023 13:31:36
Hi Rowan,
would electrical trunking suit?
David
Thread: an Oil-Tank Monitoring puzzle : Domestic Heating
28/11/2022 10:45:23
Is the solution somehow "baffling"?!
Thread: Oil Tank
22/11/2022 11:25:29
Would a small ammo box work? They're about 150x150x300 but the orientation may be wrong.
David
Thread: HBM 250-550 Lathe Tooling
13/07/2022 18:19:09
Thanks Guys.
Great advice from all and it's got me moving forwards.
13/07/2022 11:48:22
Thanks all.
I'll go with 10mm to start with. As mentioned above, they will fit with shims and will always be useful.
I may try 12mm in the future but I'll start with 10mm.
Thanks again.
David
13/07/2022 09:56:43
Thanks Andrew
That makes sense.
13/07/2022 09:28:05
Hi There,
I've recently acquired a new (to me) HBM 250-550 lathe.
It came with a miss-match of assorted tooling ranging from 6mm to 12mm.
The manual I've downloaded lists optional extras, including a set of 10mm tooling.
I've compared the 12mm tool to a centre mounted in the tail stock. The cutting edge is very slightly lower than the centre. A shim of drinks can aluminium under the tool looks like it would bring the cutting edge up to centre. This is only based on trying the single 12mm tool available.
My questions are, should I go for 10mm or 12mm tooling? Does anyone have a HBM 250-550, and if so, what do you use?
Kind Regards
David
Thread: Replacing a 24V AC machine lamp
18/06/2022 22:30:40
I recently replaced the lamp holder in my bathroom fan with integrated light. The lamp holder looked identical to the pic the OP posted.
I sourced a replacement from a local electrical trade wholesale outlet.
I had presumed it was 12V but didn't look closely at it. It may be 24V.
David
Thread: April questions---for one day only.
01/04/2022 16:49:35
Does steel wool come from hydraulic rams?
Thread: 46mm tube
29/03/2022 17:40:13
Scaffold tube is 48.3mm with about 3-4mm wall thickness. Could you turn that down?
Thread: What is this?
21/03/2022 17:21:40
It looks like part of a fishing float but not sure if you'd use that "professionally"!
Thread: Are standard "M4" nuts & bolts normally fine or course pitch?
14/01/2022 09:48:24
I use "The Cat Sat On An Orange And Howled Horribly" laid out in a 3x3 grid
TCS
OAO
AHH
Thank you Mr Short of Mortimer Comprehensive School!
Thread: New member from Ireland
03/05/2021 16:27:54
Hi Steve. Good to hear from you. I'm based in Skerries so it sounds like we're in the same neck of the woods! I'm new to all this and in the process of building a workshop. I have an old mini lathe which I picked up about 20 years ago in the UK. I've played with it but want to become more skilled. I've recently picked up a mini mill (in Ireland) but it took a long time watching the likes of ebay, facebook market place and donedeal.
Anyway, all the best and give me a shout if I can help in anyway. My mill is likely too small for your needs but you're welcome to use it if it did.
David
Thread: How to align a fixed steady?
04/02/2021 09:56:54
Hi Philip.
I've never used one either but I watched a doubleboost video on youtube yesterday where John set one up.
He mounted the work in the chuck, set the steady around the work piece, close / adjacent to the chuck. Adjusted the steady so the fingers just made contact with the work piece. Then moved the steady to it's desired location. The logic being that the workpiece and chuck would be very close to concentic close to the work piece and errors increasing as you move away from the chuck.
Thread: Swinden Vice Problem
02/02/2021 19:25:56
Hi all. Just to give you an update. I didn't have easy access to a die do I spent an hour dressing the problem area of the thread with a flat hand file and it seems to have done the trick. It's 99% as it should be. Runs freely apart from slight resistance over about 1/4".
I identified the problem area by screwing into the "captive nut" section until I felt resistance then backed the thread back out again to dress it then tried advancing it again.
I couldn't see much wrong with the thread but there must have been something!
Thanks again to you all! Much appreciated.
30/01/2021 08:33:34
Thanks for that John. I'll have a close look as I strip it down. I hear what you say about, if it was stretched, the thread being out of phase beyond the streched area. That doesn't seem to be the case. The thread is tight over an inch or two, then runs freely again. Perhaps the thread profile has been damaged rather than stretched.
Food for thought!
Thanks to you all. I'll let you know how I get on.
28/01/2021 19:25:36
Thanks all. That'll be a nice lockdown project
28/01/2021 17:57:28
Thanks Jeff. I'll check that when I strip it down.
28/01/2021 17:17:44
Thanks Howard. I guess I've got nothing to lose from trying to recut the thread. I'll give that a go.
Thanks to you both.
