Peter Simpson 3 | 19/01/2023 17:08:08 |
122 forum posts 2 photos | Hi All, I have just purchased a Colchester Bantam. The lathe is sitting on heavy duty castors at the moment. What are the views on lathes on castors ? Would the lathe be stable enough even with the castor brakes been on ? |
peak4 | 19/01/2023 17:18:16 |
![]() 2207 forum posts 210 photos | No experience of a Bantam on castors, but do use them on other machines. |
Nigel Graham 2 | 19/01/2023 17:18:50 |
3293 forum posts 112 photos | It would probably be stable, but only if all 4 castors are taking their share of the load on a solid floor. |
Baz | 19/01/2023 17:27:02 |
1033 forum posts 2 photos | On the plus side it has raised the lathe up, Bantams are quite low and working one for a day will give you backache. I have a Bantam 1600 of about 1965 vintage and have raised it up on two lengths of four inch square fence post. I am not sure I like the idea of all that weight on castors, I presume the casters are fixed through the bolting down bosses, if it were me I would want the casters mounted on some outrigger to take the caster outside the machines footprint, if you have ever seen a lathe with an out of balance job on a faceplate rocking about you will realise how easy it is to tip one over. |
Andrew Tinsley | 19/01/2023 17:27:52 |
1817 forum posts 2 photos | I use castors that have a screw down foot. So best of both worlds, very stable when all four feet are screwed down and easily moved by screwing up the feet. Andrew. |
John Haine | 19/01/2023 18:08:40 |
5563 forum posts 322 photos | I put my S7 on casters so I could move it out to fit a new 3ph motor. The ones shown in the photo above on a Myford are very similar. I can't say that the whole experience was stress free, and whilst on casters the lathe felt very unstable. I can imagine one trying to run over a small bit of metal on the floor and tripping up the lathe with disastrous consequences! |
Clive Foster | 19/01/2023 18:33:40 |
3630 forum posts 128 photos | You need some pretty serious castors if a lathe is to be stable at rest and move any sense. The small heavy duty ones used on pianos and similar aren't up to it whatever the load rating may say. I put 6 big, screw down, ones with 5" diameter wheels on my P&W Model B hoping to make it easier to move from gate to workshop and into place.. Lathe was about a ton, castors rated about a ton and a half each so it ought to have worked OK. In practice it barely worked. Possibly a bit less faffing then roller or skates but certainly harder moving. These days I'm a fan of sliding on steel rods laid rail fashion. Diameter in the 1/4" to 1/2" range works OK without major jack up issues to get the rods under. Using like a rail gives the machine a smooth surface to slide on so no tripping over small stones, ridges or tamping marks. Clive |
Chris Pearson 1 | 19/01/2023 18:40:43 |
189 forum posts 3 photos | I cannot see the point. You would have to level the lathe every time that the castors are used. I once tried moving a bandsaw on castors which were supposed to be suitable for the load - they lasted about 6 feet. In the end, I "borrowed" the ones under a large Snap-on tool chest. |
Rod Renshaw | 19/01/2023 18:45:08 |
438 forum posts 2 photos | I wonder about the "levelling" of the lathe for accurate parallel turning, would this have to be done again after each move? Rod Sorry, did not see previous post while I was typing mine. Edited By Rod Renshaw on 19/01/2023 18:46:10 |
Phil super7 | 19/01/2023 18:59:10 |
24 forum posts | I would serious worry about using a lathe on castors, when a faceplate was being used and out of balance. Also when I was an apprentice i cannot recall any lathe being on castors, they were all secured to the floor. |
Peter Greene | 19/01/2023 19:06:06 |
865 forum posts 12 photos | Posted by Chris Pearson 1 on 19/01/2023 18:40:43:
While I don't use castors anyway, as far as I recall I only ever approximately levelled my ML7 and It's done everything I ever wanted. I would bet there are many others here with similar experience. I don't decry people who feel that way and want to get everything aligned to a wavelength of blue light or whatever the standard is - more power to them. But horses for courses. |
Bazyle | 19/01/2023 19:50:34 |
![]() 6956 forum posts 229 photos | Seems a waste of good castors. Are you really moving the lathe every week? If you do maybe put 2 non swivel wheels at the tailstock end well spaced apart and a cunningly positioned bracket at the headstock end. When you need to move it pop your trolley jack under the special bracket to lift up that end, or the type of crowbar with two little wheels used by pro movers. |
Dave Halford | 19/01/2023 21:05:32 |
2536 forum posts 24 photos | Posted by Rod Renshaw on 19/01/2023 18:45:08:
I wonder about the "levelling" of the lathe for accurate parallel turning, would this have to be done again after each move? Rod Sorry, did not see previous post while I was typing mine. Edited By Rod Renshaw on 19/01/2023 18:46:10 No It's different levelling or lathes on ships wouldn't work |
Chris Pearson 1 | 19/01/2023 21:23:10 |
189 forum posts 3 photos | Posted by Dave Halford on 19/01/2023 21:05:32:
It's different levelling or lathes on ships wouldn't work Well, they don't. Yes, they may be accurate enough for some purposes, but the deck cannot be guaranteed to remain true. I distinctly remember raising this point when I first went to sea in 1990. |
Martin Kyte | 19/01/2023 21:34:21 |
![]() 3445 forum posts 62 photos | Oh I wish we hadn’t inherited the phrase levelling a lathe. All is required is that its mounting does not induce a twist to the bed. You could screw it to a wall if you liked with the bed vertical and get it turning parallel. regards Martin |
Phil super7 | 19/01/2023 21:41:45 |
24 forum posts | Martin I agree, Consider Lathe's with a slant bed. |
Martin Kyte | 19/01/2023 21:52:58 |
![]() 3445 forum posts 62 photos | Posted by Phil super7 on 19/01/2023 21:41:45:
Martin I agree, Consider Lathe's with a slant bed. That’s almost biblical. Consider the lathes of the slant bed, they turn neither taper nor bellied, yet even these be not levelled. 😊 |
Paul Janes | 19/01/2023 22:09:38 |
23 forum posts 3 photos | I agree with " I wish we hadn’t inherited the phrase levelling a lathe". All that matters is that the bed is not twisted. I have an older 9" Southbend lathe which is mounted on casters. My workshop is small and I need access to the storage cabinets behind the lathe. These lathes were used in earlier days by the army in their mobile workshops, and not always set up on a solid base. Because they were fitted with a rigid bed, it was recommended that they only be supported on 3 points, 2 at the head and 1 at the tail. The type of base for the lathe is dependent on the rigidity of its bed and the one on the Southbend is very stiff and does not require "levelling" each time it is moved. Other type of lathes may be different. |
Pete Rimmer | 19/01/2023 22:10:11 |
1486 forum posts 105 photos | I can tell you since rebuilding machines is my hobby (I mean grinding, scraping, alignment not just clean and paint), and since concrete cutting, breaking grinding is my profession where I've had to grind plant room/water tank plinths to +/- 2mm over several metres, and because when I'm in the process of rebuilding (but not the alignment phase) a lathe will typically sit on casters, 1. Concrete isn't flat. Even a properly laid power-floated floor is very unlikely to be flat enough that you can move a machine sitting on four points and not have it twist. For your average tamped/trowelled slab - no chance. 2. If you sit a machine like a Bantam on casters and move it any amount, the twist of the bed will change. As a matter of fact, I have sat a bantam on casters whilst in the rebuild process and ran a test whereby I had a dial gauge reading bed twist whist it was being wheeled around and that dial gauge was swinging like a metronome. Here it is on it's 6" 200kg casters after I wheeled it out into my garden for a photo. So if you're asking can you use a lathe that's on casters the answer is - certainly you can. If you're asking can you move it and expect it to hold alignment, even to move it one way then move it back - certainly not. For most people it's not really an issue because their lathes are not aligned anyway.
Edited By Pete Rimmer on 19/01/2023 22:11:31 |
