Slow setting Epoxy
Andrew Tinsley15/01/2023 13:22:05
1817 forum posts
My local supplier of slow setting epoxy has stopped stocking this item. Any recommendations for a supplier and indeed a good brand to replace my old stuff.
Everyone seems to go for quick setting epoxy, which I have never found as good as the 24 hour variety.
Andrew.
Michael Gilligan15/01/2023 13:26:24
23121 forum posts
1360 photos
I have just put the words Araldite Standard in a Google search
… and would suggest you do the same
surprise About 1,090,000 results (0.46 seconds)
Edited By Michael Gilligan on 15/01/2023 13:27:44
Andrew Tinsley15/01/2023 14:40:36
1817 forum posts
Thanks Michael I was unaware that Araldite Standard was the 24 hour epoxy. Easy when you know that. So fixed up now.
Andrew.
Zan15/01/2023 18:18:55
356 forum posts
25 photos
Slow setting epoxy gives 15.6 m hits….
Ian P15/01/2023 19:16:19
2747 forum posts
123 photos
Posted by Zan on 15/01/2023 18:18:55:
Yes but some of them will be duplicates!
So it will take a little longer to find the one you wantfrown
Ian P
old mart16/01/2023 19:26:26
4655 forum posts
304 photos
I found that the standard Araldite, which is the 24 hour paste, is stronger than the fast curing types. Unfortunately it costs about 4 times as much.
duncan webster16/01/2023 19:58:27
5307 forum posts
83 photos
It sets faster if you warm it up a bit. Forms nicer fillets as well, and some say it's stronger, but I can't comment on that
Pete Rimmer16/01/2023 20:07:10
1486 forum posts
105 photos
Get some Araldite 2013. Industrial strength.
Rod Renshaw16/01/2023 20:07:39
438 forum posts
Old Mart, can that price difference be typical? I have never noticed such a big difference.
A quick look on Amazon (Other suppliers are said to be available ) shows Araldite ( other brands are available ) Standard and Rapid at the same price. Is it possible you are comparing epoxy and "Super glue" which I understand are not the same thing?
Rod
old mart16/01/2023 20:19:54
4655 forum posts
304 photos
I pay about £1.50 for fast epoxy at Proper Job, try getting genuine Araldite that cheap.
Rod Renshaw16/01/2023 20:33:17
438 forum posts
Old Mart, Interesting!
Just looked at the Proper Job, Glastonbury, site. They have rapid at £1.50, as you said, but no standard. I wonder if the price difference is between a generic product and I am not saying there is anything wrong with it, and a (the? ) brand leader rather than between Standard and Rapid?
Rod
David Davies 816/01/2023 20:58:17
202 forum posts
BSI (Bob Smith Industries) Epoxy gets good write ups in model railway forums (fora?). Different setting times are available and it’s on sale at Fleabay.
HTH
Martin Hamilton 118/01/2023 20:24:26
188 forum posts
Araldite original is still one of the best 24hr epoxies you can buy, dont even bother with the fast setting Araldite it is total rubbish in comparison to the 24hr stuff. Another very good slow setting epoxy & should not be over looked, is JB Weld original.
Ian P18/01/2023 20:56:33
2747 forum posts
123 photos
Posted by Martin Hamilton 1 on 18/01/2023 20:24:26:
On seeing the above reference to 'JB Weld Original' I looked online and see there are dozens of different versions of J B Weld (which is something I was not aware of)
I dont have any idea which is the original 'original' but if I was looking for an adhesive I would select the most suitable one for the job in hand, I suspect though that I would eventually end up with a larder full of JB Weld versions I may never need again. My 'original' would be the one I used the first time.
On the forum and in the MEW there are many articles and postings that mention using JB Weld, so which version is being recommended?
Is there one version that suits most workshop purposes? (its a genuine question)
Ian P
David Caunt18/01/2023 21:30:42
110 forum posts
40 photos
https://www.hafixs.co.uk/products/profglue/index.html
This is worth considering I've been using this since a visit to Alley Palley over 10 years ago. Not cheap and it does set fairly quickly but I've used it for everything. Do ensure it is drained back before putting the lid on. Found this out the hard way.
bernard towers18/01/2023 22:32:22
1221 forum posts
161 photos
surely that's cyano I thought the thread was epoxy
samuel heywood18/01/2023 23:22:20
125 forum posts
14 photos
Probably not quite what you're after but J B weld seems to take forever to cure whenever i use it!~ not quite as advertised but worth the curing time wait.
Good stuff.
The car wing mirror has held onto the plastic mount for 6 years & counting, not bad for a temporary repair, bonded to plastic.
Roderick Jenkins18/01/2023 23:42:05
2376 forum posts
800 photos
Posted by Ian P on 18/01/2023 20:56:33:
"JB weld-original cold weld steel reinforced epoxy" is the one you want. If I don't need the extreme heat resistance and grey colour then the original (blue) Araldite is as strong for domestic purposes. Remember that in all gluing situations, good surface preparation gives the best bond. Our adhesive specialists at work used to glue PTFE components together with Araldite. Mind you, they had to etch the surfaces with Hydrfluoric Acid surprise
Rod
Lee Rogers19/01/2023 08:31:49
203 forum posts
For those tricky to hold jobs spot tack with cyano and build up the epoxy at leisure. Spare specs repair still good 2 years on.
Speedy Builder519/01/2023 09:03:22
2878 forum posts
248 photos
If you want a metallic mix, scrape some of the dust from the guards off of your grinder and mix it into the epoxy.
Also agree that the epoxy fast cure doesn't have the strength of the 'original' slow cure.
Bob
