Retro-fit speed control to battery grinder?
Pete Rimmer19/11/2022 12:53:45
1486 forum posts
105 photos
I have bought a £15 Ferrex battery grinder from Aldi with a view to removing the metal work head and fitting only the motor to another device.
This grinder uses a 40v battery and has a soft start but no speed control. I don't need the soft start since there will be no cutting disc or rotating parts exposed.
What I want to do is either junk the soft start and fit an independant speed control in it's place, or manually manipulate the soft start ramp to adjust the RPM with a speed pot or something. Here is the board and components that make up the soft start module:
The motor won't be under much load from it's retro-fitted duty, far less than when being used as an angle grinder. What I want to know is:
Does anyone know what method would be used normally to control the ramp, and could it be manipulated to work as a speed setting instead?
OR
Can anyone suggest a suitable speed control that I can put between the 40V battery and motor to vary the speed?
Please I don't want any suggestions to go and buy a grinder with speed control most are an unsuitable shape to do the conversion and since this is an experiment I don't mind trashing a £15 grinder but I'd rather not spend much more on a named brand that I might end up scrapping.
Thanks
Pete.
Michael Gilligan19/11/2022 13:30:29
23121 forum posts
1360 photos
In response to your closing comments … Yes it certainly looks interesting as a £15 source of “make-from”
Two questions:
  1. Do you already have the battery system ?
  2. Can you see any identification marks on the motor ?
P.S. __ The shiny black chip is a rectifier
http://www.thinkisemi.com/pdf/SK1045_SK1065_SK10100.pdf
… so presumably U3 is the clever bit.
Edited By Michael Gilligan on 19/11/2022 13:38:53
Pete Rimmer19/11/2022 13:46:16
1486 forum posts
105 photos
Yes I have the battery system (I obviously needed a battery so I bought one battery set and two grinders).
No marks on the motor it's just a basic PM stator and 7 segment wound commutator.
I was wondering about U3, it rather unhelpfully has no markings. Looks like the top's been sanded off.
Edited By Pete Rimmer on 19/11/2022 13:47:09
Michael Gilligan19/11/2022 13:52:58
23121 forum posts
1360 photos
Posted by Pete Rimmer on 19/11/2022 13:46:16:
  • I was just wondering whether you could ‘review’ the battery system, but it sounds like recent purchase
  • as for the motor .. there are plenty of basic PWM controllers that should handle that
  • Typical crying 2
23121 forum posts
1360 photos
Oops … double post
 However : to avoid wasting the post … here is a ridiculously wild guess [being simply an eight-leg chip that does the relevant job]
https://www.maximintegrated.com/en/design/technical-documents/app-notes/4/4481.html
Edited By Michael Gilligan on 19/11/2022 14:04:14
Pete Rimmer19/11/2022 14:07:34
1486 forum posts
105 photos
Their leaf blower has variable speed but I don't fancy spending 55 quid to see if it work with my motor.
Maurice Taylor19/11/2022 14:13:22
275 forum posts
39 photos
Hi, look up dc motor speed controller on eBay ,plenty on there fairly cheap.
Maurice
Stuart Smith 519/11/2022 15:24:25
349 forum posts
61 photos
I think it will be difficult to modify unless you can reverse engineer the circuit and take measurements with an oscilloscope. Looks like a mosfet power transistor used to switch the motor controlled by U3.
Probably easier to buy a speed controller from eBay as has been mentioned.
Stuart
not done it yet19/11/2022 16:05:56
7517 forum posts
20 photos
Hi Pete,
Looks like you may be ‘scraping’ the bottom of the barrel (or something else?smiley .
I think I still have the speed controller from a mains voltage router, I finally burned out recently, if that might work at low voltage. You are welcome to it, if it helps. Most battery operated screwdrivers have trigger operated speed controllers - plenty of scrap ones around?
Does the 20/40V actually refer to the voltage - or the capacity? - never can tell with these adverts!
Pete Rimmer19/11/2022 16:15:57
1486 forum posts
105 photos
The 20/40v batteries are just two 20v batteries in one package. Some tools use only 20v, others like this one connect them in series for 40v. The underside of that board pictured above has a heavy PCB track linking B1+ to B2- to series them.
I don't think any battery screwdriver controller will do the job unless it could be used to switch the mosfset in PWM mode.
I have looked at some of the ebay/amazon offerings and so far there are none that are powerful enough yet small enough to fit inside the housing. I was kinda hoping that the soft-start works by sending a rapidly-lengthening PWM pulse to the mosfet and that I could somehow swap that output for one from a PWM chip but I guess my 'lectronics knowledge is too scant for that to be feasible.
It's not a deal breaker. The original device is fixed speed it's just 10x more flexible if it can be varied.
Michael Gilligan19/11/2022 16:31:06
23121 forum posts
1360 photos
Posted by Pete Rimmer on 19/11/2022 16:15:57:
I was kinda hoping that the soft-start works by sending a rapidly-lengthening PWM pulse to the mosfet […]
Fig. 2 in the application note that I linked would seem to suggest that is the case
You really need to get an O’Squirrel Scope on it
Frances IoM19/11/2022 17:05:57
1395 forum posts
30 photos
grinding off the identification of the controller chip is fairly common in consumer products (the big boys in consumer products have their chips identified with their own private marks) - it makes blatant (aka Chinese) copying a little more difficult tho sometimes with grazing light you may be able to read it tho usually the chip will only be available in batches of 10000's
John Haine19/11/2022 17:16:11
5563 forum posts
322 photos
I would be at all surprised if the 8 leg chip with the label sanded off was the ubiquitous 555 timer. Operated in a mode where it generates a pulse train whose duty cycle is set by an external voltage that ramps up when you switch on to give the soft start. Pulses go to the gate of the MOSFET, the big diode is a flywheel diode on the motor. Some judicious 'scope work could test the theory. If it's right then you could just feed a voltage to the 555 for variable speed control.
Pete Rimmer19/11/2022 17:25:29
1486 forum posts
105 photos
Interesting John, I didn't realise that a 555 tier could send variable duty pulses I thought they were always 50% duty but variable frequency. I'm very weak on the subject though.
John Haine19/11/2022 21:28:00
5563 forum posts
322 photos
Well, it's a bit suppositious, but there ain't that much circuitry there and it doesn't look very high tec.
John Rudd19/11/2022 21:47:20
1479 forum posts
Just throwing this out there.
It’s conceivable that the chip is a micro, an ATtiny variety…the 4 pads may be the program connections…there’s 5v, MOSI, MISO AND GND….but no pads for Clock and Reset…,?
Easy enough to check with a meter..
Edited By John Rudd on 19/11/2022 21:53:16
John P20/11/2022 10:15:13
451 forum posts
268 photos
Found this circuit out there for soft start motor control at 48 volt but uses
2 x 555 ic .
https://www.homemade-circuits.com/pwm-motor-soft-start-circuit/
may be of some use.
John P20/11/2022 15:06:26
451 forum posts
268 photos
Don't know if it is even worth trying to make something as in the last posting as you can buy this from Aliexpress for about £8
Won't put up the reference number as it will probably be taken down if you need it just send PM.
SillyOldDuffer20/11/2022 16:05:30
10668 forum posts
2415 photos
Posted by John P on 20/11/2022 15:06:26:
Don't know if it is even worth trying to make something...
I agree. The circuit almost certainly is a soft-start, but how it works is unknown and it includes an unidentified 8 pin chip that could be anything from an NE555 to a microcontroller. More trouble to understand and modify than it's worth when PWM speed controllers are inexpensive on amazon, ebay and others.
An ordinary PWM controller provides a sort of built-in soft start. If a switched pot is provided, turning the motor off also sets the pot to minimum speed. May not be ideal or completely fool-proof, but often a reasonable solution.
Robert Atkinson 220/11/2022 16:18:59
1891 forum posts
37 photos
Wherw do all the wires go?
Motor I can see, Red and Black, and battery connections allong the bottom.
What are the markings nest to the wires on the PCB (the silkscreened white markings)?
The fact that the Orange and Blue wires go to the outside two of three connections that are enclosed in a rectangle on the silkscreen. This looks a lot like it was intended for a potentiometer which could be used for a variable speed option.
Robert G8RPI
