Dial Test Indicator
Richard Marks21/10/2022 17:29:24
218 forum posts
8 photos
I would appreciate some help as I am having problems looking for a Dial Test Indicator that has a high level of measurement, all I can find is instruments with a maximum range 0f 40 thou, my dial indicator has a range of 1" but cannot be used horizontally to measure the inside of a hole, the only option I can think of is has anybody built or designed a jig that can use a dial indicator in a vertical position to measure the offset in the inside of a hole, I need to know as I had a job and the hole was not regular and I had problems using my own dial Test Indicator as it could have been damaged due to its small range.
Michael Gilligan21/10/2022 17:47:31
23121 forum posts
1360 photos
Is this the your general idea ?
https://www.starrett.com/metrology/product-detail/671
… seems awful pricey for what it is, but those nice Starrett people have done the design work for you.
JasonB22/10/2022 07:04:22
Depends on the setup but the co-axial indicators have quite a wide range if movement. They only indicate movement not distance but a quick bit of testing and maths would give you the actual movement for whatever level length is being used.
I'm mot sure if Michaels link would work with a 1" range of movement as the arc the lever moves in would have it come off the end of the indicator.
What sort of size hole are we talking?
Michael Gilligan22/10/2022 07:58:46
23121 forum posts
1360 photos
Posted by JasonB on 22/10/2022 07:04:22:
I'm mot sure if Michaels link would work with a 1" range of movement …
Most unlikely
But it’s a big improvement over the aforementioned 40 thou
David George 122/10/2022 08:29:15
2110 forum posts
565 photos
This is an attachment for my Mercer dial indicator. I have longer fingers which screw into the attachment to give longer depth.
David
JasonB22/10/2022 08:57:12
The longer flat area against the end of the indicator would work better but it's like the co-axial one in that it shows a deviation or movement of th eneedle not a measurement and would need to be worked out for each length of finger and maybe a bit of trig thrown in as things are moving in an arc.
Does depend on the part and what is available, if the part could be mounted on say a mill table then you only need set one hole true and zero the dial/dro and then set the offset hole true which will give you how much it is offset by simply reading the dial or DRO in this case 40thou would be ample.
Edited By JasonB on 22/10/2022 08:59:34
Michael Gilligan22/10/2022 09:10:46
23121 forum posts
1360 photos
… a rather laboured presentation : Subtitles and Fast Forward advised
Edited By Michael Gilligan on 22/10/2022 09:18:55
Hopper22/10/2022 09:44:08
7881 forum posts
397 photos
If you need to measure a movement or offset of 1", a dial indicator is probably not the best way of doing it. But your description of what you are trying to do is very vague and incomplete. I am totally unsure what you mean by "measure offset inside a hole" or by mounting a dial indicator horizontally vs vertically. You can mount them upside down if you want to. A pic or more thorough description of what you are actually trying to do, and whether it's in a mill or on a lathe etc etc might bring you more helpful suggestions.
Further to the above attachments for a dial indicator, Harold Hall did some articles in MEW years ago about making your own. Details and drawings are still available on his website here LINK It's a neat little project. I have been meaning to make a set for years, but have never really had a need for them so never got around to it, yet.
Clive Foster22/10/2022 11:06:24
3630 forum posts
128 photos
Bell crank devices are primarily for changing the direction of measurement. They are inherently prone to cosine error so for accurate results the base setting needs to be with the arm perpendicular to the indicator plunger and movement restricted to ± 2.5° to 3° before cosine error sets in.
Making the measurement side arm longer increases the physical range but reduces sensitivity commensurately.
Had a slightly similar situation where I needed to get down inside a bore to verify the various errors to ensure that I had enough room to re-machine a podged up taper. I setup the seesaw probe out of a Starrett Last Word indicator kit and an indicator on my lathe cross slide using a magnetic post mount.
Something off a KTM enduro bike I think. I was very lucky that the Pratt Bernard precision 3 jaw held it accurately enough to dispense with for jaw games.
The Starrett kit uses a back plunger indicator **LINK**
https://www.starrett.com/metrology/product-detail/196A5Z
so the mounting stalk gets in the way on a set up like this.
Using the cross slide feed effectively extend the range considerably. A DRO set up would be most accurate but my cross slide screw and nut are good enough to use as is for better than ± 0.5 thou overall.
I see no reason why the measurement arm could not be made rather longer to increase the operating range but the set up is likely to get very twitchy if you go too far. 10 to 1 at 1 thou per division accuracy is theoretically possible using a tenths thou indicator but the chances of it being stable enough to actually use are slim. 2 to 1 is probably OK.
The Starrett see saw has small spherical contacts at each end and the plunger indicator has a dome end contact. This increases the angular movement range before cosine error sets in. Calculating the effects is possible but not as easy as it might seem. Size matters! In practice anything significantly more than ± 10° or so has the see saw end running off centre round the plunger end so things start to mis-behave and it all gets a bit fraught.
Bottom line is it all worked but I din't want to do it in the first place and, frankly my dears, I'd rather not do it again!
Edited By Clive Foster on 22/10/2022 11:07:24
Martyn Duncumb22/10/2022 11:09:54
55 forum posts
Oh dear, maybe it is just me, but I have just tried the link to Harold halls website and it keeps dropping the connection. I will try later today and hopefully it will work again. Has anyone else had a problem?
Martyn
Michael Gilligan22/10/2022 11:23:16
23121 forum posts
1360 photos
Posted by Martyn Duncumb on 22/10/2022 11:09:54:
Martyn
Just tried … No joy sad
also tried one level up, and that doesn’t connect either
https://www.homews.co.uk/page619a.html
Edited By Michael Gilligan on 22/10/2022 11:26:04
Peter G. Shaw22/10/2022 11:37:08
1531 forum posts
44 photos
Harold Hall's dti accessories will be found in:
MEW14 (Dec 1992) (or MEW 151/152 (Jun/Jul 2009) for a later version).
Also WSP 39, Ch.12.
HTH,
Peter G. Shaw
Neil Lickfold22/10/2022 11:40:52
1025 forum posts
204 photos
I have a long stylus Girod indicator with the small dial. It can get in about 30mm or so just on the stylus. On things with a 40mm hole it can get in as far as you can read the indicator. For getting into very long holes around 250mm deep, I made a pivoting gizmo and use the low press finger indicator with it. It is close to 1:1 ratio. I use this for indicating the bottom of a drilled hole , to align the hole and make the outer true to this hole. I will try and post an image of one of the setups. This is an early one that used a brass tube to keep the weight down and only used the indicator stand end for the pivot. It shows testing at the front of the part checking it's error reading on an area that is known. My latest one uses a piece that has 2 ball bearings in it to reduce pivot drag. In hindsight I probably should have used the type of pivot used in indicator stylus ends.
Martin Johnson 122/10/2022 12:40:23
320 forum posts
I made a homespun version of the Starrett lever & stylus. I have both 180 and 90 deg levers. There was a design in one of the very early MEW's. Not difficult though - a scrap of ally plate, afew small screws and a some steel rod plus an afternoon's work.
Martin
Ian Hewson22/10/2022 12:50:34
354 forum posts
33 photos
Harold’s site worked for me a minute ago with Michael’s links, iPhone and Safari .
Ian
peak422/10/2022 13:57:17
2207 forum posts
210 photos
Posted by Ian Hewson on 22/10/2022 12:50:34:
Ian
And fine for me from a desktop; it's also a lot faster than when I previously visited, so maybe a server upgrade.
Bill
Michael Gilligan22/10/2022 14:06:07
23121 forum posts
1360 photos
Page opens “in the blink of an eye” now
Well done Harold [whatever you did]
Richard Marks22/10/2022 14:25:12
218 forum posts
8 photos
Thank you Gentlemen, I can now work out what to do as it all looks very good.
Richard Marks
Martyn Duncumb22/10/2022 17:06:18
55 forum posts
Great, thanks everyone, now got Harold Halls site working very well.
Martyn
Hopper23/10/2022 12:53:46
7881 forum posts
397 photos
But, as I said before, if you are trying to measure 1" of runout in a hole with a dial indicator, there are probably better or easier ways of doing it. Depend on what you are trying to do as to exactly which alternative would suit your needs.
That's why nobody uses the Harold Hall type attachments anymore since lever-type DTI's became commonly available. (They used to be an exotic luxury item until recent times.)
One problem with the Harold Hall and Starrett type attachments is the ball on the end of the lever moves in an arc while the dial inidcator plunger moves in a straight line. So it will struggle mightily to read correctly over a 1" range due to the ball on the end of the lever misaligning with the plunger at each end of the 1" of travel. It was really intended to do the same thing as today's lever DTIs and measure runout of maybe 100 thou or less.
Edited By Hopper on 23/10/2022 13:24:14
