Glasses -- sometimes called headlamps
Former Member27/02/2022 17:39:20
1085 forum posts
Grindstone Cowboy27/02/2022 17:46:28
1160 forum posts
73 photos
Presumably so they don't have to produce RH and LH versions of the hinge? Is the other side with head uppermost?
Rob
Former Member27/02/2022 18:06:55
1085 forum posts
DiogenesII27/02/2022 18:10:31
859 forum posts
268 photos
Stick a dab of superglue / 638 on them
Speedy Builder527/02/2022 20:14:06
2878 forum posts
248 photos
When I take my glasses off, I can't even see the screws !
BASS 66627/02/2022 20:33:14
49 forum posts
38 photos
Posted by DiogenesII on 27/02/2022 18:10:31:
that's what i do with mine ..
Henry Brown28/02/2022 12:33:06
618 forum posts
122 photos
I use clear nail varnish over the screw head, I can scrape it off and have new lenses fitted in the old frame...
David Caunt28/02/2022 14:04:00
110 forum posts
40 photos
Posted by Henry Brown on 28/02/2022 12:33:06:
Your lucky our optician says sorry can't use the old frame. It used to be OK up until the last 3 pairs. As one of the frames was sold as indestructible it really p??ed me off.
duncan webster28/02/2022 14:15:10
5307 forum posts
83 photos
Find another optician, the prescription is yours, you can ask for a copy
Edited By duncan webster on 28/02/2022 14:16:33
Henry Brown28/02/2022 15:10:42
618 forum posts
122 photos
Exactly what Duncan said, go elsewhere if they won't do as you ask. We use a place in Worcester called The Vision Factory where they grind the lenses and fit them to the frames, a fraction of the High Street cost too...
Juddy28/02/2022 15:11:55
131 forum posts
I would imagine the screws are underneath so that if they do come out they fall away from the eye not into it?
Former Member28/02/2022 15:28:30
1085 forum posts
Former Member28/02/2022 15:28:32
1085 forum posts
KWIL28/02/2022 16:22:37
3681 forum posts
70 photos
As Henry Brown says find a vision supply shop (not an optician). Have done this for the last 40+ years. No charge for reglasing just the lens cost.
Only downside, if your prescription is "wrong" (it happens) that is your added cost, has only happened once in all that time so still cheaper overall. More likely to be more realistic in frame costs when you want to change.
DMB28/02/2022 19:03:07
1585 forum posts
I believe that the High Street opticians offering NHS eye tests have to give you your prescription by law. Specsavers put pressure on me to buy their overpriced frames which I now buy online at a sensible price. Good quality and screw heads always on top. Boots at least, will replace screws or bend side arms if too loose. At least they used to, don't know if they still do. I also got fed up with the conveyor belt feeling at Specsavers so now use Vision Express - get treated more like a human being.
Above is my opinion and experience, so if Specsavers don't like it, they need to up their game.
Anthony Knights01/03/2022 07:28:47
681 forum posts
260 photos
Specsavers wanted to charge me MORE to re-use my old frames. Told them what to do and took my prescription else where. Now I have had cateracts in both eyes operated on, I don't need opticians any more and get away with a set of cheap, off the shelf, reading glasses for close up work.
Bezzer01/03/2022 10:10:05
203 forum posts
16 photos
Specsavers are a franchise operation, depends on which franchisee runs it as to how you are treated. Can't fault our local one for no hassling pleasant customer service and aftersales service. Had screws and nose pads replaced with no problem or charge.
Alan Jackson01/03/2022 10:48:49
276 forum posts
149 photos
Cillary Blue are a good company who make new lenses to your prescription and fit them to your old frame.
Alan
Edited By Alan Jackson on 01/03/2022 10:49:21
ega01/03/2022 11:07:44
2805 forum posts
219 photos
Posted by Alan Jackson on 01/03/2022 10:48:49:
Alan
Thanks for this tip. The big players who won't reglaze should think on. The rot started with the fad for so-called designer frames.
Given that frames now come in a seemingly infinite variety of shapes you do wonder how CB go about getting the lenses to fit.
Bob Unitt 101/03/2022 11:09:43
323 forum posts
35 photos
Posted by David Caunt on 28/02/2022 14:04:00:
Find yourself a new optician. I have several pairs of glasses for different purposes, and I've had new lenses (in one case, just the one eye) fitted on all of them.
