Here is a list of all the postings Juddy has made in our forums. Click on a thread name to jump to the thread.
Thread: Small (20mm 10mm bore pulley) - source of? |
04/10/2023 11:25:40 |
There is this which may get your lathe running: 20mm OD Motor Pulley (Suits Folding Doors) (reeley.co.uk) or from Amazon : 20MM Single Groove Pulley 4/5/6/8/10MM Fixed Bore Pulley Wheel for Motor Shaft 6MM Belt (10mm) : Amazon.co.uk: Business, Industry & Science
Thread: Average Energy Consumption |
27/09/2023 15:31:20 |
Boiler Upgrade Scheme | Daikin
27/09/2023 15:29:59 |
I seem to remember reading somewhere there is a government scheme for replacing boilers with heat pumps and a grant of up to £7500, worth looking into….. |
Thread: Broken toolmakers clamp. |
25/09/2023 16:16:00 |
I made a couple from key steel, seems a little tougher than mild steel but still machinable
Thread: Building a car from scratch |
07/09/2023 14:24:18 |
that's a lovely looking car, it must represent hundreds of hours of work and planning. I modified a mk1 mr2 with a V6 a few years ago, its all of the little things that take so much time, connecting up the heater, ECU wiring, matching the clutch to a gearbox and engine it was never intended to fit, sourcing suitable engine mounts, then there is the brakes, cooling, suspension and so on and on. |
Thread: Machinery Handbook |
31/08/2023 08:51:43 |
I have I think the 23rd edition, which I haven't used apart from a causal flick though, my go to for most of the information I need is the Zeus book or for more involved things (rare for me). The Engineers edge web site: Engineers Edge - Engineering Reference Data and Tools
Thread: Small benchtop belt grinder. |
09/08/2023 12:47:54 |
OK, mate have a nice day |
Thread: RDG Dies |
09/08/2023 10:10:56 |
Is the die holder the correct size for the die, metric and imperial can be different outside diameters, when using a sliding die holder with a slightly undersize die in the holder the screws holding the die will push the die off center in the tailstock which will result in the die stripping the thread or a very poor undersized thread. |
Thread: UKCA and CE Marking of Boilers |
04/08/2023 09:59:37 |
Here you go: |
Thread: Chester face mill inserts |
26/07/2023 13:13:34 |
Possibly something like this: SEKN1203AFTN-M14, SEKN1203AFTN-M14 T25M | Secotools.com
Thread: Spiders |
20/07/2023 13:03:38 |
peppermint sprays are used by alarm companies to stop false alarms due to spiders getting where they shouldn't. Also there is the conker (horse chestnut) in the corner of the room solution, which is supposed to discourage them, I'm not sure how this works or if it does work, but my wife places them in each room in the corners and we have had very few spiders or webs since she started to do this |
Thread: A few years ago. |
06/06/2023 14:07:31 |
Posted by Ady1 on 06/06/2023 13:55:20:
Posted by Mike Poole on 06/06/2023 13:05:53:
Are we in the plastic age now? Post of the week lol Tragic but very true, they'll still be digging that stuff up in a thousand years same as the stone and bronze age things
06/06/2023 13:38:54 |
I think the present time is actually called the age of technology |
Thread: Foundations? |
13/04/2023 08:45:23 |
3D printing is far too slow, the cycle time of that press will be a couple of minutes at most, to print the same thing will be days and will not produce the item anywhere near strong enough for the application. |
Thread: Chinese diesel heater |
06/01/2023 09:04:33 |
Wow, this thread is amazing so much concern for safety from a bunch of guys that probably are using machine tools with little to no guarding or outdated safety features last reviewed in the 1960's whilst working on their own for the most part in sheds and that's ignoring the silver soldering and welding. I think you all have bigger safety issues in your workshops than worrying about one members diesel heater install. Which I'm sure he has tested fully because he appears to be no fool and has taken time to research the install and operation of the heater, and will be satisfied that he is not going to burn his workshop down or cause a major incident. I know most of you take your safety seriously otherwise you wouldn’t have all reached such great ages. But please look again at your own safety practises and the risks involved, I’m sure most of you can make improvements. |
Thread: M3 (5.5) flat spanners |
06/12/2022 16:26:47 |
small spanner set on ebay: MINI SPANNER SET 3.2mm 4.0mm 5mm 5.5mm 6mm 7mm 8mm 9mm 10mm 11mm Engineer ts-05 4989833063658 | eBay lots more on ebay spanner 5.5 for sale | eBay
Thread: Snowdon Mountain Railway |
02/12/2022 11:50:14 |
I would imagine that they are not permitted to grease the racks because of contamination of the environment in a National Park, so lack of any form of lubrication will not help in the excessive wear. |
Thread: Toys for Christmas |
28/11/2022 15:14:48 |
150mm rule, M&W or Starrett or Brown and sharpe always useful stocking filler. |
Thread: Pendula |
18/11/2022 12:10:36 |
its explained here: How Does Big Ben Keep Accurate Time? - YouTube
Thread: Clocking on a 4 Jaw indepdent |
20/10/2022 13:14:53 |
I find it easier if your trying to center a round bar or hex or square to mark the center of the bar using either a center finder or just drawing a line between corners then align that marked center with a tail stock center which will get you quite close before using a DTI for the final few adjustments |
