Need to cut long thin strips of steel (& plastic) - e.g. with an angle grinder?
John Smith 4718/01/2022 17:51:52
393 forum posts
12 photos
Hello
I hardly dare re-kindle this old thread....
"Small saw. Proxxon or something else"
https://www.model-engineer.co.uk/forums/postings.asp?th=172361&p=1
...However I find that I do keep needing to cut long thin strips of material. It's usually either wood/plastic (e.g. ABS/PS/Nylon), or stainless or mild steel.
My requirements have evolved since that thread so I shall this new one.
My cutting requirements are:
1. Material thickness:
My steel is generally between 0.9mm and 1.4mm.
2. Lengths:
My lengths might be say 10 to 20cm,
with a width of maybe 2 to 5mm.
3. Materials
Steel is obviously the hardest of the things that I need to cut. So a small machine that could even cut just steel would be a revolution for me. But would it be too much to hope for one machine that could cut both materials? (Like my fine-toothed hacksaw can!)
BACKGROUND/PROBLEMS
To be honest, my hacksawing skills aren't very accurate. It's particularly difficult, particularly after dark when there is less daylight to help me see what I am doing. Seeing marked lines on steel (even when using Dykem Steel Blue) is quite difficult...
So I find that I keep having to hacksaw somewhat over-sized and then hand-file or grind down and remove quite a lot of material to get them down to the precise required sizes.
==> So I find myself fantasizing about a precision/micro table saw that can also cut steel! Or possibly some rig to enable me to do hacksawing with great precision?
From memory (and without re-reading the entire previous discussion):
a) Small table saws (e.g. Proxxon) ==> just aren't designed for steel
b) the Proxxon band saw definitely wasn't
c) Larger, more powerful table saw just aren't designed for cutting small precision parts.
d) A nobody seems to make small grinding disk wheel (e.g. 1mm thick) embedded into a cutting table. [And no, I don't really have time to mess about making one!]
e) My strips are too long to readily fit onto my MF70 milling machine.
f) I don't think a guillotine will work because the leave one side of the cut steel sheet curved.
[ NOTE: As before, I do not have a permanent works space. Everything needs to be cleared away at the end of each day. So tools need to be fairly light and compact. ]
MY POSSIBLE SUGGESTIONS:
What about cutting using micro-sized angle grinder.
...And then finding some way to line up next to a ruler/straight edge?
[But how exactly? Have any of you tried this?]
A. "PROXXON LHW LONG NECK ANGLE GRINDER"
https://www.axminstertools.com/proxxon-lhw-long-neck-angle-grinder-702027
- with cutting disk fitted
or
- "For steel, non-ferrous metals, glass, ceramics, wood and plastic"
- 50mm diameter discs
- 100W DC motor.
B. Or possibly a DREMEL would be better (??)
e.g. "DSM20-1/5 710W Compact Saw 230V"
https://www.cromwell.co.uk/shop/power-tools/compact-saws/dsm20-1-5-710w-compact-saw-230v/p/DRE2674120F
- Blade diam: 77mm
- No load speed: 17000rpm
- Power: 710W (?)
- Weight 1.7Kg
- Dust extraction port for clean working environment (vac cleaner attachment)
- "1 x straight edge guide"
I was thinking that something that cuts with a very thin disk would create less dust, but the dust extraction port could mitigate that problem. Also claims to have "Excellent line of sight for accurate cutting"
Yes, seem like it will be damned noisy...
> Noise K Factor: 96 dB(A)
> Noise Sound Power: 108 dB(A)
> Noise Sound Pressure: 1.59 Pa
...whatever that really means, but I live with that. (With earplugs if necessary)
BUT it is quite big & heavy (at 1.7Kg), for more precise work.
Have any of you got one? Have you had much success in cutting straight lines with them by lining them up against straight edges ?
What do you think?
J
Frances IoM18/01/2022 17:59:53
1395 forum posts
30 photos
you will need very forgiving neighbours as well as an expensive set of ear defenders.
Dave S18/01/2022 18:12:00
433 forum posts
95 photos
<popcorn>, <chair>, <beer>
Tony Pratt 118/01/2022 18:14:57
2319 forum posts
13 photos
Pass
Tony
John Smith 4718/01/2022 18:15:45
393 forum posts
12 photos
Posted by Frances IoM on 18/01/2022 17:59:53:
IME, wax earplugs work well.
Fwiw, on my street there is always a LOT of building work going. And much of it is exceedingly noisy being as it happens outside from rooftops... for days on end! However nobody seems to mind, and I would be amazed if anyone even noticed a new noise from indoors.
J
Redsetter18/01/2022 18:24:21
239 forum posts
Just order your materials cut to size.
Robert Butler18/01/2022 18:28:59
511 forum posts
6 photos
Topic well aired in previous thread, an insoluble problem.
Robert Butler
Bezzer18/01/2022 18:49:32
203 forum posts
16 photos
I've just been cutting similar strips of 1.2mm stainless sheet and the weapon of choice was my wet wheel diamond blade tile saw. It's a cheap Plasplugs one about 12 years old and doesn't have a problem either freehand or with the guide giving a decent clean and accurate cut. Blades aren't that dear and last well.
noel shelley18/01/2022 18:59:45
2308 forum posts
33 photos
iF YOU CANNOT CUT A STRAIGHT LINE with a hacksaw then you do have a problem ! I would have suggested 4.5" X 1 or 1.5mm cutting disc in a small angle grinder. May be you need more practice. Good luck, Noel.
JasonB18/01/2022 19:18:57
If you can't see the line to saw to what hope have you using any other form of free hand cutter given the added complications of eye protection and sparks flying about. Though maybe the sparks will make it a bit brighter either that or get some decent lighting in your work area.
Nick Wheeler18/01/2022 19:38:18
1227 forum posts
101 photos
Cleaning off the burr caused by any abrasive disc is going to be way more work, less accurate and more time consuming than just tapping any guillotine distortion straight. The guillotine will cut quicker too, and a long machine could cut several of your parts in one operation.
HOWARDT18/01/2022 19:48:47
1081 forum posts
39 photos
Have you looked at buying metal inlay strips. Would be a lot easier in the long run than all the cutting, deburing, and flattening.
John Smith 4718/01/2022 20:05:38
393 forum posts
12 photos
Posted by noel shelley on 18/01/2022 18:59:45:
Yeah the lines are generally straight, just not in the correct direction!
Over 15 to 20cm even the smallest errors mount up.
Is not a small angle grinder precisely what I was suggesting?
But 4.5inches (11.4cm) is even larger than the machines I found. I don't see how a larger, heavier machine would help with accuracy.
Exactly what is your point?
> Good luck
Thanks you.
@JasonB
> If you can't see the line to saw to what hope...
At no point did I say that I "can't" see the lines, I said that it is harder to see the lines in less good lighting conditions. Yes, I have various portable lamps which I can and do set up when necessary, but you have to get the light to bounce off the metal just right to see the scribe marks properly. Sometimes this means pointing the lights to the floor... For best results, I may also need to change between different magnifications of reading glasses. Either way in practise if I need a more accurate cut then I have to keep stopping and checking multiple times.
==> Ergo, it's not about possibility/impossibility it's about difficulty, inconvenience & speed.
Look let's stop the smart-ass comments. There is no use pretending anyone here, no matter how many thousand years of sawing-by-handsaw experience they might have, will ever be able to saw as accurate parallel lines as a machine such as a table saw can cut.
@Redsetter
When I can, I do. But not always possible.
And where possible implies delays & potential over-orderings...
@Dave_S
My pleasure. FOC entertainment at your service.... :^P
John Smith 4718/01/2022 20:12:53
393 forum posts
12 photos
Posted by Nicholas Wheeler 1 on 18/01/2022 19:38:18:
Tapping it straight?!
In my experience, unless you put it through a special straightener you never EVER got the metal completely flat again.
I have found it hard enough to find the metals I require e.g. Grade 430 stainless 1.0, 1.2 & 1.4mm thick without trying to find the exactly correct width. In any case, I have now bought the sheets. It would be a shame to waste them.
Brian Morehen18/01/2022 20:15:06
191 forum posts
11 photos
Have you looked at a Multi Tool ,I have cut most of the material you have mention using a straigh edge as a guide
saw mine in Lidli some time ago and bought , with the right blades well worth the cost has saveded me loads of time .
Regards Bee,M
pgk pgk18/01/2022 20:22:19
2661 forum posts
294 photos
If the lines you are trying to cut are generally straight, then adhesive tape as a guide would be more visible than scribing. You may also consider the method of printing patterns and spray adhesive them to the material.
pgk
David Noble18/01/2022 20:28:35
402 forum posts
37 photos
I hesitate to enter the fray but a guillotine would do it.
David
Nick Wheeler18/01/2022 20:45:06
1227 forum posts
101 photos
Posted by John Smith 47 on 18/01/2022 20:12:53:
You need more experience then!
Cuts made with grinding wheels on thin materials are horrible things. Doing one or two like would be OK, but more than a couple is not acceptable. I would always trade flattening an already straight cut over cleaning up one done by hand with a grinder.
Martin Connelly18/01/2022 20:57:30
2549 forum posts
235 photos
Buy a suitable mill and some slitting saws. Clamp the stock between two plates to support the material. The way this is going it will be cheaper than waiting for your perfect tool. The mill only needs to have a travel slightly more than your longest strip.
Martin C
Ian P18/01/2022 21:10:57
2747 forum posts
123 photos
Posted by John Smith 47 on 18/01/2022 17:51:52:
2. Lengths:
Table saw, milling machine, slitting saws, angle grinders and almost anything else commonly (or uncommonly) available would struggle to cut a strip 1.4mm x 2mm.
Doable with scalpel if Balsa wood was acceptable
Ian P
