Member postings for Redsetter
Here is a list of all the postings Redsetter has made in our forums. Click on a thread name to jump to the thread.
Thread: Inverted slide valves
03/10/2023 22:16:49
My only experience of this was with a 5" Pansy with valves below the cylinders. On starting, there was a short delay after opening the regulator until the steam chest pressure increased enough to lift the valves up, and you could usually hear a click when this happened. You could induce this by snapping the regulator open, then backing it off to the starting position. It really wasn't a problem once you knew about it.
Thread: Advice Wanted - On obtaining help...
18/09/2023 11:45:46
If the object of the exercise is just to allow fitting of different chucks, then an easier solution might be to make an adaptor, or a few separate backplates. I had a Zyto branded Flexispeed long ago, and I think the nose thread was 1/2" BSF. If so, no problem getting a tap to start you off.
18/09/2023 09:36:25
Andy,
With respect, I think you will find that the Flexispeed is made to Imperial dimensions so you should stick with those, apart from your chosen nose thread.
From your drawing, 12.8mm is a bit more than 1/2", so probably 1/2" bearings. 6.3mm is a bit less than 1/4", so probably 1/4" bore - you need to be a lot more precise than that! And what are you going to do about the worm gear?
If you can find someone to do it, best to just let them have the whole machine and tell them what you want, so that they can fit the spindle to the job rather than trying to rely on a drawing.
And it costs what it costs. It may not be difficult for a skilled person, but it will be time-consuming, so don't expect them to do it for beer money.
£200 odd for the Cowells spindle isn't unreasonable, and an accurately made one-off, starting from scratch, will probably be be more than that.
Sorry if this all sounds a bit negative, but I am not sure you are being realistic. As said- what is the actual problem with the existing spindle?
Thread: Jubilee boiler 3.5 gauge
01/09/2023 11:22:14
I think the OP is referring to the design by Martin Evans for a Stanier 2-6-4T, which he named Jubilee.
Edited By Redsetter on 01/09/2023 11:38:57
Thread: History of the magazine.
25/08/2023 14:15:52
Another name which comes to mind is Dick Laidlaw-Dickson - not sure if he was ever editor, but certainly involved in the late 1960s.
Slightly off-topic, but in view of LBSC's well-known antipathy to Martin Evans, you have to hand it to Martin for visiting LBSC, and persuading him back into the fold. Considerable tact and diplomacy must have been required - oh, to have been a fly on the wall !
25/08/2023 12:50:42
Hollingsworth's book on LBSC indicates that following Maskelyne, c. 1955, the editors were L.B. Howard, then Kenneth Garcke, plus managing editor, L.B Waller.
It would indeed be interesting to know more about the history of the magazine and those involved.
Thread: Stephensons valve gear
21/08/2023 10:24:10
LBSC described an outside Stephenson gear for Tich in ME, vol. 120, 3012, as an alternative to Walschearts and used it on his own engine. I have only ever seen one other example. It would probably suit a Simplex if scaled up, and the double return cranks would be easier to deal with in the larger size.
11/08/2023 06:45:29
No disrespect intended to Don Ashton, but he was a perfectionist, and in my humble opinion he was unnecessarily critical of some designs which work quite well in practice.
10/08/2023 22:54:30
Posted by Simon Collier on 10/08/2023 22:22:00:
The plan is to have a vertical rocker to reverse the drive to be correct for launch links.
I would make sure I can satisfactorily make the eccentrics arrangement first up.
The background is I was given a full set of Simplex castings, frames and plans, plus boiler barrel. But I have a Simplex which I bought to drive while I made my Springbok. With a saddle tank and unusual valve gear, it would be different enough to be interesting.
Have you considered the layout used on LMS 4767 which has a launch link with direct drive?
Also the version used on some "foreign" locos with two outside eccentrics carried on a return crank? Perhaps a bit bulky, but easier to adjust than a double return crank.
10/08/2023 09:38:00
Posted by Simon Collier on 10/08/2023 02:14:03:
There are examples of die up for forward running with Walschaerts but are there any examples of link up for forward with Stephensons? Duncan might know.
Also, I don’t understand why the correct drive line is different for loco and launch links. They are not that different. Don’s book shows the preferred arrangements but doesn’t really explain why, stating that the preferred arrangements limit die slip.
I am designing outside Stephensons for Simplex, just for something different, and even raising the cylinders slightly and angling them will still have the launch link only 3/4” off the rail head in full gear.
Is there any advantage in "link up for forward running" with Stephenson's? It would of course give you more clearance between link and rail level when running forwards, but you need the clearance in reverse as well. 3/4" clearance seems ample. It is usually much less than that in 3 1/2" gauge.
Thread: Interference fit bearing sleeve
15/07/2023 01:45:30
A floating bush has been suggested earlier but I think it is difficult to predict how this would behave. As the assembly heats up the bush will expand, and tend to bind in the housing. To ensure that it floats properly it would have to be quite a loose fit, in which case it may not work well as a bearing.
15/07/2023 00:42:54
Is there any reason why the bush cannot be retained in the external housing, with the shaft rotating inside it? It would only need a light press fit, or Loctite. The oil holes could be drilled through after fitting.
Or isn't that complicated enough for you guys?
Thread: MEW Workshop Tales Artie Moore and Titanic
18/06/2023 14:53:59
Stating the obvious perhaps, but the editor of MEW must know the source of the article. Maybe ask nicely?
17/06/2023 18:51:54
Can I suggest that a posting on the UK Vintage Radio forum would be worthwhile? They are a very helpful and knowledgeable bunch.
Thread: Air in steam boiler
16/06/2023 13:18:33
Any air contained in the boiler while raising steam will be blown out when the safety valve opens.
Thread: How to repair this clock spindle?
13/06/2023 19:48:52
The hole is not too difficult to recover, as has been stated, but the escape wheel is best replaced, and with that amount of wear it is likely that there are other problems elsewhere. It would be worth looking for another Enfield movement in better condition. They were well made, but not intended to last indefinitely, and they are neither rare nor expensive.
Thread: Using nitrile balls in clack valves
20/05/2023 19:08:34
Stainless balls are absolutely fine in bronze clack valves and they last indefinitely.
Edited By Redsetter on 20/05/2023 19:09:57
Thread: BSW threads on fobco drill
15/05/2023 22:14:50
6BA?
Thread: Stuart 10 Machining Steam Chest
15/05/2023 09:14:17
A competent person can do that whole job in a four-jaw chuck very easily without any special fixtures.
Thread: Electrical Newbie....please help!
12/05/2023 09:37:43
OP, with due respect, you are only telling us part of the problem.
What are you actually trying to make on the lathe?
Have you considered manual operation? It would just need a crank handle on the end of the leadscrew, and would be far more controllable than an electric drive in its simplest form.
You will also need some way of feeding the tool into the work, and that will normally require another leadscrew.
