Michael Gilligan | 25/10/2021 11:52:01 |
![]() 23121 forum posts 1360 photos | As we are probably all aware … The chemical of choice is/was hydrofluoric acid; which comes with some serious safety-hazards. I was therefore surprised to see [in a crafting magazine that my wife was reading] this product advertised as being approved for use by twelve-year-olds : https://etchall.com/product/etchall-etching-creme-5/ . It turns out that the active ingredient is Ammonium Bifluoride : https://frantzartglass.com/images/Etchall%20Dip%20n%20Etch%20Liquid%20MSDS.pdf . Not a substance with which I am familiar … So I would be interested to know what the forum’s Chemists think. MichaelG. |
peak4 | 25/10/2021 13:04:09 |
![]() 2207 forum posts 210 photos | No idea myself, but seems to be available from UK suppliers e.g. this one https://www.creativeglassshop.co.uk/product/31199/etching-solution-118ml.html Bill |
Howard Lewis | 25/10/2021 13:13:12 |
7227 forum posts 21 photos | Ammonium Bifluoride? So uses the Flouride ions to do the etching, presumably. Still the thought of a 12 y o handling it seems a bit dodgy, but maybe I'm just windy! Howard |
Thor 🇳🇴 | 25/10/2021 13:18:34 |
![]() 1766 forum posts 46 photos | Ammonium Bifluoride can irritate/burn your skin and I would not inhale it, more info here. Thor |
Dick H | 25/10/2021 13:46:39 |
141 forum posts 1 photos | The original post referred to a product where there the ammonium bifluoride is in the form of a cream or paste and thus less likely to splash. Even so, good safety specs or a full face visor, proper gloves (i.e. Marigolds rather than a thin disposable gloves) and a plastic apron. There is an interesting discussion at https://www.finishing.com/94/62.shtml. |
Michael Gilligan | 25/10/2021 13:53:41 |
![]() 23121 forum posts 1360 photos | Thanks, Dick … that’s very helpful MichaelG. . It makes reading this all the more interesting : https://acmiart.org/index.php/art-material-safety/safety-tips-what-you-need-to-know
Edited By Michael Gilligan on 25/10/2021 14:00:05 |
Barry Smith 4 | 27/10/2021 00:47:14 |
![]() 29 forum posts 2 photos | Hi, being a chemist for more than 45 years I would not let it near a child or adult outside of a workplace or laboratory where people have access to an antidote and have been trained. Those using HF to dissolve rocks used to say its better to not wear gloves as if you have a pin prick you won't know it as HF and ammonium bifluoride / ammonium fluoride does not burn the like sulphuric etc. By the time you feel the burning sensation it will be too late and you can't just wash it off. You also have inhalation hazards with these compounds which can be severe. Using the ammonium bifluoride as a paste is marginally safer than HF as its less concentrated in terms of fluoride ion concentration. On contact with water it ionises to produce the acid F and H ions hence is acidic. As you say the F attacks the glass, I hope this help Barry The above said, it was being used in the USA for cleaning car wheels at car washes until 2000! |
Michael Gilligan | 27/10/2021 08:13:28 |
![]() 23121 forum posts 1360 photos | That helps a lot, Barry … Thank You I still find it astonishing that they have cleared it for use by twelve-year-olds, when the modern world sometimes seems totally paranoid about chemical safety. MichaelG.
J Hancock | 27/10/2021 08:55:05 |
869 forum posts | When you can't even buy a tube of Evostik off the shelf anymore it 'beggars belief' this stuff is considered safe for children to use. Industrially, they die up here on Humberside with accidents of similar material. |
Barry Smith 4 | 27/10/2021 14:59:15 |
![]() 29 forum posts 2 photos | When replying I forgot to mention an incident that happened in our lab back in 1988. A cleaner who was not very with it pinched a 1l bottle of HF acid and fortunately told his flat mate that he had decanted it into small plastic tubes so that he could throw it at potential attackers on the tube/streets. Fortunately, he had his collar felt quite quickly by the bill and we got it back. Things are now much tighter although I sometimes regret this when needing to do some case hardening Barry |
Russell Eberhardt | 27/10/2021 15:53:46 |
![]() 2785 forum posts 87 photos | As a child I was given an old "boy's book of chemistry" by a lab technician at Oxford University. One of the many dangerous experiments in it was to etch glass. The instructions were to ask your dentist for some old teeth, grind them up and place in a evaporating dish with some strong acid (was probably nitric), place the glass with wax resist on top of the dish and heat to produce hydroflouric acid fumes! It also described how to make and explode picric acid! I avoided the most dangerous experiments but did make some nitrogen tri-iodide. Those were the days! Russell |
NIALL HORN | 27/10/2021 16:23:03 |
![]() 49 forum posts 18 photos | I used to have a book of microscopy techniques for amateurs. It described subliming realgar (arsenic trisulphide) on to a microscope slide for mounting diatoms. It was the preferred medium due to it’s high refractive index for counting the dots. Not something I would do without a fume cupboard! It was also used as an artist’s pigment - must have made a few people rather ill. Niall |
Neil Wyatt | 28/10/2021 20:05:51 |
![]() 19226 forum posts 749 photos 86 articles | I've used a similar product to remove partially damaged coating from a pair of spectacles to make them usuable enough to get another year's use out of them (tightwad). I treated it with considerable respect. Neil |
Russell Eberhardt | 28/10/2021 20:29:24 |
![]() 2785 forum posts 87 photos | Posted by Neil Wyatt on 28/10/2021 20:05:51:
I've used a similar product to remove partially damaged coating from a pair of spectacles to make them usuable enough to get another year's use out of them (tightwad). I treated it with considerable respect. Neil The coating on glasses doesn't seem to adhere so well on modern plastic lenses. Mine have just become unwearable after only two years. Russell |
Swarf, Mostly! | 28/10/2021 20:30:07 |
753 forum posts 80 photos | Posted by J Hancock on 27/10/2021 08:55:05:
When you can't even buy a tube of Evostik off the shelf anymore it 'beggars belief' this stuff is considered safe for children to use. Industrially, they die up here on Humberside with accidents of similar material. Hi there, all, I still have a mostly full tube of black Bostic in a safe place. I guard it carefully. For some jobs it works like no other. The glue sniffer nutters ruined a lot of things for a lot of us!!!!!! Best regards, Swarf, Mostly! |
bernard towers | 28/10/2021 22:50:01 |
1221 forum posts 161 photos | Russell , surely your prescription is out of date by then!! |
