Taper pin/reamer for 3/32"
Martin L | 16/08/2021 12:02:54 |
7 forum posts | Hi, First post so hello to all. I have a 3/32" pin I need to change to a tapered pin, not sure what size I need.?. Will a 7/64" do or do I need to go to 1/8" size for pin and reamer. Thanks for any info. |
Emgee | 16/08/2021 13:43:47 |
2610 forum posts 312 photos | Martin As you imply the small end of the reamed hole will need to be greater than 3/32" so you need to check a tapered reamer chart sizes for a suitable reamer. Emgee Quick search found these, looks like metric has wider choice of sizes.
Edited By Emgee on 16/08/2021 13:59:11 |
not done it yet | 16/08/2021 14:00:17 |
7517 forum posts 20 photos | The taper is probably more important than the actual size (as long as greater than the current hole). A tapered pin with a 2.5 mm minimum could suffice. Different taper to imperial, mind. The wide end of the tapered pin (so the overall length of it) needs to be catered for. |
Phil H1 | 16/08/2021 14:20:34 |
467 forum posts 60 photos | Misread your post Edited By Phil H1 on 16/08/2021 14:23:32 |
Martin L | 16/08/2021 15:13:25 |
7 forum posts | Thanks for the info/help Changing the 3/32" pin's that hold the crank on the shaft of a Stuart twin Victoria , just so they are a lot easier to remove. Looks like 1/8" pin and reamer will be the one to go with, taper pin needs to cover 3/4" depth, going with a 1" pin OK?
Grindstone Cowboy | 16/08/2021 15:29:20 |
1160 forum posts 73 photos | Just to digress.. I've never used a tapered reamer, so is the correct procedure to assemble the parts and then ream the hole in both at the same time? I'm assuming it must be, but never been told this or seen it written anywhere. Thanks, Rob |
Martin L | 16/08/2021 15:37:14 |
7 forum posts | I'm the same never used a taper reamer before, so I'd like to know as well Rob. I'll be going through cast/steel/cast, think I'll have a trial run on steel first |
roy entwistle | 16/08/2021 15:42:14 |
1716 forum posts | Ream both parts assembled together. If more than one pin is needed on one shaft they should both be reamed from the same side. |
Grindstone Cowboy | 16/08/2021 16:22:20 |
1160 forum posts 73 photos | Thanks Roy |
Martin L | 16/08/2021 17:24:09 |
7 forum posts | Posted by roy entwistle on 16/08/2021 15:42:14:
Thanks for this.
not done it yet | 16/08/2021 20:18:28 |
7517 forum posts 20 photos | When I’ve fitted mine it has been after loctiting parts together. Choice of loctite grade is up to me. If it is intended to be permanent, a stronger grade is chosen. I value my reamers so tend to step drill to reduce the metal that needs to be cut away with the reamer. But I’ve yet to pin anything under an inch diameter… |
Nick Hughes | 16/08/2021 20:33:18 |
![]() 307 forum posts 150 photos | Here you go:- |
Martin L | 16/08/2021 21:46:48 |
7 forum posts | Great info thanks, love those old vids always clear concise information. Really looking forward to trying this now. |
Grindstone Cowboy | 16/08/2021 23:02:00 |
1160 forum posts 73 photos | +1 on what Martin said. Thanks Rob |
Jon Lawes | 17/08/2021 05:01:57 |
![]() 1078 forum posts | Funnily enough, all these years I've just realised I've never used a taper reamer either, but will almost certainly need to soon. Thank you. |
Nigel McBurney 1 | 17/08/2021 09:04:41 |
![]() 1101 forum posts 3 photos | Be careful when reaming with a tapered reamer,the flutes quickly fill with swarf so withdraw the reamer to clear the swarf more frequently than when using parallel reamers. use a lubricant when reaming,sluble oil,lubricating oil,or in tough materials Rocol helps, |
mick H | 17/08/2021 09:36:39 |
795 forum posts 34 photos | What a superb video as posted by Nick. No excess verbiage or ego that accompanies modern offerings. Mick |
Ady1 | 17/08/2021 09:58:37 |
![]() 6137 forum posts 893 photos | Posted by mick H on 17/08/2021 09:36:39:
What a superb video as posted by Nick. No excess verbiage or ego that accompanies modern offerings. Mick I noticed that modern vids can be hugely verbose and they ALL do it, especially the USA vids I think that the longer your page is viewed- the more advertising there is- and the more income you make So there's tons of useless fluff and a snippet of useful at the end |
Michael Gilligan | 17/08/2021 10:22:26 |
![]() 23121 forum posts 1360 photos | Posted by Ady1 on 17/08/2021 09:58:37:
What a superb video as posted by Nick. No excess verbiage or ego that accompanies modern offerings. Mick I noticed that modern vids can be hugely verbose and they ALL do it, especially the USA vids I think that the longer your page is viewed- the more advertising there is- and the more income you make So there's tons of useless fluff and a snippet of useful at the end . I’m sure you are right, Ady But also note that this film would have been an expensive production compared with the typical video ‘tutorial’ MichaelG. |
Circlip | 17/08/2021 10:31:00 |
1723 forum posts | "I noticed that modern vids can be hugely verbose and they ALL do it, especially the USA vids" MANY generated on this side of the pond can challenge that.
Regards Ian. |
