Here is a list of all the postings Martin L has made in our forums. Click on a thread name to jump to the thread.
Thread: Casting blow holes |
20/08/2021 21:12:25 |
Thanks for the info, Brian I will go with your fix thanks, now wondering what the other side has in store. Martin
20/08/2021 17:35:49 |
What is my best option for dealing with these blow holes in the casting. I'll end up under size if I carry on cutting.
Thanks for any help. Link to pic of the casting. https://i.imgur.com/CnJlKca.jpg
Thread: Taper reaming |
16/08/2021 21:46:48 |
Great info thanks, love those old vids always clear concise information. Really looking forward to trying this now. |
16/08/2021 17:24:09 |
Posted by roy entwistle on 16/08/2021 15:42:14:
Ream both parts assembled together. If more than one pin is needed on one shaft they should both be reamed from the same side.
Thanks for this.
16/08/2021 15:37:14 |
I'm the same never used a taper reamer before, so I'd like to know as well Rob. I'll be going through cast/steel/cast, think I'll have a trial run on steel first |
16/08/2021 15:13:25 |
Thanks for the info/help Changing the 3/32" pin's that hold the crank on the shaft of a Stuart twin Victoria , just so they are a lot easier to remove. Looks like 1/8" pin and reamer will be the one to go with, taper pin needs to cover 3/4" depth, going with a 1" pin OK?
16/08/2021 12:02:54 |
Hi, First post so hello to all. I have a 3/32" pin I need to change to a tapered pin, not sure what size I need.?. Will a 7/64" do or do I need to go to 1/8" size for pin and reamer. Thanks for any info. |
