Gary Wooding | 15/03/2021 09:45:24 |
1074 forum posts 290 photos | I originally posed this question in another thread, but got no response. Quite simply, I've got a PR303E but cannot find a user manual for it. In the photos, I think 'A' is the oil filler cap, but don't know what 'B' and 'C' are. Can anyone help please? Does anybody have a copy of the user manual? |
Grindstone Cowboy | 15/03/2021 09:58:36 |
1160 forum posts 73 photos | Just guessing, but I suspect C would access the filter. Not so sure about B though. Rob Edit - from the photos, this one on Ebay appears to have an instruction sheet. Might be worth contacting the seller and asking for a photocopy? Edited By Grindstone Cowboy on 15/03/2021 10:01:33 |
noel shelley | 15/03/2021 10:01:57 |
2308 forum posts 33 photos | I haven't got a manual either BUT I have got one of these ! A wonderful and almost bombproof small air commpressor. It has a built in pressure relief set at about 40PSI. A) is the oil level. B) is the filler. C) is the filter. Any oilis better than NONE. I would use SAE 30 unless you have any better info. I can't check mine as I have lent it out. The were made for paint spraying. Hope this is helpful ? Noel. |
Gary Wooding | 15/03/2021 11:15:21 |
1074 forum posts 290 photos | Thanks for your responses guys. I haven't asked, but judging by the price of the one on eBay (£650), I don't think the seller would co-operate. |
Emgee | 15/03/2021 14:13:48 |
2610 forum posts 312 photos | Posted by Gary Wooding on 15/03/2021 11:15:21:
Thanks for your responses guys. I haven't asked, but judging by the price of the one on eBay (£650), I don't think the seller would co-operate. I have the same compressor so asked the seller cost for copy of the instruction sheet PDF by email, not surprising £20, bit like the asking price. All you really need to know is change the oil regularly and clean the intake filter so not bothering with instructions !!! Emgee |
Andrew Evans | 15/03/2021 14:27:09 |
366 forum posts 8 photos | Yes, i have one too. Someone left one by the side of the road a few months ago for free and i grabbed it. It was filthy, so i cleaned it up, sorted out the dodgy cable and it works perfectly. Mine has a tyre inflator attachment fitted. Yes, its the oil and filter. You can take them apart easily, there is viirtally no moving parts. I have a plan to use it to power a mist coolant system as it is pretty quiet - not sure if it can deliver enough air. |
John Rudd | 15/03/2021 15:34:05 |
1479 forum posts 1 photos |
I asked him "what work exactly has been done to this compressor as it is described as 'seller refurbished', did you use any spares?" (potential for mis-selling, not as described)
It wouldn't surprise me if it didn't sell....
Just got a reply on the instructions...£20....Greedy!! Edited By John Rudd on 15/03/2021 15:41:10 |
noel shelley | 15/03/2021 15:43:59 |
2308 forum posts 33 photos | £650 ! Be lucky to get £150 Idear for tyres relief valve lifts at about 40 PSI. Pumps continuously, no electric cutout. Noel. |
Bob Rodgerson | 15/03/2021 15:45:34 |
612 forum posts 174 photos | Have you priced the cost of a new small capacity Hydrovane compressor. I think that if it is in good working order the asking price might well be reasonable.
Clive Foster | 15/03/2021 15:53:32 |
3630 forum posts 128 photos | Andrew Mine runs professional Bijur Spraymist systems just fine on my lathes and mill. DIY mist coolant systems usually need less air so you should be fine. Use a fog buster design. Clive |
KWIL | 15/03/2021 16:08:07 |
3681 forum posts 70 photos | I do have the manual, but alas my scanner is down at the moment. I also have the bigger HV0* series, but rather more expensive. Originally used to power a constant bleed paint gun around 30psi. There was also a dental model avai;able (because it is so quiet) |
not done it yet | 15/03/2021 16:22:28 |
7517 forum posts 20 photos | Just got a reply on the instructions...£20....Greedy!! Make him an offer of £3 and only buy at £5 tops.🙂. But best wait for KWIL. A pic, with a mobile phone/tablet/camera, and saved as a screenshot is likely good enough for purpose. Especially if emailed at full resolution. |
Andrew Evans | 15/03/2021 23:22:46 |
366 forum posts 8 photos | I think the instruction manual would boil down to 'clean the filter occasionally and change the oil periodically'. I can't see there is anything else to do or go go wrong. |
bernard towers | 15/03/2021 23:37:00 |
1221 forum posts 161 photos | Hi Gary, had mine for over 35 years now and sad to say have never put oil in it (level hasn’t gone down) or cleaned the filter and touch wood is still ok. It was ex BT cable pressurisation comp. |
Emgee | 15/03/2021 23:52:36 |
2610 forum posts 312 photos | Posted by bernard towers on 15/03/2021 23:37:00:
Hi Gary, had mine for over 35 years now and sad to say have never put oil in it (level hasn’t gone down) or cleaned the filter and touch wood is still ok. It was ex BT cable pressurisation comp. Mine also came from a retired BT worker so perhaps it was the std compressor for that job. Emgee |
KWIL | 18/03/2021 10:52:35 |
3681 forum posts 70 photos | Gary Wooding. PM me with your email. I will supply some photos. Note to all, I paid £55 when I bought it new. |
noel shelley | 18/03/2021 11:00:02 |
2308 forum posts 33 photos | You were robbed ! I got mine out of a skip 25 years ago ! Noel. |
KWIL | 19/03/2021 11:26:47 |
3681 forum posts 70 photos | Yes but mine was brand new (60 years ago) not some grubby throw away |
Tiger | 12/07/2021 10:06:37 |
15 forum posts 4 photos | Hi everyone! It's almost four months later and the one for 650 on ebay is still up for sale. I think it will be up there for another ten years. Anyway bought one yesterday for 20 quid. Yes, without finding this post I wouldn't know that it has an oil filter, so a manual would be useful. Powered it up yesterday, to test it. It runs and makes air, though I saw the gauge going up quite fast I turned it off to prevent it blowing up. Now I read here that it has a relief valve, something I was thinking of too that it should have, but couldn't see any so turned it off to protect it. Very silent, took oil level out and oil is a very milky inside. Is that supposed to be white-ish? My main question is, what grade of oil should I get? I can see a net search brings up ISO VG150 for hydrovane compressors. Is that the right oil. Is the oil filter obtainable from somewhere online? I will pop it out once I finish work today. Thanks! P.S: also, I want to the attach the output to a used gas cylinder to have some buffer. Anyone done that? Edited By Tiger on 12/07/2021 10:19:29 |
KWIL | 12/07/2021 10:46:58 |
3681 forum posts 70 photos | Tiger, yes but I run mine attached to an old red floor standing fire extinguisher |
