jon hill 3 | 25/02/2021 14:05:21 |
166 forum posts 40 photos | Looking to replace my old rs lathe work lamp as pivits cannot be sufficiently tightened down, and it has a nasty habit of collapsing while the lathe is running!!! Having made running repairs the caste alloy pivots seem to be fractured and wont prevent movement like they should. I was thinking of a 2nd hand one say a well constructed lamp such as a memlite, what do other members use? Also where can I source one for ideally less than £50 including postage? Fixer uppers are fine as I have plenty of cable, gromits, bulb holders etc.
If anyone has one please pm me .
Jon |
Iain Downs | 25/02/2021 14:06:39 |
976 forum posts 805 photos | I have a couple of clamp LED lights which came from B&Q for around a tenner each.. They clamp to the shelf above the lathe and give a good light. May not suit you, of course! Iain |
Emgee | 25/02/2021 14:31:09 |
2610 forum posts 312 photos | Memlights seem to be collectors items now and do fetch silly money, best to stick with a modern replacement IMO and an extra low voltage (<=50v) lamp will be safer in use especially if the transformer is a separate unit. Emgee |
Frances IoM | 25/02/2021 14:49:29 |
1395 forum posts 30 photos | one simple trick is to stick a length of water proof LED light strip to the splash tray (assuming you have one - Warco WM180 + larger models make it easy with a folded lip on this tray into which the strip can be placed so doesn't shine into ones eyes - gives quite effective local lighting - a small LED on a flexible stalk can then be used for detailed lighting - obviously larger lathes might need more lighting |
john halfpenny | 25/02/2021 14:59:05 |
314 forum posts 28 photos | LED sewing machine lamp, strong magnetic base and flexible arm. I've just bought two from ebay, and very pleased. |
Jeff Dayman | 25/02/2021 14:59:23 |
2356 forum posts 47 photos | Ikea JANSJO led stalk lights were bought and suitable mount plates made for several of my machine tools. Less than $20 each and well made. I am not sure if they still sell JANSJO but a quick look in Ikea website may turn up similar newer models. Have not had any issues with vibration affecting them so far (used for years now). Good value for money , just food for thought. Purpose made machine lights branded as such usually cost much more. |
JA | 25/02/2021 15:07:22 |
![]() 1605 forum posts 83 photos | A few years ago I put an LED kitchen cabinet strip light, from B&Q, above my lathe (just over head height). It is about 55cm long and rated at 20W. It works well but I should have used two. I have looked on B&Q's website but they no longer stock it. In addtion most of their lights use motion sensors to switch them on (not very useful). However ScrewFix sell a sensible range of cabinet strip lights without sensors. I have just bought three for my new bench (details later and elsewhere). JA
Nigel McBurney 1 | 25/02/2021 15:19:18 |
![]() 1101 forum posts 3 photos | Long LED conventional double strip light screwed to shed ceiling,I have the original makers lo volt lamp on my Colchester ,I never use it . |
Georgineer | 25/02/2021 15:21:53 |
652 forum posts 33 photos | Posted by Jeff Dayman on 25/02/2021 14:59:23:
Ikea JANSJO led stalk lights were bought and suitable mount plates made for several of my machine tools. Less than $20 each and well made. I am not sure if they still sell JANSJO but a quick look in Ikea website may turn up similar newer models. Have not had any issues with vibration affecting them so far (used for years now). Good value for money , just food for thought. Purpose made machine lights branded as such usually cost much more. I saw these recommended and bought one to use on my Myford lathe. I was disappointed by the relatively small spread of light and found I was needing to move them around a lot in order to see what I was looking at. I ended up using an adjustable desk light which gave far broader coverage. The Jansjo light would be OK for additional detail lighting. George B. |
Adrian R2 | 25/02/2021 15:32:36 |
196 forum posts 5 photos | Also interested in recommendations - I bought a no-brand flexible LED reading light to use on my lathe a couple of years back and it generated more radio hiss than my VFD and had to be sent back. |
peak4 | 25/02/2021 15:44:40 |
![]() 2207 forum posts 210 photos | I'm mostly using Lidl/Aldi LED clip one reading light fixed on "anglepoise" type arms at the moment. |
Howard Lewis | 25/02/2021 15:47:59 |
7227 forum posts 21 photos | Some of you will have read this before, so apologies. My lathe came in 2003, with a 24 V 50V Halogen light on a gooseneck, attached. Good light, but had an appetite for bulbs. It runs very hot, but removed the "glass" and filed a couple of 8 mm wide slots in the rim of the reflector, to improve ventilation, before reassembly. Can't remember when I last changed a bulb. Just as well, since no around here seems to stock 24V 50W QH! HTH Howard |
Journeyman | 25/02/2021 15:55:40 |
![]() 1257 forum posts 264 photos | Mentioned above but ** IKEA ** have a range od sensibly priced lamps that can be used as is or converted to suit. John |
john halfpenny | 25/02/2021 16:22:32 |
314 forum posts 28 photos | Here's the sewing machine lamp I mentioned above. Two for about £15. |
jon hill 3 | 25/02/2021 16:43:27 |
166 forum posts 40 photos | I am thinking on building a memlite replica as I have a few lengths of square tube and I could re-purpose my existing lamp shade. If I cant use the shade then I could canabolise an ikea lamp. Thanks for all the suggestions.
Oldiron | 25/02/2021 17:17:02 |
1193 forum posts 59 photos | Posted by john halfpenny on 25/02/2021 16:22:32:
Here's the sewing machine lamp I mentioned above. Two for about £15. I have one of those it is good. Was in my stocking a couple of Xmas' ago so not sure where it came from. regards |
Dr. MC Black | 25/02/2021 18:20:20 |
334 forum posts 1 photos | Posted by john halfpenny on 25/02/2021 14:59:05:
LED sewing machine lamp, strong magnetic base and flexible arm. I've just bought two from ebay, and very pleased. I have a couple of these. The first was under a fiver but the second a little more expensive. The warning label is in Chinglish and it took a long time to decipher though! |
Frances IoM | 25/02/2021 18:58:36 |
1395 forum posts 30 photos | "Just as well, since no around here seems to stock 24V 50W QH! have you tried a local coach operator ? 24V would also be used on lorries etc. |
mgnbuk | 25/02/2021 21:49:31 |
1394 forum posts 103 photos | Just as well, since no around here seems to stock 24V 50W QH! What fitting are you wanting Howard ? I have H1 and H3 (IIRC) in 24V flavour on stock & the last fitting I had that used these died a couple of months ago (metal fatigue in one of the joints) - the machine got an LED replacement, so I have replacement lamps but no fittings to use them in. Nigel B. |
duncan webster | 25/02/2021 22:56:58 |
5307 forum posts 83 photos | Posted by john halfpenny on 25/02/2021 16:22:32:
Here's the sewing machine lamp I mentioned above. Two for about £15. I bought 2 of those, direct from China. Electrocution waiting to happen. Inside that metal swan neck are 2 very thin wires with very thin insulation, one is potentially at mains voltage depending on which way the plug is wired. No earth of course. I spent far too much time altering them to run on much lower voltage |
