duncan webster | 28/12/2020 23:37:36 |
5307 forum posts 83 photos | Before I part with my cash, are those three leg spring loaded hone things any use? I'm only trying to improve surface finish in a cast iron cylinder, it's already parallel and a pretty good turned finish. Otherwise I'll set to and make an expanding lap |
noel shelley | 28/12/2020 23:51:03 |
2308 forum posts 33 photos | YES, I have 2 and 3 legged ones. Yes they work well with careful use on a slow speed drill, use parafin as a lube/ flushing agent. Noel |
Pete Rimmer | 29/12/2020 00:02:44 |
1486 forum posts 105 photos | Take care that you don't bell-mouth both ends. Go slow and take measurements often. Edited By Pete Rimmer on 29/12/2020 00:15:46 |
John Olsen | 29/12/2020 00:18:05 |
1294 forum posts 108 photos 1 articles | I agree with Noel, they are very useful. The finish they leave is better for rings to bed onto than a lapped or bored finish. Bell mouthing should not be a problem since you should not be trying to remove a significant amount of material. Move the hone up and down the cylinder as it works, taking care not to come out either end. John |
Hopper | 29/12/2020 04:10:43 |
![]() 7881 forum posts 397 photos | Millions of automotive brake cylinders are honed with these things worldwide every year. They work. Peoples lives depend on them. The linked one looks ok. The cheaper Chinese ones held together with a rubber O ring instead of a proper spring tend to fly apart unless used with scrupulous care and you hold your mouth just right. |
Paul Lousick | 29/12/2020 06:00:42 |
2276 forum posts 801 photos | The cast iron cylinder for my traction engine was bored for a running fit with the piston but after a shrink fit with the engine block (heating in my BBQ for an hour), the ends had shrunk and was too tight for the piston. Although it did provide a good seal and did not leak when tested to 250 psi. I uses a cheap 3-leg cylinder hone to enlarge the bore at the ends, checking the diameter at different places with a dial bore gauge to ensure a constant diameter thruout. Paul. Edited By Paul Lousick on 29/12/2020 06:02:53 |
not done it yet | 29/12/2020 09:41:13 |
7517 forum posts 20 photos | My largest one easily hones a bore of 110mm but I don't have one small enough for brake slave cylinders. |
Oily Rag | 29/12/2020 09:50:50 |
![]() 550 forum posts 190 photos | I prefer a Flex Hone for this type of job. Often referred to as a 'bog brush' for its similarity with the household item. They are more size specific (probably with a range of 5mm of bore size in medium sizes) but also available in small sizes. I have a 12 bore one (0.73" ) and a 16 bore one (0.663" ) for shotgun bores which work very well. Edited By Oily Rag on 29/12/2020 09:51:39 |
Dave Halford | 29/12/2020 11:09:28 |
2536 forum posts 24 photos | The trouble with three leg hones is you need to avoid the temptation to withdraw them too far, thats when they bell mouth. |
Phil P | 29/12/2020 11:18:34 |
851 forum posts 206 photos | They will not correct any ovality in a bore like a true Delapena type hone would, being spring loaded they just follow what is already there. Phil |
Howard Lewis | 29/12/2020 11:44:04 |
7227 forum posts 21 photos | Flex hones are splendid things, capable of reproducing the cross hatch finish of a machine honed bore, in depth and surface finish. But being silicon carbide, the bore needs to be cleaned extremely carefully after use. Otherwise the components will continue to lap themselves for the remainder of their short life! Flex hones tend not to be cheap, and how to get the best from their use needs to be learned. Howard. |
Rik Shaw | 29/12/2020 11:53:34 |
![]() 1494 forum posts 403 photos | I have never used one but a place where I worked years ago did. With the hone fitted to a thing like a very large two handled electric drill the fitter would hone a bored cast iron cylinder to take a cast iron piston that I had ground for him. Pistons varied in size up to 7" diameter and 8" long. The point I would like to make though is that of all the fitters, only one of them had the knack of getting it REALLY right. A hot sweaty job in the summer, Pete certainly earned his wages doing that job. Rik |
Henry Brown | 29/12/2020 12:22:22 |
![]() 618 forum posts 122 photos | I bought the Kennedy version from Zoro (from ebay) about £16 it has two and three legs and covers a lerger range of diameters. It was fine in use and gave a nice finish to the CI bore for my Economy Engine using oily diesel.. |
