Ball ended handle - how to
How to machine a ball ended handle
Jim Beagley21/11/2020 19:38:23
106 forum posts
52 photos
Hi all.
Ive recently made a Hemingway rear toolpost and it calls for a ball ended handle for the lock.
As a result, I’ve now recently finished a Hemingway ball turning attachment which works.
So on to the question: how do I machine the tapered handle with a ball at each end? Maybe three parts? Maybe 2? Maybe 1?
Looking for some guidance.
Thanks all
JasonB21/11/2020 20:10:51
First you need to make a ball turner as so starts the slippery slope.
If you use a ball turner to form balls on either end of a length of round bar that makes it easy to hold. You can then hold buy one ball in a collet or split bush and support the other with a female ctr in the tailstock to turn the central taper. It would probably be best to drill and thread the hole before that while you have the plain shank in the middle to hold. Finally screw the large end onto a threaded arbor to turn the top and bottom faces flat.
Jim Beagley21/11/2020 20:19:44
106 forum posts
52 photos
I’ve got the ball turner Jason - see my post and the lovely ball in the photo
So reading your response, I note that I don’t have a collet chuck, female centre. Bugger!
I supposed I can make a slot Bush easily enough.
So I’m thinking these steps.
Turn small ball.
Turn centre section to max diameter.
Drill and tap hole using centre section on Blocks.
Turn Taper?
Turn big ball using female centre in small ball.
Face big ball using arbours.
Sound about right?
Edited By Jim Beagley on 21/11/2020 20:20:15
DC31k21/11/2020 20:28:51
1186 forum posts
11 photos
Both GHT and DH Chaddock cover this in great detail in their books.
Use a split collet to hold it.
JasonB21/11/2020 20:41:30
I would leave ctr section to max dia of the large ball or slightly over then hold by that to do both balls
Jeff Dayman21/11/2020 21:13:19
2356 forum posts
47 photos
I know many on here think that making this sort of handle is a rite of passage for master toolmakers, and they are entitled to that opinion. For me, ball ended handles are unpleasant to use and a time consuming pain in the neck to make. Far better use of time to make a simple cylindrical hub, with a hole for a lever drilled at the desired angle. Weld or silver solder in an angled rod for a lever with a threaded end, and fit a thread-on tapered or cylindrical or flat handle. (Flat faced and cylindrical tapered handles for things operated and tightened with the fingers often during the day are far more comfortable than balls.) Job done, let the model making continue......
Again just my $0.02 worth.
I have spent much of my working life designing tool components for plastics related machinery, and custom toolroom accessories. If I had ever designed any with the time wasting uncomfortable to use double ball handles I assure you I would get two reprimands - one from the toolroom foreman for wasting machining time, and the second from toolmakers with sore fingers and thumbs from using the bloody things. Pretty, but a really bad handle design. You can Google Misumi, McMaster Carr, Jergens, Essentra etc to see some excellent commercial tooling handle designs. Many have been offered for years and years. Link to some very pleasant to use and cheap ones is below.
https://www.mcmaster.com/handles/handles/comfort-grip-adjustable-handles/
Edited By Jeff Dayman on 21/11/2020 21:22:51
Jim Beagley21/11/2020 21:24:50
106 forum posts
52 photos
Hi Jeff.
I suppose I agree with you to an extent.
For me, the kits are some of my first real engineering, so it’s the challenge more than anything.
I’m self taught, and my work leads a lot of scope for improvement but thats what I aim for.
Ive never made a ball, so I made a ball turning attachment.
Now I want to learn to use it Perhaps eventually il make a governor for my S-50 that takes balls!
Im not familiar with GHT or DH Chaddock mentioned by DC31K, nor do I own their books, so that wasn’t much practical help I’m afraid.
Cheers for all the suggestions thus far
Jim
Andrew Johnston21/11/2020 21:47:16
7061 forum posts
719 photos
If I was going to make the part I'd use a hydraulic copy attachment:
But I agree with Jeff, change the design to something simpler. I made this in less than 10 minutes to demonstrate to a forum member how to make something with nowt more than a rule when dimensions are not important:
In industry I would think that ball handles are frowned on as one can get caught up in them and it's difficult to disentangle oneself.
Hopper22/11/2020 01:17:18
7881 forum posts
397 photos
I've made a number of these ball handles for various toolposts and a teeny one for the Versatile Dividing Head, simply because they look the part on my vintage Drummond and Myford lathes. The later styles as above are easier but stand out like the dog's proverbials as non-original. Besides, the ball handles are fun to make. And I have have no problems using them, not doing 8 hour shifts of production repetition work etc. .
My method needed no special split collets or the like and went, from sketchy memory, something like this:
Start with a blank the diameter of the large ball, and the length of the finished handle plus a few thou or 20 for finishing.
Turn one end of the blank down to the diameter of the small ball for about an inch or so along the length.
With a parting tool, cut a groove to the diameter of the small end of the taper section (plus a few thou for finishing) right where the edge of the small ball will be. (You can probably skip this step if you work carefully in the next step and measure as you go but I like to know where to stop the ball turning tool at.)
Use ball turning tool to create small ball until it meets the groove.
Turn the shank down to the larger diameter of the taper section along its full length to where the large ball will start. IE for a 1" diameter ball, end your cut 1" from the end of the blank, plus a few thou for finishing. You may need a female centre to steady the other end.
Flip the job around in the chuck, gripping it by the freshly turned down but still parallel shank section, and use ball turning tool to create the second, larger ball.
Holding the larger ball in the chuck (with protective shim wrapped around ball), and the small ball in a female centre, turn the taper on the shank, adjusting the topslide angle until you get the right cut from small to large ball. Use a round-nosed tool to make a nice blending radius where shank meets balls. Blend with file if necessary. Polish with emery cloth.
Hold the large ball in the chuck with the arm facing outwards. Put the ball in the very front of the jaws and angle the arm backwards so small ball sits on chuck face. Face the large ball to desired diameter, drill and tap ball. (This works best on a larger chuck for larger handles to get sufficient angle on the handle. My Drummond has a 5" three jaw that is perfect for Myford sized toolpost handles etc)
Job's good. Enjoy.
PS, I made my own female centre by removing the point from a regular revolving centre and turning up my own female tip to fit into the ball bearing in the centre body. Just used a boring bar to cut the female conical face (60 deg included angle) into a piece of 3/4" bar then turned the step, face and the spigot diameter to fit the bearing all in one setting to ensure concentricity and parted it off. You could turn the stepped spigot end first, plus a cleanup cut on the OD then flip it around in the 4 jaw and set to run true before cutting the conical face if you prefer.
Lots o' fun! And I;m sure there are many other ways to skin this same cat.
Edited By Hopper on 22/11/2020 01:41:13
Thor 🇳🇴22/11/2020 04:57:39
1766 forum posts
46 photos
Hi Jim,
Here is a description on how to make ball-handles from Steve's workshop that you may find helpful. And here is another, and a third.
Thor
Adrian 222/11/2020 09:48:48
104 forum posts
19 photos
Hello Jim,
Thor's option one worked well for me . I tapped and counter bored the small ball allowing the tapered shaft to enter the ball, creating a truly undetectable joint. This avoids the need to machine a shouldered joint which may not be truly concentric and give the 'one piece illusion away'.
One thing which doesn't get mentioned much is the need to allow for the swing of the ball turner to avoid conflict with the chuck.
I made one for my tool post, it's a pleasure to use. You will enjoy making it. Ball turning can become addictive.
Adrian.
John P22/11/2020 10:17:27
451 forum posts
268 photos
Hi
It only needs some simple tooling to hold the ball handles
to turn the tapered section between the balls ,the sequence
for making these is shown in the Quorn book the photo is seen here.
I made an extension for the revolving centre that fits over the nose and
has an aluminium working surface a similar cone is fitted and machined
in the chuck ,a driver to hold on the cut ball end can be made from a ring
and two screws with aluminium cones on.
The sequence shown in the photo starts with a plain bar ,the 2 ball ends
turned, fitted between the center supports the topslide set over
to the required angle to turn to the ball ends.
Seen here in the next photo this double ended clamp is held in the chuck.
A spacer between the chuck face and ball is used to set the angle
the large end can have the flat seating turned then drilled and tapped.
DMB22/11/2020 10:54:13
1585 forum posts
Wot a load of balls. Sorry, couldn't resist it.
I recently had a need to make some handles for Harold Halls t n c grinding jig. His design is just like Andrew Johnston's above, except that HH adds a short length of larger dia. bar to the outer end in lieu of the small ball in the ballsup design. The smart way of doing that is to drill the larger dia. bar only part way thro., enough to hold on to the smaller dia., leaving say 2mm blind section before the part off. Reverse in 3 jaw, face smooth round off sharp corner,drill very small dia. hole thro. to bigger drilled hole. Super glue larger dia. on to the end of the smaller dia. and air/excess glue exudes thro. very small hole. Simples! when having made parts without very small hole and find close fit precludes escape of air/glue.
In passing, may I congratulate HH upon his meticulous drawings; not quite completed my jig yet but not found a single error. They are a delight to use. Pity same couldn't be said of many loco. designs
DMB
pgk pgk22/11/2020 11:20:22
2661 forum posts
294 photos
I'd have probably taken the lazy route of making the part up out of three pieces.. drill/tap a spare chunk to fit on a piece of bar.. 3-jaw chuck and make the ball, remove and replace with larger chunk for the larger ball and then make up the tapered centre section, threading one end first before tapering and threading the other end...assemble with threadlock.
It also allows for making a mess and having to repeat a componentdevil
pgk
Nick Wheeler22/11/2020 11:23:28
1227 forum posts
101 photos
I don't see the visual appeal of ball handles, and having read descriptions of the work involved certainly won't be making any.
I have made a couple of handles like Andrew showed, which match the ones on my modern machines, and only take a few minutes turning for the base, and none for the handle which is simply a piece of stock rod loctited in place.
If building a machine that needed a lot of handles I'd buy THESE or something similar
Douglas Johnston22/11/2020 11:27:21
814 forum posts
36 photos
When I built my Quorn grinder many years ago I spent ages making the ball handles. It was a great exercise and the end result was a joy to look at. Over the next few years, however, I replaced most of them with commercial adjustable handles which were much easier to use. I think it is a case of style over substance when it comes to ball handles.
Doug
Rik Shaw22/11/2020 11:38:23
1494 forum posts
403 photos
The last lot of ball ended handles I made were from silver steel rod and ball bearings thus:
Cut silver steel to length and thread as required at one end. The other end was first faced in the lathe and then dished with a ball end slot drill roughly the same diameter as the ball bearing.
Now take a tiny piece of silver solder and hammer it flat to produce a small “flake”. Place the flake on a piece of softwood and give it a whack or two with a hammer driven ball bearing. The aim is to produce a small dish. Pickle the silver steel hollow, ball bearing and solder “dish” in something like very warm / hot lemon juice for a half hour, dry all.
Next, grip silver steel rod in vice jaws vertically with the hollowed out end uppermost. Put a tiny amount of flux in the upward facing hollow and place dished flake on top. Apply a little more flux on top and gently push the ball bearing down on the lot.
I used a fine nozzle on my propane torch to heat it up. Try sitting down while you do it with your eyes level with the ball. Watch carefully and remove heat source when the ball moves slightly into its bed of molten silver solder.
Cool and polish – job done.
Others may do it differently, with paste for instance, but not having any I did it my waynote
Rik
With due acknowledgment to Harold Hall and his design at : Grind Rest, Advanced (homews.co.uk)
Edited By Rik Shaw on 22/11/2020 11:40:56
Evan Lewis22/11/2020 11:47:18
31 forum posts
10 photos
The first turning job I ever did when I inherited this lathe was to make a new cross-slide handle from stainless steel. The firs lathe project in 55 years. The plan was just make something that works. It doesn't have to look authentic.
I like the way it feels but it is not balanced. Unless the gib adjustments are tight the handle drops down to the lowest point due to gravity. So that's what the balls are for. I knew there was a reason we have balls! Gravity. So now I am thinking I have to make a bigger ball, like the song "I like big balls". Maybe if I made it from solid gold it would be heavier.
Neil Wyatt22/11/2020 16:35:54
19226 forum posts
749 photos
86 articles
I was going to mention the GHT approach with form tools and fixtures, but John Pace has covered this.
Jim Beagley22/11/2020 16:58:45
106 forum posts
52 photos
Thanks so much to everyone who has contributed.
Who would have guessed that my problem with my balls would have garnered so much interest.
I shall now attempt to digest all the information and make my choice.
Hopefully I can report back soon with a lovely set of shiny balls which will soon be swapped out for something modern I’m sure my wife will let me put my old balls on the mantelpiece as an object for discussion when the vicar calls for tea .
Cheers all
Jim
