Mark Davison 1 | 25/10/2020 15:14:31 |
134 forum posts 38 photos | I've got the knee off my harrison mill and want to to check the wear on the ways, in particular the narrow ones on the underside. Where can I get a 12" straight edge to apply the blue to? Alternatively any ideas what i can use as an alternative, e.g is gauge plate flat enough? Measuring the side without the V suggests there is some wear in the middle but I'd like to check that the wear is only in the bottom face. |
Clive Brown 1 | 25/10/2020 15:35:34 |
1050 forum posts 56 photos | I'd have thought ground flat stock was usually good enough for your purpose If you wish to check your GFS, buy 2 similar pieces and check them against one-another, faces 1 to 1 and then 1 to 2. |
Andrew Johnston | 25/10/2020 15:42:05 |
![]() 7061 forum posts 719 photos | Rectangular ground flat stock is ground on the wide sides only. The narrow sides are as sawn. Andrew |
Mark Davison 1 | 25/10/2020 17:43:50 |
134 forum posts 38 photos | I'd wrongly assumed all 4 sides would be ground, but apparently not I found this on the interweb. Even the thickness doesnt sound very accurate Thickness +0.05/-0mm
old mart | 25/10/2020 18:20:29 |
4655 forum posts 304 photos | Straight edges do come up for sale regularly on the unmentionable site. |
JohnF | 25/10/2020 18:24:51 |
![]() 1243 forum posts 202 photos | Gauge plate is not guaranteed to “flat” or “straight “ over its length unless ground to be so and I think this is unlikely on commercially produced stock. Better than nothing but IMO not good enough for the job in hand. what you really need is a camel back straight edge preferably with the facility to check the V as well. John Or start from scratch and use 3 pieces to scrap in sequence and end up with a perfectly straight tool for the job Edited By JohnF on 25/10/2020 18:27:44 |
Oldiron | 25/10/2020 18:34:52 |
1193 forum posts 59 photos | Posted by old mart on 25/10/2020 18:20:29:
Straight edges do come up for sale regularly on the unmentionable site. Sorry I do not understand this statement. Ebay is a perfectly legitimate site to mention even if some of the goods are not. regards |
old mart | 25/10/2020 18:41:02 |
4655 forum posts 304 photos | I have had some of my posts deleted even when they were totally innocuous, when listing some of the totally stupid mistakes made by advertisers on the ebay site by certain overzealous moderators on this forum. |
not done it yet | 25/10/2020 18:46:29 |
7517 forum posts 20 photos | And one can post reviews of cheap chinese tat, on the forum, too. |
Mark Davison 1 | 25/10/2020 18:48:23 |
134 forum posts 38 photos | Nothing on evilbay at the moment, other than a pair of 12" long chesterman parallels, which would do at push but they are £90 posted (with some surface rust). Ive seen cammel back castings but need something ready to use. I'm thinking I'll have to buy one of Chronos' 400x400 granite surface plates and sit it on there upside down on 4 1-2-3 blocks to allow for the v. That way I can use a dti on my scribing block. Becoming a bigger job than I'd expected. My current surface plate is only 8"x12" so not big enough. |
old mart | 25/10/2020 19:41:51 |
4655 forum posts 304 photos | I bought a 24" square cast iron table a year ago for a bargain price, but after getting it in the back of my Corsa D, I hurt my left shoulder and it still isn't right. The plate just fitted in the car without dropping the rear seats and very fortunately, there were four 3/8 unf holes through the top. I screwed in lifting lugs and got it out with the engine hoist at the museum. It is very useful. For home use, I would recommend the biggest second hand plate that can be managed and afforded. With a cover on most of the time, it is a worktop not a liability. |
peak4 | 25/10/2020 19:51:46 |
![]() 2207 forum posts 210 photos | An 8"x12" surface plate would enable you to blue and scrape something longer if you do it across the diagonal. Bill |
Pete Rimmer | 25/10/2020 19:53:28 |
1486 forum posts 105 photos | Gauge plate is not suitable as a scraping reference normally because it's aspect ratio is too high, meaning it will bend under it's own weight. It might get you close but it'll sag in the middle if you support it at each end. For a 12" straight edge look on ebay for kblastmetalworking. He sells 12" versions pre-machined for £180 which need scraping on a surface plate. I have one and it's very nice, a bit softer iron than your usual straight edges but that only makes it easier for the novice to scrape in and I have yet to get any wear in mine which is 3 years old. fOr sure, it's been very stable. That said, checking for wear is only the start. Knee ways wear at the ends so expect your straight edge to rock, which can give up a false print if you're not careful. Then once you have determined where the wear is you need to determine how to scrape it so that it ends up in alignment with no droop or twist. It's not enough to make a way flat - you need to make it flat and pointing the right way too. The alignment on a milling machine is much more critical than on a lathe because the part moves, not the tool. On a lathe you can have a lot of wear and still get good dimensional parts, not so much on a mill. |
peak4 | 25/10/2020 21:17:53 |
![]() 2207 forum posts 210 photos | Posted by peak4 on 25/10/2020 19:51:46 Sorry, the link to Flickr on the original post was wrong, I thought I'd checked it. Bill |
Mark Davison 1 | 25/10/2020 23:05:33 |
134 forum posts 38 photos | You clearly spent a lot of time on that grinder, great work. I intend to play safe and only tickle small areas with a scraper if it is obvious that I'll improve things. The saddles get a bit tight at either end of its travel and im hoping most of that is caused by wear on the narrow flat ways under the knee. I think it is 0.035mm based on the mic readings. I don't want to go anywhere near the top surface of the knee and certainly not the v! I'm not feeling that brave at the moment. Edited By Mark Davison 1 on 25/10/2020 23:05:50 |
peak4 | 25/10/2020 23:37:49 |
![]() 2207 forum posts 210 photos | Posted by Mark Davison 1 on 25/10/2020 23:05:33:
............... I don't want to go anywhere near the top surface of the knee and certainly not the v! I'm not feeling that brave at the moment. Edited By Mark Davison 1 on 25/10/2020 23:05:50 I can understand why, particularly if your mill is essentially usable. I made a clamp holder to use them end on, as you saw on Flickr. I also cut one in half and silver soldered it to a length of bar for a wider scraper. Sharpening & honing are obvious from the album. |
JasonB | 26/10/2020 19:01:26 |
![]() 25215 forum posts 3105 photos 1 articles | Cutwel do straightedges in Stainless, tool steel and granite. Steel ones are good to around 3 microns for a 300mm long one, granite is a bit better than that. at 3 microns on a 500mm length. |
Mark Rand | 26/10/2020 21:16:36 |
1505 forum posts 56 photos | Deleted Edited By Mark Rand on 26/10/2020 21:17:47 |
Nick Clarke 3 | 27/10/2020 11:21:43 |
![]() 1607 forum posts 69 photos | While not certain if a straightedge would be wide enough for what you want both Zoro tools and Chronos, amongst others no doubt, list them in various sizes. In your position I would probably go for the small surface plate. |
Howard Lewis | 27/10/2020 15:28:34 |
7227 forum posts 21 photos | My 18" straight edge came from Cromwell Tools. If you are in UK, there should be a branch somewhere near you. Howard |
