Robin Graham | 08/10/2020 23:14:57 |
1089 forum posts 345 photos | I've been using Tenacity 5 with SF55 to join both steel/steel and brass/brass joints. It seems to work, and I like it because when it it melts and flows I know that the parts are close to temperature. However, planning an emergency dash to my local ME supplier tomorrow for supplies of SF55 I looked at their catalogue and noticed they they list Easy-Flo flux as suitable for SF55, Tenacity 4A without any qualification, and Tenacity 5 for joining stainless steel. Question is - apart from the slightly higher cost of T5, is there a downside to using the stuff as 'one flux fits all' with SF55? Robin.
Bill Phinn | 08/10/2020 23:22:12 |
1076 forum posts 129 photos | Posted by Robin Graham on 08/10/2020 23:14:57:
Yes, Robin. I quote from Johnson Matthey's own blurb: "The flux residues of this product are virtually insoluble in water. Immersion in a warm (>40 ̊C) 10% sodium hydroxide solution for 30 minutes followed by brushing in a stream of water is recommended. The residues are hard and will also respond well to mechanical removal methods such as grit blasting." It's not called "Tenacity" for nothing. |
JasonB | 09/10/2020 06:57:34 |
![]() 25215 forum posts 3105 photos 1 articles | The Upside is that T5 or HT5 will stay active longer so better for larger components that may take a while to get upto heat where standard flux will get exhausted. |
Brian H | 09/10/2020 07:08:25 |
![]() 2312 forum posts 112 photos | I use Tenacity 5 for everything and, although JM's advice is sound, I find that the residues will often come away just by soaking in hot water and a wire brush or scraper. If the heating has been prolonged then they can be more difficult to remove. I always mix Ten 5 with a drop of washing up liquid as per an old Rolls-Royce Aero procedure, maybe that helps to soften used flux. I also use meths instead of water to mix the flux because when the water boils it often removes the flux right at the point when you need it the most. Brian |
Clive Brown 1 | 09/10/2020 08:56:05 |
1050 forum posts 56 photos | I've always thought that Easy Flo flux was slightly more active than Tenacity, so, within it's temperature range, was more reliable. JM also say it is more fluid and sticks well to hot solder rods, hence perhaps a bit easier to use. However, whatever works for you. |
Bo'sun | 09/10/2020 09:37:22 |
754 forum posts 2 photos | Used Borax as a flux some years ago (in an emergency). Seemed to work OK at the time, but I can't vouch for the integrity of the joint. Maybe I was just lucky. |
Circlip | 09/10/2020 10:16:01 |
1723 forum posts | "Used Borax" Another old alchemists trick. Me too, Seems I've been lucky too Regards Ian.
Edited By Circlip on 09/10/2020 10:18:13 |
mechman48 | 09/10/2020 14:05:32 |
![]() 2947 forum posts 468 photos | Posted by Circlip on 09/10/2020 10:16:01:
Edited By Circlip on 09/10/2020 10:18:13 It seems that 'Borax' is still in general use by silver smiths & jewelry makers having looked at a few 'YouTube' videos, they have shown 'Borax cones' that they mix up in a wet solution ( Water ). They seem to vouch it is still quite an effective flux. I have also seen the silver smith on the 'Repair shop' programme that used borax, IIRC it was to re- silver solder a regimental badge back on to a 'Swagger stick' George.
Bo'sun | 09/10/2020 15:33:28 |
754 forum posts 2 photos | Devils Advocate here. Might we be paying "over the odds" for something with a fancy sounding name? Far from an expert, but just wondering. |
Simon Williams 3 | 09/10/2020 16:44:31 |
728 forum posts 90 photos | Horses and courses again. Borax (if I remember right) only works at red heat, using it in conjunction with low temp' silver solders doesn't work well. Good for gold soldering. OK on soldering Sterling silver, but bog standard yellow silver solder doesn't get hot enough to enter the range where borax is active. EasyFlow Flux is suitable for low temperature (dull red heat) solders, easy to clean but exhausts quickly, and is intolerant of dirt. Tenacity solves some of these problems but is a devil to clean up. Tenacity will wet stainless steel (and some carbides), EasyFlow won't. More complication comes when working with stuff for hall marking, and where the sequence of assembly means subsequent soldering operations, possibly at (slightly|) reducing temperatures. Easyflow won't survive being heated twice, Tenacity will. For different grades of Tenacity, I'll defer to the maker's blurb. |
Robin Graham | 09/10/2020 23:11:14 |
1089 forum posts 345 photos | Thanks. From what has been said it seems the only real downside to using T5 for everything is the difficulty of cleaning up afterwards. I have been using a caustic soda solution, which seems to do the job. So I shall stick with it. Like Brian I use alcohol rather than water for mixing the flux, then let it flame off before applying serious heat. Robin. Edited By Robin Graham on 09/10/2020 23:12:03 |
Graham Stoppani | 11/10/2020 06:43:30 |
![]() 157 forum posts 29 photos | Does anyone use killed spirits (zinc chloride) as a flux? |
JasonB | 11/10/2020 07:27:39 |
![]() 25215 forum posts 3105 photos 1 articles | Killed Spirits is OK for soft solder jobs but not Silver soldering, Bakers Fluid is similar and often used particularly on sheet metal work. |
Dominic Bramley | 11/10/2020 08:17:21 |
60 forum posts 1 photos | Posted by Robin Graham on 09/10/2020 23:11:14:
Thanks. From what has been said it seems the only real downside to using T5 for everything is the difficulty of cleaning up afterwards. I have been using a caustic soda solution, which seems to do the job. So I shall stick with it. Like Brian I use alcohol rather than water for mixing the flux, then let it flame off before applying serious heat. Robin. Edited By Robin Graham on 09/10/2020 23:12:03 I would like to try this - Is standard pink Methylated spirits OK for the job? Regards Dom |
Brian H | 11/10/2020 08:57:59 |
![]() 2312 forum posts 112 photos | Not quite sure about pink meths, mine is blue/purple. This is fine as long as you don't keep reactivating dried flux as this can cause excessive contamination. I prefer to use a non-coloured material such as Isopropanol. This can be used to re-activate flux that has dried out in a container. Brian |
SillyOldDuffer | 11/10/2020 09:24:00 |
10668 forum posts 2415 photos | Posted by Dominic Bramley on 11/10/2020 08:17:21:
... Is standard pink Methylated spirits OK for the job? Regards Dom It's fine. The amount of dye in meths is tiny and makes no difference to the flux. The advantage of using alcohol rather than water to mix the paste is it boils or burns off almost the instant the flame is applied, leaving the flux to do it's job. Water takes a tad longer because it has to be boiled off before the flux activates. My brazing experience is very limited, but my learner gut feel suggests alcoholic paste is good for smaller jobs, say up to 100g of metal, but water is just as effective above that. Getting enough heat quickly on to the job with a suitably big torch and/or insulation is probably more important than the paste fluid. Slowly cooking a joint with a small torch deactivates the flux before the silver solder is hot enough to run. The results are miserable. Dave
Dominic Bramley | 11/10/2020 09:46:54 |
60 forum posts 1 photos | Thanks Dave - will give that a try next time. It was the smaller pieces I had in mind - my last soldering job was a tiny part and it was quite an amusing exercise trying to keep the bit of solder from wandering off when the water boiled. It was almost like it as deliberately trying to annoy me! Dom |
JasonB | 11/10/2020 10:08:07 |
![]() 25215 forum posts 3105 photos 1 articles | It's not the time it takes for the water to boil off it is the act of boiling itself that makes the flux bubble and spread to where you don't want it, this does not tend to happen when the liquid is burnt off. |
