Nick Clarke 3 | 28/09/2020 10:42:21 |
![]() 1607 forum posts 69 photos | Needing some for the day job, is 3/16 (or metric equivalent) cast iron bara commercial product? Through a scientific equipment supplier it is silly money so am looking to see if an alternative is available |
Stuart Bridger | 28/09/2020 11:06:06 |
566 forum posts 31 photos | 25mm seems to be the smallest diameter stocked by most suppliers |
Rik Shaw | 28/09/2020 11:15:43 |
![]() 1494 forum posts 403 photos | If I wanted cast iron that small I would find myself an old fire grate basket and turn down some of the bars. Rik |
Speedy Builder5 | 28/09/2020 11:33:56 |
2878 forum posts 248 photos | I seem to remember having that stuff at School, experiment to show how steel expands and contracts on cooling. A bar was heated between a couple of fixed points, a test piece of cast iron was slipped into an eye of the bar at one end and as the bar contracted on cooling, it would snap the test piece. |
Circlip | 28/09/2020 11:42:41 |
1723 forum posts | Can't get into scrap yards anymore, sash weights must be breathing a sigh of relief. Do you know anyone with a broken machine vice??? Regards Ian. |
JasonB | 28/09/2020 11:49:18 |
![]() 25215 forum posts 3105 photos 1 articles | I've never seen 3/16" sash weights and not seen CI bar sold in smaller than 25mm |
Circlip | 28/09/2020 11:56:35 |
1723 forum posts | Well turn it dear Elmer dear Elmer well turn it dear Elmer dear Elmer turn it! Ian. |
Brian Wood | 28/09/2020 12:27:37 |
2742 forum posts 39 photos | Circlip, What a heap of cast iron turnings that would create bringing a sash weight down from about 35 mm diameter to a little under 5mm while at the same time hoping it isn't full of inclusions and holds together while you are working on it. It is a curious requirement anyway and even in sound material it will be about as fragile as egg shell in that size. I doubt you could machine it successfully over a length beyond an inch or so. Maybe Nick's scientific supplier is quite right to charge properly for such material! Brian |
Nigel Bennett | 28/09/2020 13:09:40 |
![]() 500 forum posts 31 photos | 3/16" cast iron would present great difficulty in manufacture, as it would chill spectacularly and you'd end up with something ferrous that would snap if you looked at it. It would also be extremely difficult to machine. It's simply not practical to make it. Having said that, if some multi-national wanted to produce it by the mile, they'd find a way of doing it. So I'm afraid you're going to be knee-deep in cast iron dust! |
Nick Clarke 3 | 28/09/2020 13:41:40 |
![]() 1607 forum posts 69 photos | I seem to remember having that stuff at School, experiment to show how steel expands and contracts on cooling. A bar was heated between a couple of fixed points, a test piece of cast iron was slipped into an eye of the bar at one end and as the bar contracted on cooling, it would snap the test piece.
3/16" cast iron would present great difficulty in manufacture, as it would chill spectacularly and you'd end up with something ferrous that would snap if you looked at it. It would also be extremely difficult to machine. It's simply not practical to make it. Having said that, if some multi-national wanted to produce it by the mile, they'd find a way of doing it. Is exactly what I would like to use it for, but not at £12 for 6x2" pieces |
Pete White | 28/09/2020 14:37:24 |
223 forum posts 16 photos | I went to a poor school, no snapping of cast iron there. We had a bar between fixed supports,with a threaded end, the strongest lad in the class would tighten the nut, after heating a slight slender girl would then come on stage and tighten the nut more with ease. You would have to pick the participant differently these day of course and do a full risk assessment due to the heat. I remember it well,I was that lad, reined by self confidence for years. lol Pete p.s. now we have the whole horse to ride, can I suggest that it doesn't have to be cast iron? |
Frances IoM | 28/09/2020 15:27:25 |
1395 forum posts 30 photos | does it have to be round - I have a couple of feet of 6" by 1" cast iron which was easy to get though relatively expensive as compared to steel - saw off 5mm or so then slice on a mill or saw into square section ? |
Nick Clarke 3 | 28/09/2020 16:21:09 |
![]() 1607 forum posts 69 photos | Posted by Pete White on 28/09/2020 14:37:24:
p.s. now we have the whole horse to ride, can I suggest that it doesn't have to be cast iron? The issue is that it has to be something that doesn't break according to the children's perception, so no plastic, glass or ceramic and that doesn't leave a lot that appears to be unbreakable and strong, but where there is sufficient force as the bar expands or contracts to snap the sample. |
Brian H | 28/09/2020 16:30:40 |
![]() 2312 forum posts 112 photos | Cast iron welding rods are available in 6mm; the problem will be getting a small quantity, unless you need a box full! Brian |
Nick Clarke 3 | 28/09/2020 16:39:59 |
![]() 1607 forum posts 69 photos | Posted by Brian H on 28/09/2020 16:30:40:
Cast iron welding rods are available in 6mm; the problem will be getting a small quantity, unless you need a box full! Brian I didn't realise they were cast iron - I thought they were high nickel steel |
Brian H | 28/09/2020 16:46:42 |
![]() 2312 forum posts 112 photos | Cast iron can be welded with either a nickle filler of an S.G. iron one. SIF seem to do S.G. iron rods in either 6 or 10mm Hope that helps Brian |
not done it yet | 28/09/2020 16:54:12 |
7517 forum posts 20 photos | I would expect a short length of suitably heat treated high carbon steel would fail with a suitably sudden and noisy mode of failure? Maybe there might be a few flying fragments, safety pecs and behind a screen for them and also some for you should suffice. Care with safety is possibly one reason for the high price of basically a shear pin. Do you pour cold water over the heated bar to speed things up?🙂 Sleight of hand is a good ploy for experiments such as this - distribute rusty examples of annealed pins for some to try and break, but use a ‘hard as glass’ pin in the experiment. I used to do the same with a challenge of catching a small rod as it fell through and out of a copper pipe. The magnet had to look like the rod.🙂 Edited By not done it yet on 28/09/2020 16:54:45 |
Frances IoM | 28/09/2020 17:22:23 |
1395 forum posts 30 photos | another source of cast iron is brake pads - just looked at a set of 4 I bought for a ?1 at auction in case I could use them looks about 10mm slab bonded to the steel carrier - maybe local garage can supply some worn pads |
JasonB | 28/09/2020 17:27:41 |
![]() 25215 forum posts 3105 photos 1 articles | I would not have thought a SG Iron rod would break like a grey iron one. The experiment should work with say 25mm long rod which would not be hard to turn from some sliced up larger good quality grade 260 bar |
John Reese | 29/09/2020 05:35:13 |
![]() 1071 forum posts | I have a large amount of cast iron welding rod (R-CI). It is about 3/16" dia. The finish is sand cast and the halve are slightly offset (mold mismatch). I don't see how they could be used for anything but welding. If you need a smooth cast iron rod I suggest you find a larger diameter and set up a hollow mill on the lathe to reduce the diameter. |
