Anyone recognise these.
Cutting tools
Steviegtr24/09/2020 18:39:23
2668 forum posts
352 photos
Does anyone know what these cutters are & what they are used fo. They came with a lot of milling cutters that i bought some time ago.
Steve.
Kevan Shaw24/09/2020 18:45:36
20 forum posts
6 photos
They all look pretty boring to me
the one in your hand looks like it has a broken insert. They could be used in a boring head in a mill or in a lathe.
Steviegtr24/09/2020 18:47:23
2668 forum posts
352 photos
Posted by Kevan Shaw on 24/09/2020 18:45:36:
It does look broken but it is how the cutter is made. Seems to be a radius type thingy.
Steve.
Edited By Steviegtr on 24/09/2020 18:53:52
JasonB24/09/2020 18:52:34
The one in your hand looks like an insert ball nose cutter, one to the right of the line up an insert CSK/chamfer cutter. The others insert end mills
V8Eng24/09/2020 18:53:08
1826 forum posts
Posted by Steviegtr on 24/09/2020 18:47:23:
Steve.
Maybe a ball nosed milling cutter.
edit: Jason types faster than me!
Edited By V8Eng on 24/09/2020 18:54:02
Emgee24/09/2020 18:56:15
2610 forum posts
312 photos
The 2 on the left could be single point milling cutters.
Emgee
Steviegtr24/09/2020 18:57:40
2668 forum posts
352 photos
Posted by JasonB on 24/09/2020 18:52:34:
So would the ball nose cutter be used on the edge of a piece of work creating a radius where a corner would be.
Dave Halford24/09/2020 19:02:39
2536 forum posts
24 photos
All for the mill
Two APKT type insert cutters, one radius cutter, one bull nose and lastly a 45deg for truing your lathe tailstock etc or a counter sink
jimmy b24/09/2020 19:08:49
857 forum posts
45 photos
As Dave says.
Jim
JasonB24/09/2020 19:09:06
Posted by Steviegtr on 24/09/2020 18:57:40:
Yes or more likely to machine a curved surface either on a copy machine or cnc by of setting each pass by a small amount the rounded edge leaves many small scallops rather than steps that a square edges cutter would.
Steviegtr24/09/2020 19:18:03
2668 forum posts
352 photos
Thanks for all the replies.
Steve.
David George 124/09/2020 19:41:27
2110 forum posts
565 photos
Hi Steviegtr what diamiter is the radius cutter tip as I may have a tip spare from when I worked in the real world. They were used to cut out cavities in mould tools, in pre-hardened steel, for the plastic industry. On a CNC mill they ran at high spindle speed and feed but only moved over a small amount to create a fair finish. If it fits your holder you are welcome to it.These are 16mm diamiter
David
Edited By David George 1 on 24/09/2020 19:57:23
Steviegtr24/09/2020 20:24:36
2668 forum posts
352 photos
Hi Dave I will check later. Just out at bikers cafe with mates.
Thanks for the offer.
Steve.
Brian Oldford24/09/2020 20:30:03
686 forum posts
18 photos
They look quite dangerous to me. Send them here immediately for safe disposal. laugh
Steviegtr24/09/2020 22:41:00
2668 forum posts
352 photos
Posted by David George 1 on 24/09/2020 19:41:27:
David
Yes David indeed they are 16mm. I will gladly pay for the item & the postage if you want me to send you a P.M
Steve.
