Big lumps of Cast Iron
fizzy26/03/2020 20:27:03
1860 forum posts
121 photos
As a hobby project (as well as the 1:6 ratio WW2 Tank build!) im making a quite large Compound Stationary engine. I need some biggish lumps of cast (hate ali so not using it) for the base and cylinders, roughly a 6 inch cube would do. Before goung to a foundry and having things made for me I wanted to see if anywhere sold these things off the shelf. I can get ingots but thats no use to me. Any suggestions please?
Nick Clarke 326/03/2020 20:36:09
1607 forum posts
69 photos
College Engineering Supply in Tipton in the West Midlands list 150mm and 200mm square
David George 126/03/2020 20:40:48
2110 forum posts
565 photos
Try M Machine Metals they cut to size and Usualy quick delivery. http://www.m-machine-metals.co.uk/
David
Dave Halford26/03/2020 21:03:07
2536 forum posts
24 photos
Rapid Metals do huge blocks of cast iron, a tidly 6" cube might be in the scrap box Currently closed due to our daily nightmare.
Iain Downs26/03/2020 21:46:19
976 forum posts
805 photos
I think Metals for U also do cast iron in large sizes.
Iain
Paul Lousick26/03/2020 22:06:03
2276 forum posts
801 photos
Round sections of commercial cast iron bar are more readily available if you cannot get square. It would be cheaper than having something specially cast.
Paul.
lfoggy27/03/2020 16:25:49
231 forum posts
5 photos
I purchased a peice of cast iron around that size on ebay last year. It was an offcut from a workshop. Not that expensive either.
noel shelley27/03/2020 17:46:15
2308 forum posts
33 photos
If you know what you want and can make a pattern then a casting would be the way to go ! If the idea appeals and you need help PM me, it could save a lot of machining.
Best wishes Noel.
Chris Evans 627/03/2020 19:54:33
2156 forum posts
You only need to make a polystyrene pattern for one offs, I do so often. Biggest problem is finding a foundry that will do a cash job.
Howard Lewis28/03/2020 12:53:35
7227 forum posts
21 photos
Not a lot of good while we are all confined to barracks, but if you can manage with something less than a 6" cube, I have bits cut from a fairly hefty engine flywheel that you could have, just to liberate the space.
