Centec 2a Gear Box Oil
martin cross 120/01/2020 21:15:28
43 forum posts
59 photos
Hi, I've seen the odd thread on this subject relating to CY2 oil but I have come across another 2A document which says use vitrea 41. I am assuming one is a later edition and the vitrea 41 is the choice.
There is a site https://www.alexoil.co.uk/content/7-shell-pre-iso-iso-lubron-oil-reference-guide which gives you a Lubron equivalent to v41 as Lumach 100 available in 1lt and upwards.
Reckon 2lts will suffice.
not done it yet20/01/2020 21:55:59
7517 forum posts
20 photos
Lubrication has moved on in 70 years. A good iso equivalent will be fine.
Steviegtr20/01/2020 22:02:59
2668 forum posts
352 photos
Well I know a lot of Classic british bike owning guys. They all use the old Mineral straight oil. I have many times said why on earth don,t you put some semi synthetic oil in. The answer is always that you cannot because the engine tolerances & the way it is lubed will not work.
Paul Kemp20/01/2020 22:13:19
798 forum posts
27 photos
Smith and Allan will have something suitable.
Paul.
not done it yet20/01/2020 22:37:51
7517 forum posts
20 photos
Posted by Steviegtr on 20/01/2020 22:02:59:
It’s a gearbox, not an engine? Modern engine oils don't contain zinc additives, for a start.
Steviegtr20/01/2020 22:56:13
2668 forum posts
352 photos
Ah did not realise it was a gearbox. Oops
Steve.
geoff adams21/01/2020 12:52:20
214 forum posts
207 photos
Hi Martin been out to workshop my centec 2a brass plate says shell vittrea 41 or mobil oil heavy went to my local motorist discount center they got on the internet and came up with an substitute ep 80w 90 gear and differental
hope this helps Geoff
peak421/01/2020 13:03:57
2207 forum posts
210 photos
Posted by geoff adams on 21/01/2020 12:52:20:
Geoff, I'd be wary about using an EP gear oil in anything with bronze bushes.
I believe Vitrea 41 equates to a plain ISO100 weight gear oil
Bill
geoff adams21/01/2020 14:07:15
214 forum posts
207 photos
hi peak4 i can only go by the info given to me would be interested to known why i should be wary of ep oil with brass bushes ?
any thanks Geoff
Dave Halford21/01/2020 16:08:34
2536 forum posts
24 photos
There are no bronze bushes in the Centec smiley
Plasma21/01/2020 16:27:40
443 forum posts
Curiously I have just renovated a 1947 vintage hay mower which has a Villiers 2 stroke petrol engine driving a steel worm and brass wheel transmission.
The manual states to use SAE 30 oil as the 2 stroke mixer, and crucially says to use the same grade of oil in the gear box.
When I stripped it the gear box definitely had thick gear oil in it. Something the manufacturer warned against. Mainly because the internals are splash lubricated.
I would have put money on using a specific gear oil but Pennine lubricants echoed exactly what the engine manufacturer said in 1947.
Bough a 5 litre can of classic car SAE 30 for 24 quid, job done.
Mick
Thor 🇳🇴21/01/2020 16:39:26
1766 forum posts
46 photos
Posted by geoff adams on 21/01/2020 14:07:15:
any thanks Geoff
Some EP additives can attack yellow metal alloys, see here.
Thor
Oldiron21/01/2020 16:52:16
1193 forum posts
59 photos
Posted by Steviegtr on 20/01/2020 22:56:13:
Steve.
Steve The clue is in the thread title. wink
regards
not done it yet21/01/2020 16:53:26
7517 forum posts
20 photos
Morris Minors used engine oil. So did BMC Minis. Note that automatic minis did not like low viscosity or too-slippery oils. The 80/90 gear oil was not quoted as an EP variant so would not eat yellow metals. 80/90 gear oil is about the same viscosity as SAE 30 engine oil.
One reason why folks stick with single viscosity oils is because they are likely non-detergent. Changing to a detergent oil might well clean all the sedimented sludge, accumulated in the engine, and hold it in suspension.
T.B21/01/2020 17:15:11
54 forum posts
21 photos
Posted by Dave Halford on 21/01/2020 16:08:34:
I can't remember about the main column gear box , but the MK3 vertical head certainly has bronze parts and the VH requires the same type of thick oil as the column gear box , so it would make sense to have one oil to use on both !
martin cross 121/01/2020 17:31:29
43 forum posts
59 photos
Having re read the manual I now have. It does refer to spindle drive and gear box. ‘shafts in the gearbox are well supported by ball bearings’. No mention of bronze anywhere.
martin cross 121/01/2020 18:46:20
43 forum posts
59 photos
Thought this might be of interest. 2A internals.
Dave Halford21/01/2020 19:10:12
2536 forum posts
24 photos
Posted by T.B on 21/01/2020 17:15:11:
This Centec is horizontal only and I don't have a Mk3
