Opening a Port
Mill or Grind
martyn nutland31/12/2019 07:44:07
141 forum posts
10 photos
A Peaceful and Healthy 2020 to All
A very simple question...I need to enlarge the inlet ports on my Austin Seven exhaust manifold. It's cast iron of course. Would you recommend doing this with an end mill, slot drill or with a stone (perhaps even with a Dremel attachment).
Many thanks in advance.
Martyn
John Haine31/12/2019 07:50:02
5563 forum posts
322 photos
Unless you can clamp it to the mill table don't even think of using an endmill or slot drill, it will be uncontrollable.
A rotary burr or grinding point may work.
Inlet ports on exhaust?
JasonB31/12/2019 08:03:07
Well the exhaust gasses must go IN one end and out the otherwink
The exhaust and inlet manifold is all one casting so could well be in inlet tract that is being worked on.
Die grinder would be best but Dremel will do, carbide burrs for heavy removal and then smooth with a stone one.
Edited By JasonB on 31/12/2019 10:14:22
Henry Brown31/12/2019 08:24:40
618 forum posts
122 photos
Look for a 6mm Foredom on ebay, not cheap but with the correct burrs for ci you will be fine. I always buy Garryson, the cheap ones often don't last long.
Brian H31/12/2019 08:30:31
2312 forum posts
112 photos
There are several questions here;
Why do you want to enlarge the ports? unless you are building a 750 racing engine.
How much metal do you want to remove?
Why mess with prewar components? surly the idea of owning a prewar car is to keep it as original as possible.
James Alford31/12/2019 09:04:53
501 forum posts
88 photos
Ian,
It may be worth having a chat with Ian at Oxfordshire Sevens **LINK**. I know that he has been rebuilding and tuning a fair few Austin Seven engines of late and testing them on a dynamometer. He has also built a few successful racing Seven engines. He may be able to give you some suggestions.
Jamie.
not done it yet31/12/2019 10:42:45
7517 forum posts
20 photos
Simply matching the areas of the ports might be a better term. Matching to the head will not greatly alter the power but may well help the economy. Many manifolds, back then, did not provide a smooth transition to the exhaust.
I suppose many considered the inlet side as the important one - where gases have to find their own way into the engine cylinders (maximum pressure difference of one atmosphere), while the exhaust gases were actively shoved out by the piston (as well as starting at rather higher pressure when the valve opened).
Grindstone Cowboy31/12/2019 11:11:22
1160 forum posts
73 photos
As long as the bit you are going into has a larger hole than the bit you are coming from (e.g. inlet port in head is larger than the hole in the mating face of the inlet manifold), the 'step' is pretty much irrelevant, and on the inlet side can help atomise any fuel droplets. Gasket can be matched to either. Hope I've explained that clearly.
Happy New Year,
Rob
Phil P31/12/2019 12:20:34
851 forum posts
206 photos
I have just done a port matching exercise on a spare 1098 A series engine for my Morris Minor.
It was surprising just how bad they were when I took templates form each part.
I used a solid carbide burr in a die grinder on mine, and it was very effective and quick to do the job.
Phil
martyn nutland31/12/2019 12:30:39
141 forum posts
10 photos
Many thanks everyone.
Inlet.
Dremel
Especial thanks to Grindstone Cowboy. You seem to understand exactly what I want.
By the way Brian...I'm not into 'messing' with pre-War components. That is normally anethema to me. I'm just using conventional (pre-War if you like) engineering methods to try to improve an extremely poor aspiration system as thousands of Austin Seven Special builders have done since pre-War days!
Thanks again everyone. Bonne année from warm and sunny Paris.
Martyn
Phil P31/12/2019 13:33:50
851 forum posts
206 photos
I would not try and polish the inlet tract, the fuel might not atomise properly, it needs some turbulence to stay suspended in the air flow.
I successfully opened out the inlet ports on my A7 RTC special engine, it had standard inlet valves but very narrow seats.
Phil
Edited By Phil P on 31/12/2019 13:47:42
Stueeee31/12/2019 16:52:42
144 forum posts
Opening out the inlet valve throats is well worth doing on an A7 motor. A simple pilot cutter can be made on a lathe very quickly; you can use a reground broken centre drill as the actual cutter. Also, there is no radius on the roof of inlet port where it meets the valve throat. It has been proved again and again that the bulk of the gas flow in an inlet port is in this area -the so-called "short side radius". As it left the factory this area is a sharp right angle rather than a radius. A bit of work here with a burr or mounted grinding point will have good results.
The improvement in the inlet ports can be seen in this photo.
Phil P31/12/2019 17:28:17
851 forum posts
206 photos
Plus the removal of the sharp corner at the top of the cylinder bore near the valves which I forgot to mention.
Mine had unleaded exhaust seats fitted which precluded fitting larger inlet valves, but enlarging the throats is an excellent way of getting better gas flow.
Phil
Edited By Phil P on 31/12/2019 17:30:16
vintage engineer31/12/2019 20:33:22
293 forum posts
Try to not take too much material from the inlet ports as they way too big as standard to get optimum gas flow. If you are not competing in VSCC events, dividing the ports into four makes a big improvement.
old mart31/12/2019 21:15:37
4655 forum posts
304 photos
I used to do all my porting on motorcycles by hand with riffler files. Matching the profiles of bolted together components is best done with the help of thin card cutouts like gaskets, using the stud / bolt holes for alignment. One for each part, and when they are put together, it is easy to see the mismatches, and decide where the metal is to be removed.
Phil P31/12/2019 23:58:02
851 forum posts
206 photos
You just reminded me that I took a photo of that process.
The red aerosols in the background are a crack detection kit, the A series heads are prone to cracking so I thought it best to check before doing a load of work on it.
Edited By Phil P on 31/12/2019 23:59:38
martyn nutland01/01/2020 07:28:53
141 forum posts
10 photos
Again, very many thanks for all the advice and practical guidance. This accords with everything I have read and studied on the subject of enlarging/profiling ports and I will be printing this off and keeping it close as I work. Congratulations to everyone who has already made such a splendid job of the procedure and, above all, thank you for sharing the expertise with me.
Bonne Année
Martyn
vintage engineer01/01/2020 10:44:07
293 forum posts
If you want to make your Minor go better. Try and get a 1295g head. These were fitted to Austin Princess 1100's. They have bigger valve and better ports. But you have to skim .125" of the head to get the comp ratio back up as these engines used flat topped pistons. I built a genuine 100 mph Minor Pick Up using all BMC parts except the exhaust manifold.
Posted by Phil P on 31/12/2019 12:20:34:
Phil
Phil P01/01/2020 10:54:53
851 forum posts
206 photos
Hi Vintage Engineer.
I think you might be referring to the 12G295 head, I used to run one of those on my Mini van when I was a lad in the 70's. If I used one now I would need a bigger carb and exhaust to take advantage of it as well.
To be honest I am not trying to make the Traveller go a lot faster, I am just taking the opportunity to build the engine to a better standard than they were when mass produced, I am static balancing all the moving parts and being careful with the cam timing, fitting duplex timing set up etc etc. I am after a smoother running reliable engine that I dont need to be spannering in years to come.
Phil
Maurice Taylor01/01/2020 11:31:35
275 forum posts
39 photos
Hi,
Just wondered if after tuning the mechanical parts of your classic engines ,you still use the distributer or you swap to an ECU.
