David K | 11/11/2019 13:09:19 |
258 forum posts 259 photos | I bought this at Action a while back and don't seem to have any use for it so might sell. Not sure what to advertise it as , it has a Parvalux geared motor so turns the chuck fairly slowly. |
not done it yet | 11/11/2019 13:28:19 |
7517 forum posts 20 photos | Don’t know but it is fitted with an expensive chuck! |
Ian Johnson 1 | 11/11/2019 13:32:16 |
381 forum posts 102 photos | Looks like a rotary 4th axis for a milling machine. The tenon locates in the tee slots of the mill bed. Looks well made too, and the chuck looks like a grip tru type and is worth a few bob itself, is it a 3 inch or 4 inch chuck? I've got a rotary 4th axis otherwise I'd buy it off you. Ian |
Emgee | 11/11/2019 13:34:06 |
2610 forum posts 312 photos | Powered spindle including 3j SC ?" chuck mounted on a tilting and rotating table. Looks like a Grip-tru chuck which is a bonus, useful bit of kit, especially with a stepper fitted in place of the fixed speed motor. Emgee |
JasonB | 11/11/2019 13:41:57 |
![]() 25215 forum posts 3105 photos 1 articles | The yellow bit looks like it was originally from a T&CG and the motor has been cobbled onto the end, chuck on a 5C? or similar mount. |
Jeff Dayman | 11/11/2019 13:43:05 |
2356 forum posts 47 photos | Maybe you could call it "Powered auxiliary spindle with three jaw chuck". I think it will be no problem to sell it - those that could use it would be glad to have it. Looks like good quality stuff. |
peak4 | 11/11/2019 14:01:35 |
![]() 2207 forum posts 210 photos | Not sure what you'd call it as it's a bit of a home brew special. |
Brian Wood | 11/11/2019 14:38:22 |
2742 forum posts 39 photos | Possibly a positioning aid for precision welding Brian |
David K | 11/11/2019 14:55:39 |
258 forum posts 259 photos | OK interesting thoughts, thanks I will have to have a think about it now although its probably a bit bulky for my mill. I will make some measurements tomorrow . |
mechman48 | 11/11/2019 15:36:03 |
![]() 2947 forum posts 468 photos | Posted by Brian Wood on 11/11/2019 14:38:22:
Possibly a positioning aid for precision welding Brian My thoughts too, also consider it to be a set up to cut / grind some form of Helix angle on the mill. George. |
JohnF | 11/11/2019 18:25:07 |
![]() 1243 forum posts 202 photos | I am sure Jason is spot on, very similar to the one on my Boxford T & C grinder --- try Google " tool grinder universal workhead" and look at the images. The motor does look a bit of flash up but even so may well be original ? I can see a badge on the base in the first photo - a clue here maybe ? John |
An Other | 11/11/2019 18:34:52 |
327 forum posts 1 photos | Don't know what its for, but I have an identical Parvalux motor/gear assembly. It contains two worm drives, so the output shaft rotates very slowly. The worm drives are very good quality - the worm gears in mine seem to be chrome plated. Edited By An Other on 11/11/2019 18:35:08 |
Pete Rimmer | 12/11/2019 08:27:36 |
1486 forum posts 105 photos | That's a powered work head for a tool and cutter grinder. It'll fetch good money if you put it up for sale. |
Martin King 2 | 12/11/2019 08:51:02 |
![]() 1129 forum posts 1 photos | David, You have a PM Martin |
Tony Pratt 1 | 12/11/2019 09:13:36 |
2319 forum posts 13 photos | Looks very like a Cincinnati T & C work head. Tony |
