Davey J | 28/09/2019 20:37:04 |
26 forum posts 4 photos |
old mart | 28/09/2019 20:58:39 |
4655 forum posts 304 photos | You need "delta" connections, but the motor is wired "star". I don't know if the wiring can be re arranged, hopefully someone will know. If you bought a new motor it would be easy to change from one to the other, but the mountings and shaft diameter might have changed. |
peak4 | 28/09/2019 21:15:36 |
![]() 2207 forum posts 210 photos | Yes, you should be able to run it off one of the 240v inverters. There is normally a label on the inside of the cover you removed to expose the wiring. Edited By peak4 on 28/09/2019 21:16:33 |
Emgee | 28/09/2019 21:17:23 |
2610 forum posts 312 photos | Davey, looks like the 3 ends of the coils are all connected on the terminal marked N to provide star connection. You need to remove these and place in 3 separate connectors so you will have 6 ends in the terminal box, then check for continuity between ends to find the ends of coils. If you have 3 coils of almost equal resistance you need to connect them in Delta to allow the use of a 230v VFD. Emgee |
Davey J | 28/09/2019 21:53:46 |
26 forum posts 4 photos | Bill, Emgee and Old mart many thanks for these replies and in such a short time, this really is an amazing resource of information. I will have a go and see what happens. Thank you for your help it is greatly appreciated and I will persevere with the book! . Davey |
old mart | 28/09/2019 22:34:35 |
4655 forum posts 304 photos | What you have got is three phases going into your motor which connect together at the neutral terminal. To change to delta, you have to disconnect the three neutral wires and move them to the appropriate phase connections. The neutral terminal will now have no wires going to it. You need a meter with a low ohms range to find out which wire goes where. My poor diagram shows what it should look like Good luck. Check the connections when the wires are disconnected from the neutral. Edited By old mart on 28/09/2019 22:38:02 |
peak4 | 29/09/2019 00:31:57 |
![]() 2207 forum posts 210 photos | Old Mart, there's a little bit more to it in that each of the three windings need to be in the correct orientation, but the colours linked to in my earlier post should avoid Davey having any problems. |
DC31k | 29/09/2019 07:40:59 |
1186 forum posts 11 photos | Posted by peak4 on 29/09/2019 00:31:57:
Old Mart, there's a little bit more to it in that each of the three windings need to be in the correct orientation... The motor will run rough and overheat otherwise, as one coil will be working against the other two. Could you kindly describe or post a credible diagram showing how it is possible to put the windings in an incorrect orientation. Reversing the ends of any winding is exactly the same topographically as swapping over two wires of the supply. This is the standard method of making the motor turn in the opposite direction. |
John Haine | 29/09/2019 08:11:11 |
5563 forum posts 322 photos | Topologically. but no, the problem is that there is mutual inductance between the windings, and the couplings between each pair all have to be in the same sense for the motor load to be balanced. This is covered in a couple of threads here. |
Gray62 | 29/09/2019 08:27:54 |
1058 forum posts 16 photos | Without going into too much motor theory, hope this helps to explain: Reversing a 3 phase motor involves changing the phase rotation, there are only 2 possible phase sequences for a 3 phase system 1-2-3 or 3-2-1, reverse any 2 phases and the motor changes direction. However, reversing 1 winding will not reverse the motor. Each winding is electrically oriented to produce the required N-S magnetic field, as the phase rotate around the connections, so the N-S field in each coil progresses round the stator, effectively ‘pulling’ the rotor with it. Each coil in the stator is not a single winding but several that are interleaved so the stator is magnetically connected at multiple points around its axis. Swapping the orientation of one of these field winding groups essentially puts part of the rotating field into a S-N magnetic orientation in relation to the other windings and will therefore ‘buck’ against the rotation. Invariably this will prevent the rotor spinning and cause excessive heat in the stator windings eventually burning out the stator. |
john fletcher 1 | 29/09/2019 09:28:03 |
893 forum posts | Hello David, your motor is connected Star and needed to be re connected Delta to work from your inverter. Have you or a friend a multi meter, as you need one to locate the other end of the three wires at present connected to the terminal N. Assuming that the wires on terminal N to be the number one ends of each of the three winding and the 2 ends to be connected to terminals A,B,&C as shown in your picture. Lift off all the wires from N and with one meter lead connected or touching say A, touch the other lead to one of the three wires previously connected to N. Mark the wire. Do the same to B and C. Now connect A 2 to B one, then B2 to C one, finally C2 to A one. Job done. If the direction of rotation is incorrect SWITCH OFF and exchange a pair of the output wires from the inverter. John |
Andrew Johnston | 29/09/2019 09:32:04 |
![]() 7061 forum posts 719 photos | Must be an old motor. The rating plate certainly implies it's a dual voltage motor, but the connection box isn't what you'd expect. I'll leave it for someone with more knowledge to suggest a wiring arrangement. Incidentally a star connected motor will run just fine off an inverter producing 3-phase at 230V phase to phase. The issue is that the phase currents, and hence torque and power, will be down by a factor of 1.732, aka the square root of three. Andrew |
Davey J | 29/09/2019 10:03:50 |
26 forum posts 4 photos | Once again very many thanks for all the help offered here, the depth and breadth of knowledge is a wonderful resource. I am going to try and run it from my 3phase 240v as per Andrew@s suggestion, it is a hobby drill after all, whilst I get rid of the Transwave and obtain something more suitable. Thank you all. David |
bill ellis | 29/09/2019 10:13:40 |
71 forum posts 2 photos | When I wired my mill up to 220v delta I used the following procedure to ensure correct polarity of the windings. I noted the colours/terminal designations which related to each winding on a post it note. I just used a multimeter rather than a zero centre one and watched which way the needle tried to kick. i) With a multimeter or continuity tester, you can segregate three sets of windings. The reason the winding polarity is critical is that the windings must have the proper phase to generate a rotating magnetic field to drive the rotor in a given direction. If one of the windings has the wrong polarity then that winding will be trying to rotate the field in the wrong direction. This causes poor motor torque and generates high winding currents. HTH Edited By bill ellis on 29/09/2019 10:17:51 |
Gary Wooding | 29/09/2019 10:26:44 |
1074 forum posts 290 photos | Posted by Andrew Johnston on 29/09/2019 09:32:04:
Incidentally a star connected motor will run just fine off an inverter producing 3-phase at 230V phase to phase. The issue is that the phase currents, and hence torque and power, will be down by a factor of 1.732, aka the square root of three. Andrew In a star connected motor running with 440v 3-ph, each winding "sees" 220v, which is exactly the same as they see when running with 220v in delta layout. Hence no loss of power. |
Andrew Johnston | 29/09/2019 10:59:58 |
![]() 7061 forum posts 719 photos | Posted by Gary Wooding on 29/09/2019 10:26:44:
Hence no loss of power. Pay attention there at the back. That's not what I wrote. If you run a motor in star and at a phase to phase voltage of 240V instead of 415V then there will be a loss of power compared to running at 415V. That's why when running from an inverter that gives 240V phase to phase you need to change to delta to avoid the power loss. Andrew |
peak4 | 29/09/2019 12:10:57 |
![]() 2207 forum posts 210 photos | Davey, From your earlier posts, I gather you have a "3 phase 240v supply" Is this correct and what model and ratings are displayed? What country do you live in? I'll not deep link to his photo for copyright reasons, but I'm sure you could print it out at reduced size and stick it inside your motor's cover plate for future reference. Edited By peak4 on 29/09/2019 12:11:51 |
Michael Briggs | 29/09/2019 13:16:43 |
221 forum posts 12 photos | Davey, my Fobco drill has a similar motor, I would have to take the motor off to see the motor plate. The lid of the terminal box shows how to connect for high and low voltages. It is probably the same as your motor : |
Michael Briggs | 29/09/2019 13:20:06 |
221 forum posts 12 photos | Sorry, hadn't looked at Bill's link, Michael |
old mart | 29/09/2019 13:40:39 |
4655 forum posts 304 photos | From studying the photographs, the colours of the op's wires are the same as the motor plate diagram. This would make it easy to get everything connected correctly. RED-BROWN YELLOW-WHITE BLUE-BLACK The 3 input wires can be connected any way round, only swapping any two if the motor rotates the wrong way. |
