Current leakage om CNC
fizzy24/08/2019 17:11:59
1860 forum posts
121 photos
If I touch the inside of my wrist against my cnc bed I get a highly unpleasant shock. Ive experienced the same sensation with laptop computers but given that there are just 3 stepper motors and a drive motor I wasnt expecting this to occur. I tested the bed to earth and got 120V @ 5 uamps so virtually no current to speak of. Is there anything I can easily do (other than not touching it) to reduce this? Its all on wheels on a concrete floor. Thanks
David Jupp24/08/2019 17:26:19
978 forum posts
26 photos
Make sure the metallic parts are earthed (as required by IEEE wiring regs) ?
Joseph Noci 124/08/2019 17:54:41
1323 forum posts
1431 photos
More than likely the capacitors from live and neutral to ground, in the mains input connector/filter somewhere causing the slight, and correct, leakage, if if they are present. HOWEVER!! the system should be earthed - ALL metalic parts connected together and to mains earth. If not, and one of those caps goes short circuit, you are DEAD!
Joe
Robert Atkinson 224/08/2019 18:15:12
1891 forum posts
37 photos
Commercial CNC machine or homemade?
5uA is enough for a shock. Assumuing you are in the UK or EU with 240V mains the 120V you are measuring is caused by the inut filter capacitors acting as voltage divider, The common of the filter appears to be connected to the machine metalwork but not the mains earth. This could be a fault in the machine or the workshop wiring.
Robert G8RPI.
Dave Halford24/08/2019 19:02:48
2536 forum posts
24 photos
Had you not found 120V to earth I would have suggested static build up on you. What earth did you use for the test?
fizzy24/08/2019 23:24:16
1860 forum posts
121 photos
its a chinese set up but the plug has earth. I connected the bed to the trolley, not realy n earth but makes part of the circuit. I dont think there is a workshop wiring fault as it is installed to Iee regs.
Vasantha Abey25/08/2019 04:22:50
17 forum posts
You need to fix an Earth wire to the body of your cnc, then at the end have a piece of flat metal like copper with a rubber sponge pasted to the bottom and wet the sponge with a bit of salt water.
this will allow the charges to go to the earth. This is because you have the machine on wheels is the problem. You can also change the rubber wheels to steel wheels that can solve the problem.
Joseph Noci 125/08/2019 07:05:42
1323 forum posts
1431 photos
Posted by Vasantha Abey on 25/08/2019 04:22:50:
I cannot see how this can be a substitute for a properly earthed system!
Fizzy, as you measured 120v to earth, there is OBVIOUSLY a missing earth connection. Use your meter on ohms scale, unplug the machine from the mains and measure between the machines cable end earth pin on the plug, and all over the machine's metal parts. If you do not get close to zero ohms then the machine's earth connection is faulty and NEEDS fixing.
If you do find close to zero ohms, then the problem lies either in the wall socket, or the machines power plug-to-wall-socket connection, ie, maybe the earth pin does not make good connection to the earth socket.
If you are not comfortable fiddling in the mains wall socket, get an electrician to do it for you - the earth socket receptacle is normally a stamped form sheet metal receptacle the envelopes the earth pin - sort of split tines that make contact. If these are spread apart and no longer make contact, then you have no earth. Or maybe the earth wires in the wall socket was not inserted properly.
Can you try another wall socket, preferably on a different breaker circuit even? And please, use you voltmeter to do the '120v measurement to ground' , NOT your wrist!
You need to get to the bottom of this - if this leakage is caused by the noise suppressor capacitors on the mains input, that current MUST be drained to ground/earth. I repeat, if those capacitors are present on your machine, should any one develop a shorts circuit, the body of your machine will be fully live, at 220VAC and will kill you if a proper earth connection is not present..The present setup circumvents the purpose of the distribution board's earth leakage trip switch and you have NO protection at all with this setup. Salty wet sponges will not save you life!
Joe
Johnboy2525/08/2019 07:23:49
260 forum posts
Fizzy... listen to what Joe has written.
As a retired Electronics & Electrical Engineer I total endorse what Joes written.👍
I.M. OUTAHERE25/08/2019 09:18:14
1468 forum posts
A question i would like to ask is what voltage do the steppers operate at ? If it is around 40v then you have a serious power supply problem , i would try isolating the power supply from the machine and see if the problem disappears.
Les Jones 125/08/2019 09:28:04
2292 forum posts
159 photos
I second Johnboy25's comment to do exactly what Joe has advised. Do not use the machine until this problem is resolved.
Vasantha Abey's comments are total nonsense
Les.
Edited By Les Jones 1 on 25/08/2019 09:32:14
fizzy25/08/2019 09:29:13
1860 forum posts
121 photos
Indeed the stepper motors are under 40v but the spindle motor is 110v. I have a new, unopened motor somewhere so I will swat it out and retest. Thanks all.
JasonB25/08/2019 09:58:35
By way of comparison my KX3 gives 0.4ohms testing between table and earth pin on the plug as Joe suggests.
Have you got rubber tyres on your casters?
Edited By JasonB on 25/08/2019 09:58:46
SillyOldDuffer25/08/2019 10:13:04
10668 forum posts
2415 photos
Posted by fizzy on 24/08/2019 23:24:16:
... I dont think there is a workshop wiring fault as it is installed to Iee regs.
May have been OK when installed but there's always the possibility of wear and tear later. I've had the neutral connection inside a well-used wall socket lose enough spring to spark due to a fatigue crack.
A socket tester would confirm all is well with the workshop wiring, this example is £7.99 from Screwfix.
Though I trust nothing I agree faulty workshop wiring is unlikely. A more likely cause is damage to the CNC machine's power lead, perhaps the earth connection in the plug has been strained or the wire pulled off inside the machine. Or a manufacturing problem left the earth disconnected.
Easy enough to test with a multimeter as Joe described. There should be close to zero ohms resistance between the plug's earth pin and all the CNC machine's exposed metal work.
Most likely the cause is simple.
Joseph Noci 125/08/2019 11:16:16
1323 forum posts
1431 photos
Posted by fizzy on 25/08/2019 09:29:13:
Also from XD 351:
Actually, it matters little where the leakage is from in terms of safety. The current seems happy to find a way through Fizzy's wrist, arm, heart, and whatever route it finds to some or other ground somewhere, anywhere, EXCEPT via the mains plug earth pin! Fix that first then worry about what is causing the leakage, if you need to. 5uA leakage or even more is very common with the mains input filer caps, so its not a crisis, IF you have a proper earth in place.
Joe
Robert Atkinson 225/08/2019 11:21:04
1891 forum posts
37 photos
+ one for Joes comments. and as Dave says fault can develop, you arn't using an extension lead by any chance?
All metallic parts of the machine that might come into contact with a voltage ove 50V in the event of a fault MUST have a path to ground (unless the machine is double insulated which is unlikely and not the case ith yours as you have an earth). This path must be designed in and able to carry the full fault current. Just continuity becuase conductive parts hppen to touch .s not good enough. Unfortunatly many machines do not meet this requirement.
The use of a 110V spindle motor may indicate a more serious fault/ design issue if the main supply is 230V.
Sponges and saltwater have no place in any safety earth.
Robert G8RPI
blowlamp25/08/2019 11:22:47
1885 forum posts
111 photos
I had a similar thing happen with my CNC lathe a while ago.
See page 2 of this discussion for what was wrong with my machine.
Martin.
Ian P25/08/2019 11:53:40
2747 forum posts
123 photos
Posted by fizzy on 24/08/2019 17:11:59:
Posted by fizzy on 25/08/2019 09:29:13:P
About twelve replies so far, some absolutely on target and contain warning of serious risk, some others are irrelevant. To be fair to some of the less useful repliers, the information Fizzy gave is somewhat fuzzy.
Initially he said he measured 120V to earth. The meter will have two probes, one we know was on the metalwork of the machine, but what 'earth' was the other connected to?
Stepper motor and spindle motor voltages, concrete floor, rubber tyres, wheels, Chinese made is all irrelevant!
Unless this machine is of double insulated construction (which is very unlikely) then there should be continuity between the machine metalwork and the earth pin on the end of its mains lead. If there is low ohms continuity then the fault lies in the workshop wiring.
Fizzy, you say connecting bed to trolley form part of the circuit, I hope not! What circuit would that be anyway?
Absolutely no point in swapping motors whatsoever, test the earth wiring and connections first
Ian P
old mart25/08/2019 16:33:34
4655 forum posts
304 photos
I have just bought a VFD made by Schneider for the rebuild of the Tom Senior mill. Reading the full manual, there is a mention of an earth leakage caused by the filters fitted to it. I don't know what the value is.
Phil Whitley25/08/2019 16:41:18
1533 forum posts
147 photos
Take heed of the above! unfortunately it is very common to find that Chinese equipment has not had the earth connected at the appliance end! see Bigclivelive.com on you tube. Using a continuity tester, test from the earth pin on the plug to the chassis of the machine, and test different parts of the chassis! I have had some 240v led lighting units supplied in metal cases where I found earth wires unstripped and unconnected inside the case, although there was an earth fixing point right next to the cable entry!
