Michael Gilligan | 30/07/2019 19:05:41 |
![]() 23121 forum posts 1360 photos | Posted by John Smith 47 on 30/07/2019 18:52:02: Hello Is there a type of Sellotape or "sticky-backed plastic" that resists constant pressure, resists heat and sunlight, and which forms a permanent bond?" Background: - Any thoughts? J
Interesting first question, John ... so a hearty 'welcome aboard' 3M [already one of your suppliers] is probably the best source of advice, and product They've bee doing this for a while !! I did a quick google search for '3m pressure sensitive tape, permanent' ... and quickly found this page: **LINK** http://multimedia.3m.com/mws/media/467622O/3m-pressure-sensitive-adhesives-tapes.pdf It looks like a promising start. MichaelG. Edited By JasonB on 31/07/2019 06:51:51 |
Clive Brown 1 | 30/07/2019 19:10:14 |
1050 forum posts 56 photos | 3M manufacture VHB, (very high bond) tapes for industrial use, vehicle trim etc. Available via ebay. Might be worth a try. |
MichaelR | 30/07/2019 19:14:58 |
![]() 528 forum posts 79 photos | Model aircraft hinge tape may suit your project Here Mike. |
Robert Atkinson 2 | 30/07/2019 19:27:16 |
![]() 1891 forum posts 37 photos | I use Kapton / Polyimide tape with silicone adhesive for this type of job. One possible issue for you is that while transparent it has an amber/copper/gold colour example https://uk.farnell.com/multicomp/mc001818/tape-polyimide-film-25mm-x-33m/dp/2770437?st=kapton%20tape Robert G8RPI. |
Former Member | 30/07/2019 19:45:20 |
1329 forum posts | [This posting has been removed] |
Andrew Tinsley | 30/07/2019 19:51:03 |
1817 forum posts 2 photos | I used to use a 3M product, to line a vacuum chamber with thick aluminium foil. The material stood 200 centigrade and a vicious low pressure plasma. One needed a chisel to remove it after a 100 hours or so of running. The reel that I have, says, 3M made in the USA. Core Series 2-1360. It is a double sided black tape maybe a little over 1mm thick. Excuse the mixed units! This was purchased in the UK with no difficulties. Regards, Andrew. |
Former Member | 30/07/2019 19:53:14 |
[This posting has been removed] | |
Geoff Theasby | 30/07/2019 20:25:52 |
615 forum posts 21 photos | I was going to suggest Kapton tape, too. What Andrew has is called self-amalgamating tape, much used for outdoor sealing purposes. Stretch it round the item to be sealed, and it bonds with itself, can only be removed by destructiion. |
Michael Gilligan | 30/07/2019 21:22:05 |
![]() 23121 forum posts 1360 photos | Posted by 34046 on 30/07/2019 19:45:20: Confused. O P says he is new here. Michael says interesting first question but it seems he joined in Nov 2015 and has had 44 posts to date ? Bill . Good point, Bill ... I can only say: I took the statement at face value and didn't check MichaelG. |
vintage engineer | 30/07/2019 21:44:34 |
![]() 293 forum posts 1 photos | Helicopter tape? |
Jeff Dayman | 30/07/2019 22:30:24 |
2356 forum posts 47 photos | Posted by John Smith 47 on 30/07/2019 18:52:02:
Hello Is there a type of Sellotape or "sticky-backed plastic" that resists constant pressure, resists heat and sunlight, and which forms a permanent bond?" Background: - Any thoughts? J With your requirement set (sun exposure, heat, pressure, time) I think you are expecting more than tape can deliver. I'd suggest revisiting the hinged part design with mechanical hinges and an elastomer seal that is in a compartment out of the sun. The simplest seal to implement for plastic assys if possible is a round shaped flat seal, like some food storage systems and some autoclaves use. If you are using this product outdoors you will want to rethink PS and ABS material choices also. Both will degrade and eventually crack in sunlight, in varying degrees depending on grade. An outdoor-rated material like Sabic's Valox V3900, or one of their Lexan outdoor grades would be far better - especially if they need to contain pressure. (you don't specify temps and pressures - hope they are relatively low) . Be sure to have this design checked by a professional designer before exposing the public to it. |
Dave Halford | 30/07/2019 22:48:57 |
2536 forum posts 24 photos | Solartex used to work well as a hinge. iron on |
JasonB | 31/07/2019 06:50:48 |
![]() 25215 forum posts 3105 photos 1 articles | Sorry I deleted the opening post by Mistake but it is quoted 3 times so you should all be able to work out the question but I have also added it to Michael's first reply.
Edited By JasonB on 31/07/2019 06:52:32 |
John Smith 47 | 31/07/2019 13:18:20 |
393 forum posts 12 photos | What a lot of replies! Thank you everyone. Firstly my humble apologies - I got confused about my "new-ness". (In my defence, I hadn't used the site for a fair while and for some reason I simply couldn't find where to see any of my previous posts!) To get clear, here are my IDEAL requirements for what I am looking for an adhesive tape: b. Is highly flexible (so would form a good hinge) c. Is transparent (or better yet, "invisible" like 3M's Magic Tape - but that doesn't age well) d. Ages well: e. Resists heat well k. (if possible) with a near immediate 'grab'
> Core Series 2-1360.
> Kapton tape - polyimide film
Jeff Dayman | 31/07/2019 15:42:45 |
2356 forum posts 47 photos | Is this an enquiry for commercial purposes? |
John Smith 47 | 31/07/2019 16:09:17 |
393 forum posts 12 photos | Posted by Jeff Dayman on 31/07/2019 15:42:45:
Is this an enquiry for commercial purposes? No. I am a private individual. |
Grindstone Cowboy | 31/07/2019 16:29:39 |
1160 forum posts 73 photos | Clear Gorilla tape? Video here |
John Smith 47 | 01/08/2019 19:58:45 |
393 forum posts 12 photos | Thank you. Gorilla tape is an interesting suggestion, but any money says that it doesn't "set". i.e. If my hinge on my model is in the sun and under sustained albeit gentle pressure it is almost bound to come apart, no? OP |
John Smith 47 | 10/09/2019 12:56:21 |
393 forum posts 12 photos | UPDATE I finally bought some special (fairly expensive) 3M tape called "396 Super Bond Polyester Film". But although this tape is extremely tacky and has a high "grap", it has a rubber-resin adhesive, which doesn't seem to ever set and doesn't survive sustained forces very well. This is worse in higher temperatures, such as sunlight of course. I also tried some of 3M's "4411N Extreme Sealing Tape", but this is rather thick and the hinge doesn't flap freely. BUT I have just realised that book-binding technology could be the way forward! J
Jeff Dayman | 10/09/2019 14:58:32 |
2356 forum posts 47 photos | "- Any thoughts? J" Here's a thought - you don't seem to take advice well. |
