mick H | 30/07/2019 08:59:09 |
795 forum posts 34 photos | As far as weatherproofing is concerned my "main" (tiny) workshop is OK but I do have to keep a certain amount of stuff in the garage which has an up and over door. During periods of heavy rain the up and over garage door lets in water as there is no seal at the bottom. I would like to fit a threshold seal whilst the weather is reasonable. Any recommendations will be appreciated. Mick |
Journeyman | 30/07/2019 09:09:11 |
![]() 1257 forum posts 264 photos | I've got one of these on my door works but the threshold needs to be flat *** Screwfix *** you can also get a rubber strip that fixes to the floor and provides a stop for the door to butt up to. Loads on the interweb a quick Google will show plenty... John Edited By Journeyman on 30/07/2019 09:09:53 |
not done it yet | 30/07/2019 09:11:04 |
7517 forum posts 20 photos | Unless the water drains away, I doubt a seal is the best option. On my first garage, I made a raised mortar hump just behind where the door closed to. It at least prevented ingress past the door. Second one, the base was made with a slope away from the garage across the door opening. Never been a problem. It was only occasional driving rain which was a problem for the first. I think I drilled a hole through the base, at the lowest point, for the occasionally needed drainage |
Former Member | 30/07/2019 09:12:43 |
1329 forum posts | [This posting has been removed] |
MichaelR | 30/07/2019 09:35:01 |
![]() 528 forum posts 79 photos | This for UP and Over door floor seal Here |
roy entwistle | 30/07/2019 09:42:09 |
1716 forum posts | I got a rubber seal from the firm who supplied the door, can't remember who, it must be 25 years back. I do get an ingress of water at the sides when it's windy Roy |
John Paton 1 | 30/07/2019 10:03:07 |
![]() 327 forum posts 20 photos | Given that most rain (and leaves) only comes in when wind driven, I pop rivetted brush pile draught excludr around the bottom and side inside edges of my garage doors. This accommodates uneven concrete surface and 'wobble' of the door within the frame better than rubber seals do. It is not 100% watertight but keeps dampness to within 50mm of the frame where it came in 300mm or more previously. |
Stuart Bridger | 30/07/2019 10:10:18 |
566 forum posts 31 photos | Screwfix seal linked above worked for me |
Clive Foster | 30/07/2019 10:17:39 |
3630 forum posts 128 photos | +1 for the flexible, glued down, "hump" strips. Had rubber cable cover type one on my Portaldoor, OK that was an up and out not up and over door but same behaviour at the bottom, for decades which worked very well. Tried DIY of the hanging rubber strip type but found it needs a decent gap to permit flexing during initial opening and final close. If it touches the ground it reverses during a close / open cycle. I only had about 1/8" gap which overstressed things. Unfortunately the heavy rain wind direction was straight at the door so even 1/8" let a lot of water in. Clive |
Paul Lousick | 30/07/2019 10:40:49 |
2276 forum posts 801 photos | I have a panel-lift type door on my garage which is similar to an up and over at the bottom. Providing a water tight seal at the bottom of the door where it meets the floor is difficult. They are not precision parts and therefore not water tight. To overcome the leakage, I made the height of the floor under the door about 10mm lower than the main garage floor with a slight fall to the outside. Any water that seaps under the door door is drained away. Paul. |
Mike Crossfield | 30/07/2019 11:51:01 |
286 forum posts 36 photos | I have a strip of the damp proof plastic membrane that bricklayers use fixed to the bottom inside face of my up and over garage doors. I used self tappers and washers to fix. Very flexible, weather-proof and cheap as chips. Works a treat for keeping out wind blown rain and leaves. Mike |
Martin Kyte | 30/07/2019 12:09:44 |
![]() 3445 forum posts 62 photos | On my last 'Garage Workshop' I did pretty much the same as Mike above except I used a 5 inch wide thin rubber sheet pop rivetted to the insude edge of the door. When the door closed the rubber floded itself under the door and extended 4 ish inches beyond the front face creating a skirt that directed all the wet of the concrete cill and into the gulley in front of it. regards Martin |
Howard Lewis | 30/07/2019 13:10:10 |
7227 forum posts 21 photos | I sealed the bottom of my up and over door in the last house. The car rusted the wings and doors, presumably because the damp air could not escape easily. The door at our current house is unsealed, and over 40 years we have never had a problem with the cats rusting, or even staying wet. The brush sealing should be good, in that it will prevent water ingress, it will be permeable, so that moist air can escape. Failing that, why not a shallow lip inside the door, (Aluminium angle fixed to the floor, say 30 -40 mm high? Howard |
Sam Longley 1 | 30/07/2019 13:30:13 |
965 forum posts 34 photos | I had a brush seal but it was useless as the water just goes through the brush. i now have a 100mm piece of damp proof membrane fitted to the door ,faced with a 20 mm wide strip of aluminium to clamp it to the door. There is still a small leak each end but the DPM has been left a little long & I have cut notches in the frame to accept this, so leakage is really very small The best solution would be a piece of timber plugged & screwed to the floor inside, on a bed of mastic, to form a simple rebate. This would catch any water running down the door jambs, as well as under the door |
Former Member | 30/07/2019 14:49:08 |
Howard Lewis | 30/07/2019 17:22:48 |
7227 forum posts 21 photos | FAT fingers, should be CARS. The cats dry themselves! The muddy footprints over everything prove that! No rust yet seen on the Adept Shaper and mini lathe that also live beside the car in the garage. Howard |
mick H | 30/07/2019 20:58:16 |
795 forum posts 34 photos | Thanks gents. Very useful. Mick |
Robert Dodds | 30/07/2019 22:06:57 |
324 forum posts 63 photos | Its worthwhile checking the door construction. Bob D |
Colin Heseltine | 30/07/2019 22:27:58 |
744 forum posts 375 photos | I stopped water ingress by grinding a narrow channel in the floor parallel to the back bottom edge of the door and inserting a metal strip (1/4" x 3/4" Colin |
