small belts
Philip Burley23/06/2019 18:19:45
198 forum posts
I have been looking for a belt to run a governor on my steam engine . Rather than the spring ones . needs to be about 12 inch long about 1/8 wide . . , I cant find anything in this country , have anyone come across something similar ?
Bodger Brian23/06/2019 18:43:18
187 forum posts
40 photos
Posted by Philip Burley on 23/06/2019 18:19:45
Which country? It helps with requests like this if you say where you are.
Edited By Bodger Brian on 23/06/2019 18:43:32
Philip Burley23/06/2019 19:10:05
198 forum posts
sorry I am in UK , it seems suitable belts are available in USA , I do have a couple of elastic bands from the post man , but not sure when to obtain similar ones , these degrade quite quickly
Phil
JasonB23/06/2019 19:17:18
Spare belts for things like tape recorders work quite well, you may need to split something down the middle as 3mm in that sort of length is hard to find but 5-6mm are about such as this
David George 123/06/2019 19:21:12
2110 forum posts
565 photos
Have you tried Beltingonline.com I bought a 6mm wide belt for my small lathe from them it cost a few pounds and just tried their web site and it accepted 3mm.
David
Former Member23/06/2019 19:37:25
1329 forum posts
Pete Rimmer23/06/2019 19:54:57
1486 forum posts
105 photos
Get the right length and appropriate pitch poly-vee belt and cut it down to the width you need. I've done that to replace a round belt on the narrow pulleys. Works wonderfully well.
John Haine23/06/2019 20:20:35
5563 forum posts
322 photos
You can get O-ring material in continuous lengths, make a loop by joining with superglue in a jig. Or may be able to get a suitable large 1/3 or 3 mm O ring?
Hollowpoint23/06/2019 20:44:10
550 forum posts
77 photos
What about the PU belt you weld together with heat. I believe you can get that in small sizes.
Philip Burley24/06/2019 06:04:40
198 forum posts
thanks ,I will try Forest Classics and Beltingonline and see what turns up
Phil
Dennis D24/06/2019 07:03:45
84 forum posts
Try these people looks like they may be on holiday at present but have had fast delivery when ordered **LINK**
Paul Lousick24/06/2019 07:22:00
2276 forum posts
801 photos
3D printer timing belt is 6mm wide. Join ends together with Loctite, same as you join O-ring material. Run on the tooth side of the belt or alternatively on the ftat side.
Paul.
Howard Lewis24/06/2019 13:23:12
7227 forum posts
21 photos
If you cannot find a source of the spring belts used for Meccano, the garter springs from lip seals (oil seals ) are the same. To shorten, you need to cut the spring and then carefully unwind the wire of the cut end, to expose the tapered end. Having arrived at the required length, you then twist to the free end, a few turns, in the opposite direction that is required to "screw" the belt back together, so that when rejoined it is has minimal twist.
