Machining cork!
Maurice | 04/03/2019 19:48:55 |
469 forum posts 50 photos | Can anybody tell me how to make a cork, into a smaller cork please? I have tried (with little expectation of success) turning with various shapes of tool; and assorted abrasives . All I got was a lot of cork dust and less corks! Some time back I made a working model Archimedes screw, with two wooden tanks (see album ). The upper tank has a drain made from 3/8" copper pipe, but I have nothing to plug it with, that doesn't leak, other than a piece of Plasticine. Not elegant. I'm sure I have seen corks this small but I have so far not found one. Any ideas please? Regards Maurice |
Rockingdodge | 04/03/2019 19:59:45 |
![]() 396 forum posts 111 photos | Turn one out of balsa wood? |
John P | 04/03/2019 20:07:13 |
451 forum posts 268 photos | Hi Maurice, I you have ever used some silicone sealant the tapered nozzle that is on the tube always has some left over sealant inside that sets inside , pull it out and you have a tapered plug of silicone ,cut it as required to form a suitable silicone cork. John |
DMB | 04/03/2019 20:07:33 |
1585 forum posts 1 photos | Cant help with making corks to size,but if and when you succeed, a light smear of vaseline will waterproof the cork. |
mechman48 | 04/03/2019 20:08:00 |
![]() 2947 forum posts 468 photos | Freeze it... ? |
Nick Hughes | 04/03/2019 20:08:04 |
![]() 307 forum posts 150 photos | Have a look here (Also lists Silicone and Neoprene rubber versions)
Edited By Nick Hughes on 04/03/2019 20:14:00 |
Bizibilder | 04/03/2019 20:38:19 |
![]() 173 forum posts 8 photos | Have a look online at methods of shaping cork fishing rod handles - lots of advice and videos etc. |
Maurice | 04/03/2019 21:36:59 |
469 forum posts 50 photos | Thanks gents. Moulding in silicon sounds good to me. I,ll give it a try. Maurice
dcosta | 04/03/2019 23:54:51 |
496 forum posts 207 photos | Hi Maurice, Please see thread **HERE** .Seventh post. Regards
Alan Charleston | 05/03/2019 05:02:07 |
157 forum posts 26 photos | Hi Maurice, Moulding a silicone bung sounds a good idea. If that doesn't work try a scientific supply company. Rubber bungs are made from a small end diameter of a millimeter or so to huge (>100mm). Regards, Alan |
Speedy Builder5 | 05/03/2019 06:38:42 |
2878 forum posts 248 photos | High speed and sandpaper, if required, glue sandpaper to a flat block of wood. |
Neil Lickfold | 05/03/2019 06:45:17 |
1025 forum posts 204 photos | Grind it. With a dremel and sanding drums works really well. The use a vacuum cleaner to keep the dust to a minimum. |
Maurice | 05/03/2019 07:54:10 |
469 forum posts 50 photos | Thank you for all your help. I think I will try bringing it down to size and tapered using a Dremel and finishing it with the sandpaper glued to wood idea; I'll tell you how I get on. May take a week or so. Other stuff to do! Regards Maurice |
Martin Kyte | 05/03/2019 08:55:46 |
![]() 3445 forum posts 62 photos | Razer blada mounted vertically. Feed slowly and run the lathe fast. Essentially you take small slices from the face of the cork to full depth required. Either Geo Thomas or more probably Tubal Cain described this eons ago. Works on rubber too. Martin |
JohnF | 05/03/2019 09:35:46 |
![]() 1243 forum posts 202 photos | Maurice, have not read all the reply so apologies if I'm repeating but grinding is the way to go or abrasive paper, fishing rod handles are profited in this way, first by grinding a profile then fine finishing by hand with wet & dry paper. The cork shives are glued onto the blank and are quite large compared to the finished unit hence the grinding. Regards John |
