Ron Laden | 23/02/2019 08:08:03 |
![]() 2320 forum posts 452 photos | Do any of you guys have to keep logging in to the forum..? I can go days without needing to log in but then I have periods where I need to log in every day, sometimes 2 or 3 times a day. Its not an issue but wondered if its just me. Ron |
Steambuff | 23/02/2019 08:16:45 |
![]() 544 forum posts 8 photos | Do you have the "Remember Me" box ticked? If you change devices that you logon with it will require you to login again i.e. PC to iPad Dave |
Ron Laden | 23/02/2019 08:22:09 |
![]() 2320 forum posts 452 photos | Yes Dave, I have "Remember Me" ticked and I only use one device. |
not done it yet | 23/02/2019 09:06:00 |
7517 forum posts 20 photos | Ten tmes a day, sometimes more? Regularly. |
I.M. OUTAHERE | 23/02/2019 09:10:17 |
1468 forum posts 3 photos | I only log in if i want to reply to or add a new post . |
Emgee | 23/02/2019 09:29:39 |
2610 forum posts 312 photos | I had login problems yesterday, the server advised me about 10 times I had logged in with the wrong user name. Emgee |
Mick Henshall | 23/02/2019 09:38:55 |
![]() 562 forum posts 34 photos | I only log in if I want to comment, if I go to another site and return to this one I am logged out, on other sites once logged in always logged in Mick 🇬🇧 |
Bazyle | 23/02/2019 09:56:15 |
![]() 6956 forum posts 229 photos | If you log in from a different machine then it logs out of the last one. If your phone is enabled for the site it may be logging in if the window is left open in the background. |
Vic | 23/02/2019 10:00:28 |
3453 forum posts 23 photos | Posted by not done it yet on 23/02/2019 09:06:00:
Yes, same here. Never have the problem on other sites, it’s just this one. |
Samsaranda | 23/02/2019 10:16:46 |
![]() 1688 forum posts 16 photos | Same problem, sometimes go a couple of days with staying logged in but then sometimes will have to log in numerous times during a day. Bizarre occurrence a few months ago the log in rejected my password so I proceeded as if to change my password and just entered the old password, I didn’t want to change if it wasn’t necessary, the old password was accepted and I haven’t had any problems with log in since. Most sites refuse to accept a previously used password but it appears that Model Engineer will accept. Dave W |
not done it yet | 23/02/2019 12:34:08 |
7517 forum posts 20 photos | Third time today. I just wanted to look at the classified this time. |
Old School | 23/02/2019 13:44:14 |
426 forum posts 40 photos | I have to log in every time I want to post so often don't bother. |
martin perman | 23/02/2019 13:52:16 |
![]() 2095 forum posts 75 photos | I dont know whats different about my set up but I'm logged in for months with no issues, the only time I have to sign back in is when I have a tidy up of the system. Martin P |
JasonB | 23/02/2019 13:55:33 |
![]() 25215 forum posts 3105 photos 1 articles | Same her, maybe once every 6-8wks I get logged out without a known reason, rest of the time it's fine |
Nick Clarke 3 | 23/02/2019 14:09:12 |
![]() 1607 forum posts 69 photos | For some Windows updates the system has to log in using an system account, so is that what might be logging you out of your browser? I am sorry I can't test this as I don't use remember me at all (can't on work machines, don't at home) The giveaway test is if you are logged out the first time you try to use the system after a second Tuesday in a month (but not every month unfortunately) If you use another system then this doesn't apply of course. Edited By Nick Clarke 3 on 23/02/2019 14:10:00 |
JohnF | 23/02/2019 15:42:03 |
![]() 1243 forum posts 202 photos | Not noticed an issue with the logon dropping out, only very occasionally or when i change devices or if I switch off my MacBook rather than go to sleep mode. However today I did notice that the "return " button now works as it should ! press return and you go to the new paragraph rather than to the first letter you had typed in so "something"has changed ! John |
Howard Lewis | 23/02/2019 15:45:03 |
7227 forum posts 21 photos | Only log in if I want to post something. Logs me out sometimes, If I change topic. Howard |
Ron Colvin | 23/02/2019 15:49:52 |
91 forum posts 6 photos | I find that regular logging is a good practice, otherwise I tend to forget my user name and password. |
JasonB | 23/02/2019 16:09:12 |
![]() 25215 forum posts 3105 photos 1 articles | Also means you will see any PM's that you might otherwise miss if you don't have e-mail notification turned on. You need to be logged in if you want to access any digital archive mags too. Edited By JasonB on 23/02/2019 16:11:06 |
Enough! | 23/02/2019 16:42:47 |
1719 forum posts 1 photos | Posted by martin perman on 23/02/2019 13:52:16:
Me too until recently. Now I have the same problem as others - I go anything from a few days, to hours to a week before I'm logged out (and yeah - I know all about "keep me logged in" and using another machine).
