New mill for workshop
Robert Graham 2 | 18/02/2019 23:38:10 |
6 forum posts | Hi all After advice on this forum, I bought a warco 280v lathe and so far am very pleased with it now to buy a mill my budget is £2000 I am going to fit a dro and stand so less £500 so my choices look like 1. major milling drilling machine 2. GH 18 mill 3. wm18 mill 4. major GH mill. I could stretch to VMC mill ( comes with a stand ) or GH universal mill if I wait for the dro and buy it later funds permitting your thoughts advice welcome the above m/c are all from warco but other mills are welcome regards, Robert |
John Rudd | 19/02/2019 06:59:33 |
1479 forum posts 1 photos | I have owned a Major mill, biggest drawback is its got a round column.... I replaced it with a 626 from Chester, their equivalent of the VMC, great machine, never looked back...I modified mine by fitting a 3 ph motor and vfd...and dro. |
Martin Kyte | 19/02/2019 08:42:58 |
![]() 3445 forum posts 62 photos | Streach to the VMC even if you have to wait a little before upgrading to DRO. regards Martin |
fizzy | 19/02/2019 08:51:45 |
![]() 1860 forum posts 121 photos | Ive got mill drill for work - fits my requirements perfectly but I dont like milling with it! The round column has been known to allow the head to move under load which is disasterous. I mostly drill and bore with it.
Chris Evans 6 | 19/02/2019 09:11:33 |
![]() 2156 forum posts | Space/budget and most important type of work you intend to do should influence the decision. I run a Bridgeport mill which is perfect for the old motorcycle parts I machine. |
Samsaranda | 19/02/2019 09:21:38 |
![]() 1688 forum posts 16 photos | I have a Champion V20 mill, a solid piece of engineering but a little short of grunt for heavy milling, have fitted DROs to two axis, the spindle has a factory fitted digital readout. All depends what work you will be doing. Dave W |
Andy Carruthers | 19/02/2019 09:24:20 |
![]() 317 forum posts 23 photos | I picked up a Tom Senior M1 in very good condition for £1350 including base then fitted DRO for ~£165 Presumably you know of this site? http://www.lathes.co.uk/page3.html/ |
John Hinkley | 19/02/2019 09:38:23 |
![]() 1545 forum posts 484 photos | +1 for the Warco VMC mill. I bought one a couple of years ago with R8 quill and power feed to the X-axis. I have since fitted three-axis DRO, quill digital scale readout and upgraded the motor to 3-phase 2HP motor and matching VFD. Smiles all round! Not cheap, but you know what they say ........... John
Vic | 19/02/2019 10:03:50 |
3453 forum posts 23 photos | Get the VMC. I’ve got one without DRO’s as I can’t really justify the cost but I use the stops on it and it works well. |
Stuart Bridger | 19/02/2019 10:14:31 |
566 forum posts 31 photos | Another vote for the the VMC, would recommend a DRO as it makes things so much easier |
Robert Graham 2 | 19/02/2019 18:18:34 |
6 forum posts | a VMC it is then dro will have to wait thanks a lot guys most helpfull |
not done it yet | 19/02/2019 19:24:34 |
7517 forum posts 20 photos | If you are used to a variable speed drive (the lathe), the extra wait for the slightly more expensive mill with variable speed drive might be worth considering. I, personally, would now find belt changing so much a chore that I would no longer consider a drive with discrete speeds obtained by swapping belt positions. |
Hollowpoint | 20/02/2019 17:52:04 |
550 forum posts 77 photos | I would go for the VMC too! I have a variant, its a good solid mill. |
Vic | 20/02/2019 18:55:19 |
3453 forum posts 23 photos | Swapping belts on my VMC is hardly a chore, it’s quicker than changing a cutter, about 20 seconds.
