martyn nutland | 31/01/2019 17:34:07 |
141 forum posts 10 photos |
Can anyone advise me how to do this accurately? Fourth attempt coming up! I need a through slot 19mm X 9mm in 14 mm mild steel bar 27mm long. Have tried a slot drill which just made a mess. Tried enlarging holes I thought to be accurately placed on the axis then cutting out the 'bridge' with a slot drill. Latter made a further mess and although I did get the slot I wanted by filing it was dangerously over to one side to the extent the part is unusable. Guidance much appreciated, and many thanks, as always, in advance.
Neil Wyatt | 31/01/2019 17:45:43 |
![]() 19226 forum posts 749 photos 86 articles | If your mill is not very rigid, either take much smaller cuts and/or use an undersize slot drill, then skim to size. Neil |
Emgee | 31/01/2019 18:20:41 |
2610 forum posts 312 photos | Hi Martyn You could drill 8mm through at each end, (centre drill 4.5mm from end of the slot) so when drilled there will be .50mm of material to remove at each end with your slot drill, also there will be .50mm each side of the drilled holes if the drill didn't wander. Emgee |
JasonB | 31/01/2019 18:21:27 |
![]() 25215 forum posts 3105 photos 1 articles | Seems to be one dimension too many to me? or is your bit of bar only 27mm long? If it is then drill out say 6mm dia at each end and again in the middle, open out the two end holes by plunging with an 8mm cutter then change to 9mm dia and mill out the slot 19mm O/A length Edited By JasonB on 31/01/2019 18:24:29 |
I.M. OUTAHERE | 31/01/2019 18:32:45 |
1468 forum posts 3 photos | Are you doing this with a milling machine or a lathe ? Maybe a photo of your set up will give us some clues as to what is going awry . |
Ady1 | 31/01/2019 18:57:13 |
![]() 6137 forum posts 893 photos | Cut most of it out with an angle grinder and finish off with a slot drill You must be hogging out 90% plus of the material here, there aint much left, 2.5mm each side, is that right? Filing off might be the better option Edited By Ady1 on 31/01/2019 19:02:00 |
Paul Lousick | 31/01/2019 21:42:08 |
2276 forum posts 801 photos | Holding a short piece of bar only 27mm long and trying to mill a 19mm slot is difficult. Better to use a longer bar, securely clamped. (both ends if possible) and cut to length after machining the slot. Paul. Edited By Paul Lousick on 31/01/2019 21:43:00 |
Hopper | 31/01/2019 23:06:24 |
![]() 7881 forum posts 397 photos | What exactly is the problem you are having? Rough finish? Cutter digging in? Not cutting straight to the line? Pics of the problem would help too. "Made a mess" is a bit vague to pinpoint the possible cause. Edited By Hopper on 31/01/2019 23:08:32 |
Simon Williams 3 | 31/01/2019 23:32:01 |
728 forum posts 90 photos | By dint of washing it with coolant, or simply blowing compressed air at the cutter, make sure that you are not trapping and re-cutting the chips. Otherwise this is about stiffness/rigidity of the set-up and/or sharpness of the cutter, which could well lead to a conversation about climb milling. If you can first drill a hole right through with your slot drill and then wash the chips down the hole it gives them somewhere to go. Quite a difficult thing to do actually, so some photo's of the set up would help to show what is going on. HTH Simon |
larry phelan 1 | 01/02/2019 11:05:05 |
1346 forum posts 15 photos | Hi Ady1 An angle grinder ? |
martyn nutland | 02/02/2019 08:36:39 |
141 forum posts 10 photos | Firstly, many, many thanks for all the comments and help.
For clarification, at the risk of being boring, what I'm trying to make is a pivot to sit between the forks of a vintage Austin Seven brake lever. The slot is necessary to accommodate a rod that links the brake pedal to the lever without putting any sideways load on the connection (rod).
To make the pivot I'm using a surplus Austin Seven gearbox mainshaft which is a nice bit of 'stuff' and because the gears would have been keyed to it, is not in itself hard. Its about eight inches long and 19 mm in diameter. and I turned it down to 14mm which is the only really critical dimension (hole in fork).
I am holding it in a collet block with an ER32 collet in a Vertex 4 inch vice on a Warco Economy mill. I have about 35 mm protruding out of the collet and for the later/heavier cuts I supported the overhanging end in a vee-block. Prior to that the collet block tended to tilt downwards.
Thus, I think overall rigidity is an issue.
I centred the spindle over the stock with one of those simple 'swinging vee' gadgets, scribed a line along the axis; centre drilled at both ends 4mm + 4.5 mm from the true end and from the intended cut off point (27 mm overall). Four millimetres because that's how much solid metal I want to insert on each side of the fork and 4.5mm because that is half the diameter of the width I want the slot. The rod is the diameter of a 5/16 BSF thread. (7.9mm)
I drilled on the centre drill indents at 6mm, 8 mm, 8.5 and 9 mm. When I now say mess I mean the 9 mm wandered off and chewed the sides where there's not much lee-way (as you point out) - 2.5mm. That's why I corrected with an 8 and 8.5 and why I think rigidity is an issue.
I tried to take out the remaining metal between the two holes with an 8mm slot drill and that was a mess too. In fact it wouldn't do it! Stalled the mill. Resorted to a file.
This is another bit I don't understand! I know that the difference between a slot drill and an end mill is that , because of the way the teeth on a slot drill are formed, they can 'plunge' whereas end mills' capacity to 'plunge' is minimal. Yet, my slot drills have a marked reluctance to 'plunge. Do you....drill a hole first, insert the slot drill part way - say for the sake of argument - to a depth of 2mm, then advance it the length of the slot - say 20 mm, come back, go down another 2mm and advance and so on until you are at depth or do you advance (plunge) the slot drill the full depth, as you might a conventional drill, then advance it along the slot cutting all the way in one go?
Good news is, the pivot piece, rough and unsatisfactory from a machining point of view though it is, works like a dream.
Thanks again.
Hopper | 02/02/2019 09:12:43 |
![]() 7881 forum posts 397 photos | Glad you got the job done at a useable level. That's the main thing. It sounds like you may have got more rigidity by holding the job in a vice with suitable packing etc. A good slot drill should plunge straight down. But it depends on if its properly sharpened etc. Drilling a smaller hole then dropping the slot drill down should work ok, having provided clearance for the critical centre part of the cutting edges. The method of taking say 2mm deep cuts along the length is probably a good idea on smaller less rigid milling machines (eg home hobby machines smaller than a Bridgeport) particularly on the roughing out stage. By using a slot drill smaller diameter than the finished slot width, you culd then take a light full-depth cut along each side of the slot. What make and model milling machine are you using? |
Nicholas Farr | 02/02/2019 09:56:32 |
![]() 3988 forum posts 1799 photos | Hi Martyn, you could try milling a flat on the bar the length of the slot with a 7 or 8mm cutter first before you drill any holes, this should stop the drill wandering off course. Another thing you can do to help stop the collet block from tilting, is to use a hold down clamp on the top of it. Your mill should be plenty capable to do this job. Hopper, he is using a Warco Economy mill, which is a smaller version of their Major mill. Regards Nick. P.S. The Economy mill was last advertised in their issue 12 catalogue and was one down from their Minor mill. Edited By Nicholas Farr on 02/02/2019 10:12:31 |
SillyOldDuffer | 02/02/2019 10:23:40 |
10668 forum posts 2415 photos | I'm having trouble visualising the object Martyn - is it like this? If not, a photo of the finished item would help. I promise not to laugh if it's a shameful botch - living in a glasshouse myself I know better than to throw stones! From the description, and as I've drawn it, this is a difficult object to hold rigid during cuts, and the problem gets much worse as metal is removed. I suspect that most of your problems are due to the work twisting under heavy cuts resulting in gouging, dig-ins, and a bent workpiece. One solution is to improve the holding AND to reduce the forces on the work by taking lighter cuts at high speed with a small diameter cutter. Assuming the object is as pictured, I'd firmly clamp a long rod direct on the table, perhaps making a shallow V block to add longitudinal support. Then I'd rough out about a third of the slot with a large slot drill before switching to a smaller slot drill for the next third, and finally finishing off with a small diameter slot-drill shallow cutting at high speed. Only after the slot is cut would I shorten the rod to size. Dave
Simon Williams 3 | 02/02/2019 10:26:16 |
728 forum posts 90 photos | Posted by martyn nutland on 02/02/2019 08:36:39:
Rigidity is always an issue! But that ain't the whole story. That bit of mainshaft may not be hard, but I bet it's tough as old boots. Cutting a deep slot like this is difficult territory, without trying it out on some difficult material. For curiosity, try the same procedure on something more forgiving and see how much better a result you can achieve. Your slot drill, if we mean by that something with a cutting edge which meets the centre of rotation of the end face, should plunge perfectly happily. But, again, trying to do that in the material you are using may be easier said than done. If it doesn't plunge as easily as it would if you were just using a standard twist drill then there is something wrong with the cutter geometry, though a tough material won't help things. Drilling a pilot hole is a good work-round, but you shouldn't need to. The other thing we've not mentioned is the actual cutting procedure. In principle you can cut a slot by going to and fro, but you maybe running into problems with cutter deflection so try cutting in one direction, then returning to the start before feeding down for the next cut. IIRR Jason's series of articles in MEW on milling for beginners include some comments on milling about the geometry of cutting edges and how the number of flutes can affect the accuracy of the finished item. Make sure you are not re-cutting the swarf, that will deflect the cutter erratically and frustrate your best endeavours. But good to hear you got something functional, if not pretty. Your mill is plenty capable of doing pretty but it may need a bit of fiddling with the cutter geometry and sharpness also the technique to get there. But the lesson my milling machine has taught me is that it always needs a rigid set up, and I have learned that time making sure the work is held securely is always well invested. Best rgds Simon |
Martin Connelly | 02/02/2019 15:38:07 |
![]() 2549 forum posts 235 photos |
This photo shows a supported and clamped overhanging workpiece which is the way to do what you wanted. A hard collet block held by hard vice jaws gives poor grip as you found. A piece of paper between the block and the moving jaw may have helped. Putting milling cutters in lathe chucks can have similar issues. The other thing that is a problem is the lack of material at the sides of the slot. If you think of a twist drill as a twisted ribbon you can understand hiw easily it can deflect. In this case as soom as one side is weakened enough the drill will be pushed that way by the forces acting on it. A stiff stub drill or spotting drill would have helped but a 3 or 4 flute milling cutter would be stiffer so better. Regarding plunge cutting with milling cutters even centre cutting ones do not go in as easily as a drill. One way to improve on this is to ramp the tool into the workpiece. This is easily done with CNC but is possible when manually operating a mill. It requires lateral movement of the workpiece as the tool is lowered into it. Since you needed a slot it was possible in this case. Martin C Edited By Martin Connelly on 02/02/2019 15:39:12 |
John Haine | 02/02/2019 16:02:00 |
5563 forum posts 322 photos | Swinging vee centering gadgets are best avoided. The right way to centre the cutter over the shaft is to use an edge finder. |
martyn nutland | 03/02/2019 09:11:14 |
141 forum posts 10 photos | Thanks everybody, I think we can make progress here! Rigidity, rigidity, rigidity is a good axiom I feel. Maybe turn down the centre of the stock shy of diameter first. Clamp the collet block vertically certainly, but with a long piece of stock there's also the opportunity to hold the other end rigidly. Not working to the finished diameter would strengthen the sides of the slot during the cutting process and once it was done an interrupted cut on the lathe would take it down to size before finally cutting off the part at each end. Take the point about the material. That's the trouble with non-virginal material isn't it? You don't know the composition. I'll buy new steel. I'll forget slot drills. Cut a flat with an end mill I think. Use twist drills at each extremity then gently take out the balance with end mills of increasing size. I appreciated the drawing. That's not quite it. The bar, 27mm long at the finish remains intact at 14mm diameter. The slot - 9mm wide x 19mm long - goes through it. Thus you can't take out a complete portion as in the drawing but are leaving about 2.5mm on each side which is what makes it tricky. The slot needs to be straight, consistent and in the middle so as not to weaken one side or the other. Nice artwork though! Thanks again everybody Martyn
not done it yet | 03/02/2019 09:32:48 |
7517 forum posts 20 photos | You can always fill the slot, for final machining, with a softer material - say Al - or glue in a piece of material which can easily be removed after machining to size. |
JasonB | 03/02/2019 10:11:51 |
![]() 25215 forum posts 3105 photos 1 articles | The job in hand, to be cut from the bar after milling . I will stick with the method I described earlier. |
