Wadkin surface grinder.
sparky mike06/09/2018 15:39:48
259 forum posts
77 photos
I have been offered a small Wadkin surface grinder for around £100.00
I don't know the model but I should soon have photos.
It probably weighs around three or four cwt. and looks pretty sturdy but will need complete overhaul and change of motor to single phase.
Has anyone here had any experience of this make of machine ?
Mike.
larry phelan 106/09/2018 18:31:15
1346 forum posts
15 photos
Only know their wood working machines, top of the range,some of them 50 years on,still going strong.
No DIY stuff there !
HOWARDT06/09/2018 19:12:35
1081 forum posts
39 photos
Have a look here. **LINK**
Andrew Johnston06/09/2018 19:48:54
7061 forum posts
719 photos
So not a surface grinder as we know it? In which case changing to a single phase motor probably won't matter. If it was a proper surface grinder, as opposed to a cutter sharpener, then changing to a single phase motor would be a bad thing due to motor vibration.
not done it yet07/09/2018 22:44:33
7517 forum posts
20 photos
A Variable Frequency Drive (VFD) could be used to drive the 3 phase motor, so avoiding a motor change? Other 3 phase converters are also available.
sparky mike08/09/2018 08:29:05
259 forum posts
77 photos
It looks to be smaller version than this one. Or the one shown below has larger control handles/wheels.wadkin-ltd-surface-grinder-vintage-industrial-machine.jpg
Dave T08/09/2018 17:02:36
69 forum posts
Hi Mike,
I sent you a PM a while ago regarding another matter - I thought you were'nt on the forum any more
sparky mike11/09/2018 20:20:46
259 forum posts
77 photos
img_6720.jpgimg_6719.jpgimg_6718.jpgimg_6716.jpgI now have the machine home. Very heavy to lift so we stripped it down into manageable smaller lumps !!
Photos enclosed. Any more info on this machine/model would be very useful.
Rainbows11/09/2018 20:46:13
658 forum posts
236 photos
Looks like a steal if it polishes up
Brian Oldford11/09/2018 21:02:46
686 forum posts
18 photos
Now I'm jealous.
sparky mike11/09/2018 21:03:08
259 forum posts
77 photos
So far,all the nuts and bolts, bar one, have undone ok. Looks mainly like surface rust on the beds so am hoping to do a fast restore on this one. Could well be of use, as I often have to reduce thickness of hardened washers.
The paint is just flaking off, so that will save a considerable time. Being Wadkin make, I wonder if they included this machine in their range of woodworking machines, so that it could have been used for planer blade sharpening ?
Neil Wyatt11/09/2018 21:21:27
19226 forum posts
749 photos
86 articles
Looks like a proper surface grinder from here...
sparky mike11/09/2018 22:05:42
259 forum posts
77 photos
One thing that mystifies me, is what does the "Test" figure represent on the machine lable in photo above ?
Mike.
Mark Rand11/09/2018 22:09:33
1505 forum posts
56 photos
Don't worry about driving it from a single phase motor. The drive belt and inertia of the spindle/wheel will absorb the torque fluctuations for what you want.
sparky mike12/09/2018 07:34:43
259 forum posts
77 photos
Original 3 phase motor was around 2500 RPM, but luckily I have a single phase, same RPM, motor on the shelf ready to bolt on, that a friend gave me last year..
Some of the paint looks like battleship grey, but don't know if that is original.
I find that car engine paint comes up with a nice gloss but takes around three days to dry.
Mike.
sparky mike15/09/2018 07:37:11
259 forum posts
77 photos
The machine is now stripped down except for two parts, the pinion for the rack has a taper pin that refuses to move for the time being, and the rod that holds the collars for setting the travel , will not budge and as both are mounted in the casting I have to take care with both points if I need to remove them.
All the castings have a part number cast in then. Would it be of use to make a list of
all parts for future reference ?
All the castings seem to ring ok with no signs of any cracks.
The base pedestal is a two man lift , as is the middle plate, so not easy to move round the workshop. The base is now primed with a rust inhibitor paint and I will spray it first with a spray two pack filler, that sands easily and makes for a good undercoat for the top gloss.
Original paint seems to be a grey with a blue tint. Looks to be similar shade to Myford's.
I found traces of the paint under the name plate and warning plate. That plate informs owner to only grease bearings with motor running. ?
Due to heavy construction I had wondered if the machine, with suitable chuck, could be used for light milling as well as the grinding it was intended for.
Mike.
not done it yet15/09/2018 19:52:43
7517 forum posts
20 photos
Posted by sparky mike on 15/09/2018 07:37:11:
... That plate informs owner to only grease bearings with motor running. ?
Mike.
We all should be following that advice.
Martin Cargill15/09/2018 20:28:52
203 forum posts
Re "Test Number" Most older Wadkin Machines have this unique number stamped on the ID plate. It seems to be a factory reference number for the machines final testing
sparky mike15/09/2018 21:10:06
259 forum posts
77 photos
Hi Martin,
when you say older, any idea of date when they used this test number.
I have been searching the net ,but so far have been unlucky in finding any information on it.
A photo or drawing would be handy for ref. For example, the wheel guard has been "got at" by previous owners and it would be nice to get it looking how it was when new. I have a feeling it is from 1948 era.
The grinders supplied by Wadkin in later years were used to re-grind blades as used on their woodworking machines, and these were known as cutter grinders. This makes me think that my machine was used for same purpose.
Mike.
Rainbows15/09/2018 22:31:27
658 forum posts
236 photos
RE: surface grinder as miller
Spindle will be too fast for horizontal mill blades. If you can somehow mount a chuck on it you could get away with small endmills but you would have some awkwardness because of the rack and pinion preventing fine adjustment in one axis. Not sure you would mount the chuck either.
If you want a mill I would swap you a denbigh for it
