Here is a list of all the postings Dave T has made in our forums. Click on a thread name to jump to the thread.
Thread: Joe Pie at it again |
03/04/2023 12:28:33 |
Posted by Georgineer on 01/04/2023 11:22:57:
Posted by Dave T on 01/04/2023 09:45:24:
I'll give it 2 days before BH copies it BH? Quinn invariably copies a lot of of Joe Pie's stuff on YT and, just as regularly makes a mess of it |
01/04/2023 09:45:24 |
I'll give it 2 days before BH copies it |
Thread: changing a start stop car battery |
19/03/2023 17:52:06 |
My 2016 Octavia VRS was a straight swap, no fiddling needed at all (according to a VAG specialist) - no problems |
Thread: After a new dial indicator |
13/03/2023 08:57:53 |
Starrett are using more and more chinese stuff now unfortunately |
Thread: Carbide end mills in a hobby machine? your experiences please. |
06/02/2023 08:19:39 |
Tend to favour carbide myself |
Thread: cable core colours for 3 phase motors |
18/09/2022 15:09:43 |
Red, Blue, Yellow phase colours went out more than 15 years ago. Now it's Brown Black Grey. Edited By Dave T on 18/09/2022 15:10:42 |
Thread: Quick Release Coupling |
16/08/2022 16:17:02 |
Look like Rectus style connectors to me |
Thread: Broadband woes |
11/08/2022 11:54:13 |
I have been with VM (and prior companies) for over 30 years - BB only is £48. The problem that I have is that all other companies can only supply less than an 1/8 of the D/L speed that VM provide, despite claims (lies) otherwise. I'm not sure why this VM stitch-up is the case, but it is |
Thread: Myford Tachometer |
15/07/2022 13:39:41 |
It's issue: 290 (Feb 2020) page 34 - Cheers |
14/07/2022 15:39:04 |
Noel, Have you got a reference to which issue number? or month/year obviously |
Thread: Warco VMC powered Quill feed |
18/06/2022 15:58:10 |
I shall have a look, thanks
18/06/2022 12:04:24 |
Thanks Mike, As I (very) recently let my subscription lapse, it looks like I've missed out - Thanks anyway Dave T |
18/06/2022 10:25:42 |
Hi All, How do I go about obtaining a copy of an article from Issue 76? (2001) The article is by Peter Rawlinson and it entitled 'Powered down-feed for milling machine quill' It's something I'm planning, and don't want to re-invent the wheel Thanks Dave T |
Thread: Early Myford Super 7 (1953) Spindle lubrication |
16/05/2022 11:00:10 |
Posted by DMR on 15/05/2022 22:09:22:
Hi Dave, I am with Simon Williams 3 on this. You do not need a continuous oil feed and, above all your window arrangement is not irrepairable. I have an S7 of both designs. My early machine has no cone scoring whereas the later machine does, presumably from the felt pad running dry in the past. What you do need to do is get the tap (as Myford called it) out upwards so that you can push your new white casing into place. That is a bit of a frightening exercise as it is a push-fit. Just oil the hole in the back of the sight glass and even put a spot on top of the cone where it sticks out at the front and you will be good to run for a few hours. You need a piece of nylon rod or similar to turn up a new white bit and put a fine thread on the front/outer end. Trickiest bit is the screw-on front with its short fine thread. The fibre washer is easy and I have spare glass as I made 3 from a microscope side when I broke mine. See my PM and I can talk you through it if you are interested. Dennis Hi Dennis, I extracted the tap a while ago, to remove the remains of the white casing. My problem is that new white casings are impossible to obtain - maybe if I had a lathe I could make one! I would probably make one out of brass if I had the talent and a lathe that worked |
15/05/2022 20:47:56 |
The watch glass and aluminium ring disappeared due to the white plastic body disintegrating |
15/05/2022 16:50:33 |
Hi All, I own the above, which has an oil reservoir cast into the headstock. The sight glass/oil windows is irreparable, and significantly rarer than unicorn teeth, i.e completely unobtainable. Do you think it's feasible to add a drip oiler into the lid of the reservoir and control the lube feed from there? It would be easy to mill up a new lid and add an oiler, but I want to know that it has a reasonable chance of working! Cheers Dave |
Thread: Searching for a good quality, metric-only, 300mm steel ruler |
21/03/2022 21:44:31 |
Any use? https://www.zoro.co.uk/shop/measuring-and-test-equipment/rules-and-measures/300mm-flexible-rustless-rule-round-end/p/ZT1015249X |
Thread: VFD auto tune. |
31/12/2021 14:24:23 |
Nothing attached (in my experience) - It should tell you in the VFD manual Edited By Dave T on 31/12/2021 14:25:10 |
Thread: Do you "still" enjoy driving? |
30/12/2021 23:01:58 |
Have always hated driving - always loved my big bikes until a few years ago
Thread: Turning a riser for VMC Z Axis |
19/08/2020 19:12:03 |
Posted by Robin Graham on 29/07/2020 00:57:13:
Dave - I'm in the East Midlands (Derbyshire, about 4 miles south of Matlock). If that's within striking distance, I'd be happy to help. Robin. A BIG thank you to Robin regarding this problem of mine. Not only did he provide a more than adequate lathe, he provided tea, biccies and toilet facilities over 2 days for me and my pal, Alan. An altogether fine fellow Just got to work out how to mill the pockets with the Mill in bits now Thanks all |
