Need a Frame 56 size motor pulley
Robin07/08/2018 09:19:28
678 forum posts
I cannot find a pulley to fit a frame 56 motor and I am starting to think the world hates me.
The spindle is 11mm diameter by 23mm long with a 4mm Woodruff.
I tried a 50mm taper lock but the screws are on the wrong end.
Surely to God I cannot be the only person on planet Earth who wants to do thisfrown
John Haine07/08/2018 09:25:37
5563 forum posts
322 photos
Do you have a lathe, or is this the motor for it? It would be easy to get a pulley with a standard larger bore, say 13 or 19 mm, and make a little bush which you loctite in place.
Hopper07/08/2018 09:37:16
7881 forum posts
397 photos
RDG Tools sells V belt pulleys with 6mm bore that could be bored out to suit. Cutting keyway is easy with a boring bar in the lathe with toolbit turned sideways and racked back and forth like a slotter. I've done it with cast iron gears so an aluminium pulley should be easy.
John Rudd07/08/2018 09:51:16
1479 forum posts
The alternative to the RDG pulley is make your own.....
When I converted my WM290 clone to vfd/3ph motor, I made my own pulley to suit the new motor ( frame 90 size....)
Making the keyway is probably the most difficult operation but doable in the lathe....
Clive Foster07/08/2018 10:49:04
3630 forum posts
128 photos
Robin
I don't follow your comment about screws on taper lock bushings being on the wrong end. When used with a motor taper lock bushes release by pushing the pulley towards the motor releasing the lock on the shaft so the assembly can be withdrawn. Has to be that way for screws to be accessible.
Clive.
Andrew Tinsley07/08/2018 11:51:15
1817 forum posts
Making your own pulley is a straightforward lathe exercise. Quicker than looking for the rare exact beast that you need. Boring or bushing standard pulleys is not difficult either. At a pinch you can cut the keyway with an appropriate tool held in the toolpost and traversing the carriage, if you don't have a slotting device.
I am no great fan of taper lock systems. They are not very accurate or repeatable, one was used on a 12" rotary spark gap. It was almost impossible to get it running true. Though it would be OK for a small pulley.
Andrew.
Robin07/08/2018 12:03:34
678 forum posts
Henry at Bearing Shop has just patiently explained to me that the problem is the smaller sized pulleys where there is not enough meat between the groove base and the taper lock bushing.
The shaft would have to be 37mm long to reach out through the pulley and then through the taper lock. They cannot overlap. I only have 23mm.
Apparently the first Z pulley that does not suffer with this is the 67mm and as Henry has no problem refunding my silly mistake I can shop with confidence.
Still not totally clear on what i have bought. I like the automotive belts, with the cross cut inside edge to help it bend. Unfortunately they give outside diameter, 595mm, the inside diameter, 544mm, but no PCD so it's a pig in a poke.
Bazyle07/08/2018 12:28:30
6956 forum posts
229 photos
Not sure what your problems is. Henry will bore the pulley to size for you and add a keyway. Did he explain that a woodruff key would be in the shaft and your picture already shows a key in the motor shaft so you just want a keyway. Does get a bit expensive though. If you have a lathe but this is the motor you should be able to jury rig a handle, turn the hole, fit to the motor using the grugscrew while you make a slotting attachment to make the keyway.
John Rudd07/08/2018 12:42:09
1479 forum posts
The alternative to cutting the keyway in the pulley is to drill and tap on centre, if the key is 4mm then use M4 grub screws....but dont let them bear down on the shaft. Cut some small 4 mm dia brass to fit flush with the key way.
This will allow you to lock the pulley onto the shaft without having to cut a keyway and protects the shaft from the grub screw, it also affords a degree of protection of overload too....the brass being soft takes the brunt...
Edited By John Rudd on 07/08/2018 12:42:43
Ian S C07/08/2018 12:58:18
7468 forum posts
230 photos
One method of reducing the bore of a pulley, and putting a keyway in was in ME somewhere in the 1990s.Make a bush to fit the pulley, and bore it to the shaft size, then cut a slot along it to the width of the key. Next fit the bush in the pulley with a shaft lock adhesive, leave it over night. Drill for grub screws, I put one over the key, and one at right angles, ie 90* round the circumference.
Ian S C
Ian Austin07/08/2018 13:13:50
20 forum posts
I have an SPZ taper lock pulley and bush here in hand.
I see from your photo that your bush is a 1008 11mm bore, and the SPZ pulley is two groove.
Ok, so mine is a little bigger - SPZ 1210 18mm bore, but still a 2 groove SPZ pulley.
The pulley is 28mm axial length, so I assume yours is too?
And the bush - although a bigger size - has an axial length of 25.5mm (with the 2.5mm recess on the motor side). So I would have thought you could get a 1008 bush somewhere that is also 25.5mm long, at the most. But because its more tiddly, maybe you'd even find a 1008 bush that's 22mm or so long.
Try googling around suppliers catalogues to see if you can't get a thinner bush.
Ian Austin07/08/2018 13:39:59
20 forum posts
Look, here you go -
http://www.bearing.net.au/wp-content/uploads/2014/10/Taperlock-bushes.pdf
1008 bush, axial length 7/8" = 22.25mm. Perfect.
EDIT:
Sorry, just realised you've got a single groove pulley (was about to ask why you needed a 2-groove pulley, looked again at your photo).
Not to worry. Have a look at this catalogue below, you'll see you can get SPZ pulleys for 1008 bushes that are also 22mm axial length. Yes these are Australian catalogues but you know where it all comes from, eh? If they're here, they'll be there close to you too.
http://www.bearing.net.au/wp-content/uploads/2014/07/SKF-Pulley-Catalogue.pdf
Edited By Ian Austin on 07/08/2018 13:47:36
larry phelan 107/08/2018 13:58:50
1346 forum posts
15 photos
My local supplier keeps pulleys in many different sizes,most of them blank,so that they can be bored to suit. He can arrange to have this done if required,not all that dear,and it gets the job up and running.
Dont bother messing around.
Michael Gilligan07/08/2018 14:32:19
23121 forum posts
1360 photos
Robin,
You have evidently measured the motor shaft, so this is of no consequence ... but I'm surprised:
So far as I was previously aware, frame 56 described a motor to NEMA standard, dimensioned in inches.
According to this list (just found) the shaft would normally be 5/8" diameter. **LINK**
https://www.engineeringtoolbox.com/nema-electrical-motor-frame-dimensions-d_1504.html
... perhaps the standard has been updated [?]
JasonB07/08/2018 15:24:59
IEC 63 Frame is 11mm dia
Edited By JasonB on 07/08/2018 15:27:19
Michael Gilligan07/08/2018 15:37:25
23121 forum posts
1360 photos
Posted by JasonB on 07/08/2018 15:24:59:
Good point, Jason ... but Robin mentioned 56, so maybe my confusion has shifted.
https://jameselectric.ca/help/iec-quick-reference-chart/
JasonB07/08/2018 15:45:17
I wonder if it is Robin who is confused, as the 63 frame also has a 23mm long shaft, not the longer ones found on the imperial motors.
Would also expect a 56 to be about 7" O/A dia and that motor look less when compared to the callipers
Edited By JasonB on 07/08/2018 15:47:06
Robin07/08/2018 15:56:01
678 forum posts
Robin is always confused. If the 63 has an 11mm shaft it is probably a 63.
JasonB07/08/2018 16:01:32
50mm x 11mm Vee belt pulleys on e-bay, just cut your own keyway or do as mentioned above.
J
PS that is not a Woodruff key in your shaft either
Robin07/08/2018 16:51:52
678 forum posts
A bit expensive if I have to cut the keyway myself, and on a slow boat from China to boot.
Okay, not a Woodruff , an M4 whadda-ya-ma-call-it key.
Is there no end to my humiliation? cheeky wink
