What type of glue to use sticking paper paters to metal
Samantha Loughlin | 23/07/2018 13:52:38 |
![]() 3 forum posts | Hello, I am very new to the forum and making and I have a questions I am hoping someone can help me with. I would like to glue a paper pattern that I have printed to copper and brass so that I can use it to cut the correct shape and drill holes in the right place. My question is what glue should I use as obviously after I would need to remove it completely... and also what I use to remove it would be great too Thank you in advance for any advice. Sam
jason udall | 23/07/2018 18:21:37 |
2032 forum posts 41 photos | I would go for "Pritt" or any similar paper glue... Soak in water to remove..paper and glue |
Dalboy | 23/07/2018 18:26:56 |
![]() 1009 forum posts 305 photos | At the moment I work mainly in wood and am looking to start in metal work. What i use to stick patterns down is the spray photographic type adhesive. |
Jon Lawes | 23/07/2018 18:29:14 |
![]() 1078 forum posts | Second vote for Prittstick, I've used it for holding a guitar pickguard pattern to a sheet of stainless before marking out and it held remarkably well and removed cleanly. |
Samantha Loughlin | 23/07/2018 18:35:33 |
![]() 3 forum posts | That's great .. thank you all! |
Jeff Dayman | 23/07/2018 18:41:15 |
2356 forum posts 47 photos | I like spray glue for sticking paper patterns to metal for cutting - 3M's Super 77 is great. Not sure if it's available where you are but artist suppliers in North America usually stock it, and industrial supply firms. Sold in a large can, it lasts ages when doing model work. It is oil resistant, and usually stays stuck over several days if working on a complex part. It cleans up completely with acetone or laquer thinner. Isopropyl (rubbing) alcohol will remove it usually, if you can get the stuff with 20% alcohol or more (much of the stuff in drug stores here is diluted with lots of water to make it look like a great deal ie big bottle low price). Edited By Jeff Dayman on 23/07/2018 18:46:58 |
Neil Wyatt | 23/07/2018 19:13:46 |
![]() 19226 forum posts 749 photos 86 articles | +3 for pritt. Put it on the metal not the paper and let it dry a bit, otherwise it can make the paper wrinkle. N. |
I.M. OUTAHERE | 23/07/2018 19:15:50 |
1468 forum posts 3 photos | Pva wood glue works well and you can just soak it to get the template off without having to scub it to death . |
Gary Wooding | 24/07/2018 08:01:31 |
1074 forum posts 290 photos | I do a lot of pierce sawing on precious metal and use Pritt Power. |
Martin Kyte | 24/07/2018 08:09:30 |
![]() 3445 forum posts 62 photos | Spray Mount from you local art shop. Martin |
Michael Cox 1 | 24/07/2018 08:39:02 |
555 forum posts 27 photos | I have printed patterns onto A4 self adhesive label stock. These stick readily to clean metal. They are easily removed by wetting the label with white spirit and then peeling off. |
Samantha Loughlin | 24/07/2018 09:30:13 |
![]() 3 forum posts | Wow thank you all this is all really helpful .. I have some pritt sticks so going to start there then explore the others so I can find what works best for me. Thank you all again so much!! |
Tim Rowe | 24/07/2018 09:47:39 |
33 forum posts 4 photos | + for Pritt. When the time comes to take the paper patterns off, brush on some clean water and the paper will soak it up readily. It will also start to wrinkle and lift. If you keep going sparingly with the water the paper will more of less fall off taking most of the glue with it. If you try to peel the paper too early you will find more of the glue remaining on the job. |
roy entwistle | 24/07/2018 09:56:19 |
1716 forum posts | Note that there are two types of spray mount. One is instant sticking, the other allows you to reposition the pattern on the job. Spray mounting can also be a bit nasty if used in an enclosed space. Personally I would go with Pritt Roy |
SillyOldDuffer | 24/07/2018 10:31:24 |
10668 forum posts 2415 photos | I don't know of anything better than Pritt, but two things to check before cutting:
The first problem caused serious cussing, the second misplaced hole I pretended was deliberately offset for artistic reasons... |
richardandtracy | 24/07/2018 10:51:38 |
![]() 943 forum posts 10 photos | Posted by Martin Kyte on 24/07/2018 08:09:30:
Spray Mount from you local art shop. Martin That's what I'd suggest too. can be completely removed. Self adhesive crack-back sheets work quite well too. Regards, Richard.
martin107 | 26/07/2018 06:34:05 |
62 forum posts 2 photos |
Martin |
