22mm x 16g steel tube
mick7019/06/2018 13:27:25
524 forum posts
38 photos
anyone know a supplier?
tried local places but what they list 22mm is actually 7/8 now i know 0.2mm ish
shouldn't matter but it does as for some custom length goose necks on bikes i'm building.
if still had lathe set up would have gone for 14g and skimmed down but not an option.
only other option is go for 14g and sand length using flap disc on grinder and marker pen.
done it before and got good results but if idea works will need to make 50.
JasonB19/06/2018 13:38:56
Is 22mm plumbing pipe going to be too thin a wall?
mick7019/06/2018 13:57:46
524 forum posts
38 photos
might be bit thin but neighbours dad is plumber so will see if he as an offcut i can try ta
Brian Wood19/06/2018 14:12:59
2742 forum posts
39 photos
Surely you will need steel tube for bike frames? The plumber will only have copper pipe.
Have you tried metals4u? Their website may have what you need.
JasonB19/06/2018 15:16:12
Opps I read it as wanting copperblush
Martin Connelly19/06/2018 15:21:06
2549 forum posts
235 photos
I think metric tube will be sold with a metric wall thickness. Are you searching for something that does not exist? A quick search on Ebay for 22mm steel tube gave plenty of results with a 2mm wall for instance.
Martin C
Michael Topping19/06/2018 17:30:33
74 forum posts
5 photos
I'm a bit of a cyclist and I have to say that Mild steel is not suited to any part of a bike frame. Have a look at the Reynolds tubing web site they have been around for over 100 years making bike tube sets.
Ordinary mild steel will absorb most of the pedalling effort, not transfer it to the rear wheel. I had a bike once made of low grade aluminium tube and that had exactly the same problem, soon got rid of it.
Michael
Jon19/06/2018 21:48:33
1001 forum posts
49 photos
This can be a long drawn out affair, size is a nominal dimension within tolerances of the Standards governing body.
In the past i have had to buy say short lengths from several suppliers. Sizes vary so buy from same supplier what you need.
Worlds your oyster here.
https://www.steeltube.sk/list-of-dimensional-standards/
I would never advise anyone going to these metal markets the cost is always outrageous and have to collect. Can get three times more for same outlay with delivery from most online places, why bother.
ERW, Cold and hot rolled tube wont be round, certainly offset to the bore.
mick7020/06/2018 07:29:04
524 forum posts
38 photos
martin have sent email to someone on ebay asking for od cheers.
can sand down .2 off 2mm ta.
michael i have built about 40 bikes from steel from recumbants to american style choppers with car back wheels for my kids with no problems.
my first tadpole style recumbant i built 6 yrs ago is still in every day use by friend i passed it onto and ridden to work 8miles every day by him.
i don't know about your normal bikes these days as haven't ridden one years.
not done it yet20/06/2018 07:41:24
7517 forum posts
20 photos
Are these bikes or trikes?
mick7020/06/2018 07:57:19
524 forum posts
38 photos
it's two of these i'm building for mate's who need steering altering to suit their disabilites.
normally would weld to std gooseneck but can't this time for way i have to modify steering.
so have to scratchbuild.
Ian S C20/06/2018 10:38:02
7468 forum posts
230 photos
How about old bike frames.
Ian S C
mick7020/06/2018 11:19:10
524 forum posts
38 photos
cut load up for parts for building them but no tubing that will fit into headstock.
guy i'm building one for as no use of left left so will have steering and crank between legs.
loosely based on one in pic below.
Martin Connelly20/06/2018 20:47:47
2549 forum posts
235 photos
Mick70, just make sure you get seamless tube not erw (electric resistance welded).
Martin C
Tim Stevens20/06/2018 21:38:55
1779 forum posts
The sentence from Michael Topping 'Ordinary mild steel will absorb most of the pedalling effort, not transfer it to the rear wheel' seems not to fit comfortably with my understanding of the properties of mild or any other steel. What else does the energy put in do? Or, which bits get hot? An effort on a pedal will cause the metal - any metal - to spring, and if the effort is too great, it will take a permanent set. Otherwise the spring effect of mild steel is no different from fancy grades of steel - the relevant Young's Modulus is almost exactly the same for all steel.
So, does this mean that a pedal effort on mild steel is enough to bend it permanently? Or what is going on with mild that does not happen with Reynolds ?
Confused of mid Wales - ie Tim
Paul Lousick06/07/2018 02:37:02
2276 forum posts
801 photos
I could not find anything on the Reynolds web site saying "Ordinary mild steel will absorb most of the pedalling effort, not transfer it to the rear wheel". (I am interested to see what they say, please advise address).
Reynolds sell tube sets in different materials, including steel. The main advantage in using other materials is weight and unless you are out to break world records is not required. Building from exotic materials would also require specialised equipment for fabrication.
Also confused of New South Wales, ie Paul
Michael Gilligan06/07/2018 07:01:26
23121 forum posts
1360 photos
Tim & Paul
I think this is a reasonably well-balanced article on the subject: **LINK**
http://www.bretonbikes.com/homepage/cycling-article-blog/163-steel-tubing-for-cycle-tourists
David George 106/07/2018 08:06:07
2110 forum posts
565 photos
Have you asked Reynolds them selves for help, I know that they have helped groups in the past with donations of tube. They are based at Hall Green Birmingham contact details on there web site.
David
Paul Lousick06/07/2018 08:16:45
2276 forum posts
801 photos
Thanks Michael,
I understand all of what is in the link. All basic engineering and common to lots of construction ( have worked in mechanical engineering for 30 years) but what we do not understand is the statement that "Ordinary mild steel will absorb most of the pedalling effort, not transfer it to the rear wheel".
Paul
Michael Gilligan06/07/2018 08:26:38
23121 forum posts
1360 photos
Posted by Paul Lousick on 06/07/2018 08:16:45:
Thanks Michael,
Paul
I think it's probably best to put that exaggeration down to 'poetic licence' Paul
Edit: This is worth a look, regarding 'energy absorption'
https://www.sheldonbrown.com/rinard/fea.htm
Edited By Michael Gilligan on 06/07/2018 08:43:04
